michelking 1 Posted December 25, 2014 Posted December 25, 2014 Hello there,Titan skin is not working on SPMC anymore.I got "Unable to build menu" install log uploader blabla......Also there is no settings button so I can't change anythingsolution anybody?using tronsmart MK908IIgreeetz
marcelveldt 736 Posted December 25, 2014 Author Posted December 25, 2014 Hello there, Titan skin is not working on SPMC anymore. I got "Unable to build menu" install log uploader blabla...... Also there is no settings button so I can't change anything solution anybody? using tronsmart MK908II greeetz Hi, I'm not familiar with spmc but could you send me your xbmc log please? You may do this here or in a PM. The skin uses the skinshortcuts script for processing all menus so I think we'll have to look there
michelking 1 Posted December 25, 2014 Posted December 25, 2014 Hi, I'm not familiar with spmc but could you send me your xbmc log please? You may do this here or in a PM. The skin uses the skinshortcuts script for processing all menus so I think we'll have to look there Hi, thats not possible got only a blue screen so I can't get in otherwise I had changed the skin
marcelveldt 736 Posted December 25, 2014 Author Posted December 25, 2014 Hi, thats not possible got only a blue screen so I can't get in otherwise I had changed the skin Do you have file access or shell access to the box ? In that case you can go to the xbmc directory and get the logfile. Also you can delete the skin.titan directory so the skin won't be loaded. There must be some dependency missing on spmc why it's not working. Normal xbmc/kodi builds work just fine. I'll try to get my android tablet installed with spmc to try it myself in case you cannot get the logfile
michelking 1 Posted December 25, 2014 Posted December 25, 2014 Do you have file access or shell access to the box ? In that case you can go to the xbmc directory and get the logfile. Also you can delete the skin.titan directory so the skin won't be loaded. There must be some dependency missing on spmc why it's not working. Normal xbmc/kodi builds work just fine. I'll try to get my android tablet installed with spmc to try it myself in case you cannot get the logfile No can't acces the log file (or don't no how?) its since a few days after Titan update I supose bedankt voor het meedenken
marcelveldt 736 Posted December 25, 2014 Author Posted December 25, 2014 No can't acces the log file (or don't no how?) its since a few days after Titan update I supose bedankt voor het meedenken I have to go for the Christmas meal /evening now but I'll look at it (ans reply to you) tomorrow. Thanks for your patience
e123enitan 276 Posted December 25, 2014 Posted December 25, 2014 I have to go for the Christmas meal /evening now but I'll look at it (ans reply to you) tomorrow. Thanks for your patience Big XMAS to U, enjoy your meal 1
michelking 1 Posted December 25, 2014 Posted December 25, 2014 I have to go for the Christmas meal /evening now but I'll look at it (ans reply to you) tomorrow. Thanks for your patien Thanks have a nice x_mass 1
marcelveldt 736 Posted December 26, 2014 Author Posted December 26, 2014 No can't acces the log file (or don't no how?) its since a few days after Titan update I supose bedankt voor het meedenken I've installed SPMC on my android tablet this morning and all is working fine. Both the stable and the beta versions of the skin work fine, no problems with the menu not beiing build at all. So it must have something to do woth your setup or something so basically I need the xbmc logfile
puithove 209 Posted December 26, 2014 Posted December 26, 2014 I see a little glitch with the new media tag icons - see the leftmost border is cut off with them in the bottom left:
marcelveldt 736 Posted December 26, 2014 Author Posted December 26, 2014 I see a little glitch with the new media tag icons - see the leftmost border is cut off with them in the bottom left: Thanks for noticing, this occurs when some mediainfo is not known. Normally you'd see on the left the videocodec and resolution etc. I can fix this by changing the aligment but maybe I can better hide it all the way because the info is not present ?
puithove 209 Posted December 26, 2014 Posted December 26, 2014 maybe I can better hide it all the way because the info is not present ? Yea, probably hide it all for those cases.
michelking 1 Posted December 27, 2014 Posted December 27, 2014 I've installed SPMC on my android tablet this morning and all is working fine. Both the stable and the beta versions of the skin work fine, no problems with the menu not beiing build at all. So it must have something to do woth your setup or something so basically I need the xbmc logfile Thanks Marcel, I just starded over and everything is fine now. The onlything I can think of thats my app (spmc) getting to heavy 1.50gb. freshstart and something to do
marcelveldt 736 Posted December 27, 2014 Author Posted December 27, 2014 Thanks Marcel, I just starded over and everything is fine now. The onlything I can think of thats my app (spmc) getting to heavy 1.50gb. freshstart and something to do Ok, thanks for reporting back, good to hear that it's working now.
saitoh183 137 Posted December 28, 2014 Posted December 28, 2014 (edited) @@marcelveldt I just encountered a weird issue. I just swicth profile back to my titan profile and after it loaded once again my tiles were messed up. My Tv show tile because playlist (with tvshow widget) and my UFC tile became Tv show. I usually have to exit Kodi and restart it but this time, it didnt fix it. Also When i try to add my UFC tile back, it doesnt appear under mediabrowser collection but if i start mediabrowser addon directly, its there. I think the screw of tiles happened because the UFC node isnt accessible. I notice that if this type of bug happens, Titan replaces the tile with a random section (ie: tvshow or playlist) and then skin loader just leaves it. Here are the 2 last logs maybe you can see something... http://pastebin.com/jT0PY2HZ http://pastebin.com/Hf2kvivb titan 3.1.18 MB 753 Also is it normal the skin shortcut takes a long time to lad changes or load tiles when i switch profiles..when coming from a swicth profile...it can take up to 3mins before loading proper tiles Edited December 29, 2014 by saitoh183
marcelveldt 736 Posted December 29, 2014 Author Posted December 29, 2014 @@marcelveldt I just encountered a weird issue. I just swicth profile back to my titan profile and after it loaded once again my tiles were messed up. My Tv show tile because playlist (with tvshow widget) and my UFC tile became Tv show. I usually have to exit Kodi and restart it but this time, it didnt fix it. Also When i try to add my UFC tile back, it doesnt appear under mediabrowser collection but if i start mediabrowser addon directly, its there. I think the screw of tiles happened because the UFC node isnt accessible. I notice that if this type of bug happens, Titan replaces the tile with a random section (ie: tvshow or playlist) and then skin loader just leaves it. Here are the 2 last logs maybe you can see something... http://pastebin.com/jT0PY2HZ http://pastebin.com/Hf2kvivb titan 3.1.18 MB 753 Also is it normal the skin shortcut takes a long time to lad changes or load tiles when i switch profiles..when coming from a swicth profile...it can take up to 3mins before loading proper tiles Hi Saitoh, Thanks for the log, other then some errors in the skin (that are fixed in beta a while ago) I see no strange issues. What I do notice is that you're using the beta version of the XBMB3C addon with stable version of the skin. Please also use the beta version of the skin or use the stable version of the xbmb3c addon. About the switching of profiles: Do you have the same skin on both profiles or do the profiles also have another skin ? The menu shortcuts are build into a file called "script-skinshortcuts-incldes.xml" it should only do this at changes, so if you manually edit the menu or when a skin update is available, not every time. And yes, this can take some time, I noticed that with most recent version of skinshortcuts this is even a bit more slow then it was before. Is it possible for you to send me that file ? It is located in c:\users\username\appdata\roaming\kodi\addons\skin.titan\1080i\ Also, the menu shortcuts to your MB3 collections are provided by the MB3 addon itself. The skin just keeps a reference to that and displays that. What I'm starting to think is that the order of the collections changes sometimes and that's what's causing your problems. For testing could you go to the menu editor -- mb3 collections and notice the order of the items there ? Does this order change after a profile switch or kodi restart ?
saitoh183 137 Posted December 29, 2014 Posted December 29, 2014 Hi Saitoh, Thanks for the log, other then some errors in the skin (that are fixed in beta a while ago) I see no strange issues. What I do notice is that you're using the beta version of the XBMB3C addon with stable version of the skin. Please also use the beta version of the skin or use the stable version of the xbmb3c addon. Sorry i am using 3.2.18 (typo in previous post) and it says Titan Mediabrowser Beta (Helix) About the switching of profiles: Do you have the same skin on both profiles or do the profiles also have another skin ? The menu shortcuts are build into a file called "script-skinshortcuts-incldes.xml" it should only do this at changes, so if you manually edit the menu or when a skin update is available, not every time. And yes, this can take some time, I noticed that with most recent version of skinshortcuts this is even a bit more slow then it was before. I use Aeon MQ5 (even if its gotham..it works besides the keyboard) Also, the menu shortcuts to your MB3 collections are provided by the MB3 addon itself. The skin just keeps a reference to that and displays that. What I'm starting to think is that the order of the collections changes sometimes and that's what's causing your problems. For testing could you go to the menu editor -- mb3 collections and notice the order of the items there ? Does this order change after a profile switch or kodi restart ? Yeah the order did change because i added my photos to mbs this weekend so the photo category was added. But the thing is that UFC isnt even in the list anymore. Is there a way to make it re-cache? http://pastebin.com/b6niZUSi
marcelveldt 736 Posted December 29, 2014 Author Posted December 29, 2014 Sorry i am using 3.2.18 (typo in previous post) and it says Titan Mediabrowser Beta (Helix) I use Aeon MQ5 (even if its gotham..it works besides the keyboard) Yeah the order did change because i added my photos to mbs this weekend so the photo category was added. But the thing is that UFC isnt even in the list anymore. Is there a way to make it re-cache? http://pastebin.com/b6niZUSi Ah, okay/ Than it's fine :-) I suppose that skin error is caused by MQ5 than... How many items are there in the list o collections ? There currently is a limit in Titan of 10 collections, maybe I need to extend this. Also some good news about the menu building. I've been working on that and managed to turn it down to a few seconds, will provide new beta of the skin later on.
saitoh183 137 Posted December 29, 2014 Posted December 29, 2014 Ah, okay/ Than it's fine :-) I suppose that skin error is caused by MQ5 than... How many items are there in the list o collections ? There currently is a limit in Titan of 10 collections, maybe I need to extend this. Also some good news about the menu building. I've been working on that and managed to turn it down to a few seconds, will provide new beta of the skin later on. Yup...UFC would make 11...so again, when titan cant find a tile, it replaces it with a default tile
marcelveldt 736 Posted December 29, 2014 Author Posted December 29, 2014 Yup...UFC would make 11...so again, when titan cant find a tile, it replaces it with a default tile No, it just uses the content that's provided by the MediaBrowser server and if there's something changed serverside, the client will change too. The problem is that if something is added to the list of collections in the MB3 server, the order of all items change and that's what you're experiencing. The skin has a reference -for example- to tile 1 in your homemenu = collection item 3 from the MB3 server with name "my movies" If the order changes at serverside and collection item 3 is no longer "my movies" it will display whatever has become "collection item 3" @@Luke, is it possible that the order of user collections change when you add something ? It looks like when something is added serverside this is not added at the end of the list but instead the whole order changes.
saitoh183 137 Posted December 29, 2014 Posted December 29, 2014 Yup...UFC would make 11...so again, when titan cant find a tile, it replaces it with a default tileWell the reason UFC isn't showing is because of your limit of 10 items.
marcelveldt 736 Posted December 29, 2014 Author Posted December 29, 2014 Well the reason UFC isn't showing is because of your limit of 10 items. Yeah, I'm currently extending that to 15 or 20 items so that will be solved later today. What I am curious about is why the order of items changes in the collection. You reported that your tiles were suddenly all messed up that's only possible if the order changes. Or was that after you added the photo collection ?
saitoh183 137 Posted December 29, 2014 Posted December 29, 2014 Yeah, I'm currently extending that to 15 or 20 items so that will be solved later today. What I am curious about is why the order of items changes in the collection. You reported that your tiles were suddenly all messed up that's only possible if the order changes. Or was that after you added the photo collection ? That was after I added the photos. But I did state in a previous post that when switching profiles to the titan one, I experienced this problem and that I had to restart kodi to fix it.
marcelveldt 736 Posted December 29, 2014 Author Posted December 29, 2014 That was after I added the photos. But I did state in a previous post that when switching profiles to the titan one, I experienced this problem and that I had to restart kodi to fix it. OK, that one should be fixed by now because we made some changes in the addon. I will upload a new beta of the skin somewehere within the next hours so please try that with the latest beta xbmb3c addon and I hope it's all solved than.
saitoh183 137 Posted December 29, 2014 Posted December 29, 2014 Ok.. Going out for the day. Will check it out tonight
