mata7 45 Posted January 5, 2015 Posted January 5, 2015 first thanks that work, but the preference wont saved, soon as i select movies for example, when i return back to TV Show it will show recently episodes again, at lest you know that there is a problem and now i can manage whit this trick util you can fix it again thanks for everything and great job
marcelveldt 736 Posted January 5, 2015 Author Posted January 5, 2015 first thanks that work, but the preference wont saved, soon as i select movies for example, when i return back to TV Show it will show recently episodes again, at lest you know that there is a problem and now i can manage whit this trick util you can fix it again thanks for everything and great job Fixed and available in the latest beta version: 3.2.27
marcelveldt 736 Posted January 5, 2015 Author Posted January 5, 2015 (edited) Hi all, I just pushed another beta update (version .27) out to the beta repo with fixes for some bugs that were discovered by users here and on the kodi forums. - New is the appearance section in the skin settings which will let you customize every single bit of the skin. - Changed is the header in the mediaviews which will now only show the path of the container and not the entire movietitle, also the alignment is changed to match the default theme more. The title is added to all infopanels where it (imo) suits better. If you prefer the movietitle to be displayed in the header, you can enable it again in the appearance settings. Please let me know if you like the changes to the header (I think it's a bit cleaner look now). - Fixed the problem with mediabrowser widgets not remembering preference of content. Also thanks to @@shaefurr for creating the new splashscreen Please test it out and let me know. If no new bugs are found I'll push out update to the stable/official kodi repo. Edited January 5, 2015 by marcelveldt
marcelveldt 736 Posted January 5, 2015 Author Posted January 5, 2015 Is there a stable Helix version yet?Yes, both helix and Gotham versions are available on official kodi repo.
marcelveldt 736 Posted January 5, 2015 Author Posted January 5, 2015 that great, but I was referring to a stable version in the stable xbmb3c repo.No because xbmb3c repo wont let me add both helix and Gotham version on the same repo ( same id, other version)
puithove 209 Posted January 5, 2015 Posted January 5, 2015 Wow Marcel - good stuff. I only have one very small thing for you right now. The Weather widget - when moving from a tile that has no widget (so submenu is shown as just the text above the tiles) to the weather tile, the spotlight is shrunk instead of the wide size that is normal for the Weather widget. When you move from a tile that has a widget (like TV shows in the example pic below) it works as expected (wide spotlight image). In this image, I moved the selector from the Settings tile to the Weather tile.
puithove 209 Posted January 5, 2015 Posted January 5, 2015 I will add that I'm good with the change to the header (breadcrumb).
mata7 45 Posted January 6, 2015 Posted January 6, 2015 Fixed and available in the latest beta version: 3.2.27 thanks a lot, great job
mata7 45 Posted January 6, 2015 Posted January 6, 2015 hey man one quick question, you skin work on openelec? cause i just installed and the widget dont work, maybe im doing someting wrong
xnappo 1611 Posted January 6, 2015 Posted January 6, 2015 @@mata7 - seriously man, can't you change your image?
marcelveldt 736 Posted January 6, 2015 Author Posted January 6, 2015 hey man one quick question, you skin work on openelec? cause i just installed and the widget dont work, maybe im doing someting wrong Should work on all platforms. What doesn't work on the widgets ?
mata7 45 Posted January 6, 2015 Posted January 6, 2015 if i use xbmb on the home screen it wont load any fanart or movies image, but if i use local data it will show it, dont know if i explained my self well, english is my 2 language
mata7 45 Posted January 6, 2015 Posted January 6, 2015 this is what i mean TB With local Library data TB with XBMB3C
pünktchen 1411 Posted January 6, 2015 Posted January 6, 2015 (edited) I don't know if it is a problem with the Titan skin or the Mediabrowser addon in general @@xnappo: I like to define submenu entrys of genre and people for specific "ungrouped collections" of type movie, series and music. I don't mean boxsets with collection eg. "Movie (Anime)", "Movie (Modern)", "Movie (Classics)" ... Genre for a movie collection lists all genre for all collections. (edit: i have two sections were this works as expected, so what's going on here?) Genre for a series collection lists all movie genres! Genre for a music collection isn't available as a subentry at all. Skin shortcuts to a music collection don't show anything, but it works via Video-Addon -> Mediabrowser. People isn't available as a subentry for movie and series collections at all. In general i like to have the same behaviour/options of the webinterface. Edited January 7, 2015 by pünktchen
marcelveldt 736 Posted January 7, 2015 Author Posted January 7, 2015 I don't know if it is a problem with the Titan skin or the Mediabrowser addon in general @@xnappo: I like to define submenu entrys of genre and people for specific "ungrouped collections" of type movie, series and music. I don't mean boxsets with collection eg. "Movie (Anime)", "Movie (Modern)", "Movie (Classics)" ... Genre for a movie collection lists all genre for all collections. (edit: i have two sections were this works as expected, so what's going on here?) Genre for a series collection lists all movie genres! Genre for a music collection isn't available as a subentry at all. Skin shortcuts to a music collection don't show anything, but it works via Video-Addon -> Mediabrowser. People isn't available as a subentry for movie and series collections at all. In general i like to have the same behaviour/options of the webinterface. I can confirm the issues you mentioned. Just reproduced this in my own setup. The list of links that is returned by the addon is wrong, at least for genres. Also "all music" returns empty. It's a mediabrowser addon issue but I will take a look if I can find what's wrong. About your question of adding "people" as possible suboption for every collection, I don't know if this is possible but I'll add it to our list of feature requests, maybe it's an easy change to do. 1
marcelveldt 736 Posted January 7, 2015 Author Posted January 7, 2015 if i use xbmb on the home screen it wont load any fanart or movies image, but if i use local data it will show it, dont know if i explained my self well, english is my 2 languageThe first load can take a while. At first start of the addon it starts retrieving all the images in the background. Did the problem resolve itself in a while or are you still missing the images? If you want, can you take a look at your kodi log file if there are any errors regarding image retrieval?
mata7 45 Posted January 8, 2015 Posted January 8, 2015 no it never loads i at ready remove the mb adon to many problems, i dont know maybe is me, i try with plex adon and it load fast, if i have some time on the weekend i will reinstalled again and let you know, thanks for all you help
shaefurr 1340 Posted January 8, 2015 Posted January 8, 2015 After the last update I cant use custom images anymore for tiles or backgrounds. When I browse for the image only my 1 DVD drive shows up in the file browser window. That a bug? I can post logs or whatever if you need.
marcelveldt 736 Posted January 8, 2015 Author Posted January 8, 2015 After the last update I cant use custom images anymore for tiles or backgrounds. When I browse for the image only my 1 DVD drive shows up in the file browser window. That a bug? I can post logs or whatever if you need. No that's "by design" in Kodi; if no file locations are added in the file manager you're able to browse your entire pc, if a file location is added you can only browse that. Make sure to add extra file locations in the file manegr from kodi. I find that a strange behaviour myself too but it's really a kodi thing...
marcelveldt 736 Posted January 8, 2015 Author Posted January 8, 2015 no it never loads i at ready remove the mb adon to many problems, i dont know maybe is me, i try with plex adon and it load fast, if i have some time on the weekend i will reinstalled again and let you know, thanks for all you help In that case I'm pretty sure it's something in your setup that we didn't cover. You windows machine was running fine right ? Please let me know after your re-install and if you still have problems upload your kodi logfile for us to investigate.
shaefurr 1340 Posted January 8, 2015 Posted January 8, 2015 No that's "by design" in Kodi; if no file locations are added in the file manager you're able to browse your entire pc, if a file location is added you can only browse that. Make sure to add extra file locations in the file manegr from kodi. I find that a strange behaviour myself too but it's really a kodi thing... Ah ok thanks, got it working again. Very odd, especially since it worked fine a day or two ago and just started doing this, I haven't changed anything so figured it was something with the update.
Serandel 0 Posted January 9, 2015 Posted January 9, 2015 Hi, I've upgraded to Kodi and, after finding that the skin I was using wasn't compatible, I tried Titan and it's great! I love that it's beautiful and clear while displaying a lot of information. Nonetheless, I've just a question. Isn't there a "Cast" button in the movie or TV show info screen? I've looked for it everywhere and can't find it. Is it possible that it's a bug in the skin? Thanks for your help.
marcelveldt 736 Posted January 9, 2015 Author Posted January 9, 2015 Hi, I've upgraded to Kodi and, after finding that the skin I was using wasn't compatible, I tried Titan and it's great! I love that it's beautiful and clear while displaying a lot of information. Nonetheless, I've just a question. Isn't there a "Cast" button in the movie or TV show info screen? I've looked for it everywhere and can't find it. Is it possible that it's a bug in the skin? Thanks for your help. Did you try pressing the "right" button on your remote /keyboard?
pünktchen 1411 Posted January 9, 2015 Posted January 9, 2015 Did you try pressing the "right" button on your remote /keyboard?Forgotten to mention this. Sorry! Cast in details view doesn't work with "Touch/Mouse Support" enabled!
Serandel 0 Posted January 10, 2015 Posted January 10, 2015 Forgotten to mention this. Sorry! Cast in details view doesn't work with "Touch/Mouse Support" enabled! That was it! Cast option is replaced with an 'X' button if 'Touch/Mouse Support' is enabled. I can't say I understand the logic behind that, especially noting that I can use the mouse pointer either way and that 'Cast' could be a regular option in the footer menu. But it works again, so thank you very much.
