great skin,
Was wondering a couple of things.  Using the New Kodi, I am trying to get the log off button to appear.  I added it to the home screen, but it does not show.
also I have set up 1 profile for my kids pointing to there login, and another for me pointing to my login.  both profiles show the same kids content.
Do not know if the second one is skin related or plugin related.
Thanks.
marcelveldt
great skin,
Thanks.
That's strange, if you add a tile/shortcut to home it should offcourse appear in the list.
Did the menu build succesfull after you made the changes ?
I've worked today on a huge improvement in the menubuilding and will provide a new beta later today.
Maybe you could test with that version instead ?
Also, your problem about the multiple MB3 profiles was fixed some days ago in the XBMB3C addon but I don't think that's available allready in the stable version.
Just to be sure you could try the MediaBrowser beta repo.
Thanks, it does say it is rebuilt, and I know its working since it removed some of the menu items.  For some reason it did not add the Kodi->commands Log Off.
I will give it a look tonight.
Thanks for noticing, this occurs when some mediainfo is not known. Normally you'd see on the left the videocodec and resolution etc.
I can fix this by changing the aligment but maybe I can better hide it all the way because the info is not present ?
@@marcelveldt - on 3.2.18 I see you removed the media tags from Collections, Shows, and Seasons.  It looks like they're also now gone from Episodes though, and those I think should still be there.  Do you mind taking a look?
marcelveldt
Ah, I found out why it isn't working. This is a known bug in the skinshortcuts script that has been fixed but not yet pushed to the repo.
You can manually install the script by installing the zip:
https://github.com/phil65/script.skinshortcuts/archive/master.zip
Just go to settings --> addons --> install from zip and point to the downloaded zip file and it should be fine.
I'll ask the script maintainer to do a push to the repo soon.
marcelveldt
At my test machines they're present... Are you testing with the "fast data" option in the xbmb3c addon by any chance ?
Just noticed this afternoon that some data is missing if this is enabled.
EDIT: confirmed bug with fast data enabled, also happens on my system.
@xnappo: When "fast movies" mode is enabled some data is missing, like the plot, tvshowtitle and flags for episodes.
For movies things appears to be fine, it seems to be only wrong on the episodes
Edited by marcelveldt
  • Like 1
What data is that?
xnappo
marcelveldt
What data is that?
xnappo
For all tvshows --> the flags are missing (both audio and video)
For user collection of type tvshows, episode level --> tvshow title is missing
For user collection of type tvshows, the "in progress", "next episodes" and "recent episodes" --> almost all data missing, like the plot, tvshow title thumbs etc.
Just found out this afternoon. Do you have a clue ?
marcelveldt
New BETA version of the skin available on the beta repo!
- Massive speed improvement for the menu building (now only seconds).
- Improved widget assignments
- Fixed some styling issues and small bugs.
- Major improvements for MediaBrowser users
Version: 2.2.19 for Gotham and 3.2.19 for Helix.
Please try it out and let me know if you find any issues.
Because of the massive speed improvement I'd like to get this version to the stable repo asap
  • Like 1
Yep - thanks for beta testing.  Need to get me some more testers!  I was thinking this was ready for stable.
Got some work to do..
xnappo
@@marcelveldt - can you test with the latest Git?  The top two I am pretty sure are fixed, I didn't see the third with missing thumbs etc - make sure you restart after turning on FastData and that there are no errors in your log.
Thanks,
xnappo
marcelveldt
Thanks,
xnappo
That was quick :-)
The first two are fixed, I have the flags and the tvshow title again.
The third is still broken. I mean the sublevel of one of the usercollections:
xbmb3c.X.recent.path (and also unwatchedm inprogress, next etc.)
or
xbmb3c.usr.movies.X.recent.path (and also unwatchedm inprogress, next etc.)
or
mediabrowser.usr.X.recent.path
These work fine without the fast movies but not when it's enabled. I know that there are lot's of users that use links in the skins to their own collections so that's why I always test this part.
For example if I open the recent-episodes sublevel of my tvshows section it doesn't have a thumb/icon, tvshow-artwork, no plot, no details like flags/genre etc,
marcelveldt
Ok.. Going out for the day. Will check it out tonight
New beta of the skin is available for you to test.
Also the latest version of the xbmb3c addon (beta) has improvements on the userswitching, this should fix your problem with the tiles not matching your MB3 profile.
That was quick :-)
or
or
Okay.  Sadly I don't know how that works as the skin I use doesn't use it.  It sounds like the 'details string' for those queries is incorrect.
@@im85288 - do you know where these puppies are?  They don't come from 'def skin' anymore right?
marcelveldt
skinhelperthread.py --> line 185
Note that it's working with fast movies turned off...
marcelveldt
@@xnappo, one more issue I found (in all collections, also the global ones) is that the resume percentage is empty.
ListItem.PercentPlayed is just empty
Okay, please try Git for your 3rd problem.  Will look at the 4th now.
  • Like 1
marcelveldt
fixed!
Percentage in collections - you mean like BoxSets?
saitoh183
Dont see it when i refresh repo
saitoh183
Ok, finally installed this + latest mediabrowser (759) and i see my UFC section again but when i add it as a tile and then open it, it just goes into collections (boxsets)
here is a snippet of log:
01:54:23 T:4996  NOTICE: XBMB3C RecentInfoUpdaterThread -> Updating Recent TV Show List
01:54:23 T:4996  NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL ==
01:54:23 T:4996  NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?Limit=30&Recursive=true&SortBy=DateCreated&Fields=Path,Genres,MediaStreams,ShortOverview,Overview&SortOrder=Descending&Filters=IsUnplayed,IsNotFolder&IsVirtualUnaired=false&IsMissing=False&IncludeItemTypes=Episode&format=json
01:54:23 T:4996  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh
01:54:23 T:4996  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: ea8782955fb948f8852beeaa2623565d
01:54:23 T:4996  NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:23 T:4996  NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:24 T:4996  NOTICE: XBMB3C RecentInfoUpdaterThread -> Updating Recent Unplayed TV Show List
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL ==
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/Latest?Limit=30&SortBy=DateCreated&Fields=Path,Genres,MediaStreams,ShortOverview,Overview&IsPlayed=false&GroupItems=false&IncludeItemTypes=Episode&format=json
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: ea8782955fb948f8852beeaa2623565d
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:24 T:4996  NOTICE: XBMB3C RecentInfoUpdaterThread -> Updating Recent MusicList
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?Limit=10&Recursive=true&SortBy=DateCreated&Fields=Path,Genres,MediaStreams,Overview&SortOrder=Descending&Filters=IsUnplayed,IsFolder&IsVirtualUnaired=false&IsMissing=False&IncludeItemTypes=MusicAlbum&format=json
01:54:24 T:4996  NOTICE: XBMB3C RecentInfoUpdaterThread -> Updating Recent Photo
01:54:24 T:4996  NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items?Limit=10&Recursive=true&SortBy=DateCreated&Fields=Path,Genres,MediaStreams,Overview&SortOrder=Descending&Filters=IsUnplayed&IsVirtualUnaired=false&IsMissing=False&IncludeItemTypes=Photo&format=json
01:54:25 T:3200  NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID :
01:54:25 T:3200  NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Resetting MB3.Background.Item.FanArt
01:54:30 T:3488  NOTICE: Thread LanguageInvoker start, auto delete: false
01:54:30 T:3488  NOTICE: -->Python Interpreter Initialized<--
01:54:30 T:1236  NOTICE: Thread LanguageInvoker start, auto delete: false
01:54:30 T:4400   ERROR: Control 58 in window 10025 has been asked to focus, but it can't
01:54:30 T:1236  NOTICE: -->Python Interpreter Initialized<--
01:54:31 T:1236  NOTICE: ===== XBMB3C START =====
01:54:31 T:1236  NOTICE: XBMB3C -> running Python: sys.version_info(major=2, minor=7, micro=8, releaselevel='final', serial=0)
01:54:31 T:1236  NOTICE: XBMB3C -> running XBMB3C: 0.9.759
01:54:31 T:1236  NOTICE: 14.0 Git:20141223-ad747d9
01:54:31 T:1236  NOTICE: XBMB3C -> Platform: Windows
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> Flatten is:
01:54:31 T:1236  NOTICE: XBMB3C -> LogLevel:  1
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> Script argument date ['plugin://plugin.video.xbmb3c/', '7', '?url=http%3A//192.168.13.198%3A8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items%3FParentId%3D839177042fdd6bd9e49e3eefb1ea61c0%26IsVirtualUnaired%3Dfalse%26IsMissing%3DFalse%26Fields%3DEpisodeCount%2CSeasonCount%2CPath%2CGenres%2CStudios%2CCumulativeRunTimeTicks%2CMetascore%2CSeriesStudio%2CAirTime%2CDateCreated%2CSeasonUserData%2CMediaStreams%2COverview%26SortOrder%3DAscending%26SortBy%3DSortName%26Genres%3D%26format%3Djson%26ImageTypeLimit%3D1&mode=0']
01:54:31 T:1236  NOTICE: XBMB3C 0 -> Version : 14.0 - {u'major': 14, u'tag': u'stable', u'minor': 0, u'revision': u'20141223-ad747d9'}
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> Script params is {'url': 'http%3A//192.168.13.198%3A8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items%3FParentId%3D839177042fdd6bd9e49e3eefb1ea61c0%26IsVirtualUnaired%3Dfalse%26IsMissing%3DFalse%26Fields%3DEpisodeCount%2CSeasonCount%2CPath%2CGenres%2CStudios%2CCumulativeRunTimeTicks%2CMetascore%2CSeriesStudio%2CAirTime%2CDateCreated%2CSeasonUserData%2CMediaStreams%2COverview%26SortOrder%3DAscending%26SortBy%3DSortName%26Genres%3D%26format%3Djson%26ImageTypeLimit%3D1', 'mode': '0'}
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C Service Timestamp: 1419922470
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C Current Timestamp: 1419922471
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C Connection Manager Called
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C server already set
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> Mode: 0
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> URL: http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?ParentId=839177042fdd6bd9e49e3eefb1ea61c0&IsVirtualUnaired=false&IsMissing=False&Fields=EpisodeCount,SeasonCount,Path,Genres,Studios,CumulativeRunTimeTicks,Metascore,SeriesStudio,AirTime,DateCreated,SeasonUserData,MediaStreams,Overview&SortOrder=Ascending&SortBy=SortName&Genres=&format=json&ImageTypeLimit=1
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> Name:
01:54:31 T:1236  NOTICE: XBMB3C 1 -> XBMB3C -> identifier: None
01:54:31 T:1236  NOTICE: XBMB3C 1 -> == ENTER: getContent ==
01:54:31 T:1236  NOTICE: XBMB3C 1 -> URL: http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?ParentId=839177042fdd6bd9e49e3eefb1ea61c0&IsVirtualUnaired=false&IsMissing=False&Fields=EpisodeCount,SeasonCount,Path,Genres,Studios,CumulativeRunTimeTicks,Metascore,SeriesStudio,AirTime,DateCreated,SeasonUserData,MediaStreams,Overview&SortOrder=Ascending&SortBy=SortName&Genres=&format=json&ImageTypeLimit=1
01:54:31 T:1236  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh
01:54:31 T:1236  NOTICE: MB3 DataManager -> Cache_Data_Manager:C:\Users\htpc\AppData\Roaming\Kodi\userdata\addon_data\plugin.video.xbmb3c\cache\5f1e83f428edfbb36523f63b237c4e26
01:54:31 T:1236  NOTICE: MB3 DataManager -> Loading Cached File
01:54:31 T:2612  NOTICE: MB3 CacheManagerThread -> CacheManagerThread Started
01:54:31 T:1236  NOTICE: Cache_Data_Manager: Returning Cached Result
01:54:31 T:1236  NOTICE: MB3 DataManager -> Returning Cached Result
01:54:31 T:1236  NOTICE: XBMB3C 1 -> == ENTER: processFast ==
01:54:31 T:1236  NOTICE: XBMB3C 1 -> Processing secondary menus
01:54:31 T:1236  NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL ==
01:54:31 T:1236  NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/Items/839177042fdd6bd9e49e3eefb1ea61c0?format=json
01:54:31 T:1236  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: ea8782955fb948f8852beeaa2623565d
01:54:31 T:1236  NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:31 T:1236  NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:31 T:2612  NOTICE: MB3 CacheManagerThread -> Cache Validator String (11f13a4a3e4d46d802b9565b38804bf1)
01:54:31 T:2612  NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL ==
01:54:31 T:2612  NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?ParentId=839177042fdd6bd9e49e3eefb1ea61c0&IsVirtualUnaired=false&IsMissing=False&Fields=EpisodeCount,SeasonCount,Path,Genres,Studios,CumulativeRunTimeTicks,Metascore,SeriesStudio,AirTime,DateCreated,SeasonUserData,MediaStreams,Overview&SortOrder=Ascending&SortBy=SortName&Genres=&format=json&ImageTypeLimit=1
01:54:31 T:2612  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh
01:54:31 T:2612  NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: ea8782955fb948f8852beeaa2623565d
01:54:31 T:2612  NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:31 T:2612  NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.759"', 'X-MediaBrowser-Token': 'ea8782955fb948f8852beeaa2623565d'}
01:54:31 T:1236 WARNING: CVideoInfoTag::GetDurationFromMinuteString <runtime> should be in minutes. Interpreting '0' as 0 minutes
01:54:31 T:2612 WARNING: Previous line repeats 47 times.
01:54:31 T:2612  NOTICE: MB3 CacheManagerThread -> Loaded Validator String (11f13a4a3e4d46d802b9565b38804bf1)
01:54:31 T:2612  NOTICE: MB3 CacheManagerThread -> CacheManagerThread Exited
01:54:31 T:4844 WARNING: Previous line repeats 56 times.
01:54:31 T:4844  NOTICE: Thread BackgroundLoader start, auto delete: false
01:54:31 T:1236  NOTICE: Previous line repeats 1 times.
01:54:31 T:1236  NOTICE: ===== XBMB3C STOP =====
01:54:31 T:1396  NOTICE: Thread JobWorker start, auto delete: true
01:54:31 T:1236 WARNING: CPythonInvoker(29, C:\Users\htpc\AppData\Roaming\Kodi\addons\plugin.video.xbmb3c\default.py): the python script "C:\Users\htpc\AppData\Roaming\Kodi\addons\plugin.video.xbmb3c\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcaddon::Addon
01:54:31 T:3200  NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID : 3042a01feac59942c562cd845c0dcf7e
01:54:31 T:3200  NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Image 2 of 1
01:54:31 T:3200  NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink MB3.Background.Item.FanArt=http://192.168.13.198:8096/mediabrowser/Items/3042a01feac59942c562cd845c0dcf7e/Images/Backdrop/0/e3ab56fe27d389446754d0fb04910a34/original/10000/10000/0?
Full log: http://pastebin.com/n5dS2AyD
marcelveldt
No, just the resume percentage for any item in the lists. So "all movies" or a specific collection that doesn't matter.
ListItem.PercentPlayed is not filled.
marcelveldt
Aha, after long searching I found a little bug that was causing this. Fixed it and will provide a new beta later today.
If you allready would like to test it, please overwrite the attached "includesvariables.xml" file in c:\users\username\appdata\kodi\addons\skin.titan.beta\1080i
Close xbmc/kodi before overwriting the file.
IncludesVariables.xml
Okay, still totally confused by the percentage thing.  The only thing we have ever set AFAIK is:
list.setProperty("complete_percentage", str(cappedPercentage))
That is from the 'old' code.  I am setting the same thing in the new code, and it looks to be working fine in Aeon Nox:
I can certainly set a NEW property called PercentPlayed - but I am really confused as to why it worked before.  It works with 'Fast' disabled?
Thanks,
xnappo
Guest
