marcelveldt 736 Posted December 9, 2014 Author Posted December 9, 2014 Do you have plans to add scenes to the info page, or is that something that needs to be added to the actual MB plugin? Also one suggestion, is it possible to animate the disc on the info page? Just looks a bit odd to me stuck in a static position. The scenes would be something for the addon itself, I don't think that this is currently supported. I tried animating the discart on the infopage but I found it a bit destracting in that place. It's easy to add it back in so will create a skinsetting for it.
e123enitan 276 Posted December 9, 2014 Posted December 9, 2014 As I understand correctly you'd like to have a rotating fanart thumb for your movie genres button? Sorry, this is not possible... You can off course set your own custom image to the button Thanks, Any I am happy with the results of Genres, all categories appears nicely. However, my thought is Genres are based on movies library, I was hoping it should only extract back drops rotations from GENRES categories ONLY, but see back drop rotations from adult fanart, this defeated the purpose of having Genres for audience without seeing the adult collections, any idea on how this could be configured to prevent adult backdrops populating, while this maintain backdrop rotations. Thanks
dtaylor 0 Posted December 9, 2014 Posted December 9, 2014 I think you have to restart XBMC/Kodi after you first installed things... Thanks but tried that and it doesn't help. The movies widget on the homescreen does nothing at all. I can get to mediabrowser via Videos but thats way to many clicks to get to movies. Also I can't add in a homecreen menu item for mediabrowser collections. Then after playing around a while the whole thing has locked up!!
Lucii3n 0 Posted December 9, 2014 Posted December 9, 2014 Hi everybody, i've a question ... I'm noob with titan skin but i would like something, i will like place music theme for my library tv-shows. it's possible ? because with tvtunes it's not working.... Someone can help me ? Thanks for your help
marcelveldt 736 Posted December 9, 2014 Author Posted December 9, 2014 Hi everybody, i've a question ... I'm noob with titan skin but i would like something, i will like place music theme for my library tv-shows. it's possible ? because with tvtunes it's not working.... Someone can help me ? Thanks for your help Are you using MediaBrowser as your backend with the skin ? If so, please keep in mind that you have to setup/enable the tvtunes addon in the MB3 server as well..
marcelveldt 736 Posted December 9, 2014 Author Posted December 9, 2014 Thanks but tried that and it doesn't help. The movies widget on the homescreen does nothing at all. I can get to mediabrowser via Videos but thats way to many clicks to get to movies. Also I can't add in a homecreen menu item for mediabrowser collections. Then after playing around a while the whole thing has locked up!! Did you enable mediabrowser mode in the skin settings for the movies section ?
marcelveldt 736 Posted December 9, 2014 Author Posted December 9, 2014 Thanks, Any I am happy with the results of Genres, all categories appears nicely. However, my thought is Genres are based on movies library, I was hoping it should only extract back drops rotations from GENRES categories ONLY, but see back drop rotations from adult fanart, this defeated the purpose of having Genres for audience without seeing the adult collections, any idea on how this could be configured to prevent adult backdrops populating, while this maintain backdrop rotations. Thanks Hmm, I think I understood your question not good enough. I think by genres you mean your MB3 collections that you've set up. Well this is in fact possible as you want it. Go to the skin settings --> configure menu items Press the add button Go to MediaBrowser collections Here you will see your mediabrowser collections, you can add a tile for every collection you have. --> the tile image will only show images from that particular collection --> if you also want a widget for that collection tile, also press "select widget" --> custom collection widget
marcelveldt 736 Posted December 9, 2014 Author Posted December 9, 2014 Currently uploading a new beta of the skin to the beta repo, version 2.2.4 with some small fixes: - fixed some image scaling issues- fixed animated discart in movieinfo Dialog- added labels to square panels- added rss feed to enhanced home screen- fixed label error in widget if no rating available- fixed widgets not visible if message dialog visible
marcelveldt 736 Posted December 9, 2014 Author Posted December 9, 2014 Cool...wasnt sure if it was skin related or not...because with the current scaling we can only use 1 type of box to make it look nice Please try with latest beta of the skin.. I've been playing around with the scalings. Maybe things will look better now but I'm not 100% sure 1
shaefurr 1340 Posted December 9, 2014 Posted December 9, 2014 (edited) Being nit-picky here, but is there a reason the thumbs in the widgets are stretched? its not a lot but it is noticeable. You can see in this screen the size they are now and they size they should be. Also I really like the animated disc in the info page, but if its found to be too distracting to others as you said i'm fine if it needs to be changed back. Edited December 9, 2014 by shaefurr
franklinismint 0 Posted December 10, 2014 Posted December 10, 2014 Hey I was wondering if there is a way to see how much ahead the movie had buffered when your watching it
marcelveldt 736 Posted December 10, 2014 Author Posted December 10, 2014 Being nit-picky here, but is there a reason the thumbs in the widgets are stretched? its not a lot but it is noticeable. You can see in this screen the size they are now and they size they should be. Also I really like the animated disc in the info page, but if its found to be too distracting to others as you said i'm fine if it needs to be changed back. Thanks for noticing, I thought I fixed all scaling issues but apparently I forgot one. Fixed it just now, available in a next beta I provide soon. As for the animating disc art, there's a setting for the animated discart in viewsettings, if that's disabled it also won't be animated in the info dialog. 1
saitoh183 137 Posted December 10, 2014 Posted December 10, 2014 I just noticed that every few tile art rotation the following happens: All the MBS tiles will change to music art. Then they all change back to there respective art. I captured the log and it happens when this part appears: 10:38:15 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID : 10:38:15 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Resetting MB3.Background.Item.FanArt 10:38:21 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID : 10:38:21 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Resetting MB3.Background.Item.FanArt 10:38:25 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Music -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=200bc10e3e609981cd30b362b466eefb&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper] error occurred: 'SkinHelperThread' object has no attribute 'doDebugLog' 10:38:26 T:5268 NOTICE: Previous line repeats 1892 times. 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Movies and Series] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=c827f6752c5c820e5a98c8191ad4f9bf&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Others -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=c827f6752c5c820e5a98c8191ad4f9bf&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Photos] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=c827f6752c5c820e5a98c8191ad4f9bf&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Others -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=c827f6752c5c820e5a98c8191ad4f9bf&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Other] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=c827f6752c5c820e5a98c8191ad4f9bf&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Others -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=c827f6752c5c820e5a98c8191ad4f9bf&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Movies and Series] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=da35a92fbb4eea6743cf0901d1df901e&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Playlists -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=da35a92fbb4eea6743cf0901d1df901e&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper] error occurred: 'SkinHelperThread' object has no attribute 'doDebugLog' 10:38:26 T:5268 NOTICE: Previous line repeats 136 times. 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Photos] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=da35a92fbb4eea6743cf0901d1df901e&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Playlists -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=da35a92fbb4eea6743cf0901d1df901e&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Other] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=da35a92fbb4eea6743cf0901d1df901e&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- Playlists -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=da35a92fbb4eea6743cf0901d1df901e&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Movies and Series] 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=4c836f8411cc39bf311d5267feb5c58f&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:26 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- TV shows -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=4c836f8411cc39bf311d5267feb5c58f&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper] error occurred: 'SkinHelperThread' object has no attribute 'doDebugLog' 10:38:27 T:5268 NOTICE: Previous line repeats 258 times. 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Photos] 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=4c836f8411cc39bf311d5267feb5c58f&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- TV shows -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=4c836f8411cc39bf311d5267feb5c58f&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Other] 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=4c836f8411cc39bf311d5267feb5c58f&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- TV shows -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=4c836f8411cc39bf311d5267feb5c58f&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Movies and Series] 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=313559b47cdde5ed41463c277ebebecf&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- UFC -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=313559b47cdde5ed41463c277ebebecf&IncludeItemTypes=Movie,Series,MusicVideo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper] error occurred: 'SkinHelperThread' object has no attribute 'doDebugLog' 10:38:27 T:5268 NOTICE: Previous line repeats 17 times. 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Photos] 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=313559b47cdde5ed41463c277ebebecf&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- UFC -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?Limit=20&SortOrder=Descending&ParentId=313559b47cdde5ed41463c277ebebecf&IncludeItemTypes=Photo&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper get Collection Images Other] 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> == ENTER: getURL == 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DOWNLOAD_URL = http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=313559b47cdde5ed41463c277ebebecf&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved UserID : f6c51e6fd330e59d16f4cc52886702e1UserName: Saitoh 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> DownloadUtils -> Returning saved AccessToken for user : Saitoh token: 7381e220b9134edeaac03b6f44b6c5d6 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> Authentication Header : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C DownloadUtils -> HEADERS : {'Accept-Charset': 'UTF-8,*', 'Accept-encoding': 'gzip', 'Authorization': 'MediaBrowser UserId="f6c51e6fd330e59d16f4cc52886702e1",Client="XBMC",Device="Downstairs",DeviceId="5A6AC675126645FDB06493CC4BB1BFE6",Version="0.9.732"', 'X-MediaBrowser-Token': '7381e220b9134edeaac03b6f44b6c5d6'} 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> [MB3 SkinHelper COLLECTION] -- UFC -- http://192.168.13.198:8096/mediabrowser/Users/f6c51e6fd330e59d16f4cc52886702e1/items?&SortOrder=Descending&ParentId=313559b47cdde5ed41463c277ebebecf&IncludeItemTypes=MusicArtist,MusicAlbum,Audio&Fields=ParentId,Overview&SortOrder=Descending&Recursive=true&CollapseBoxSetItems=false&format=json 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Anime 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Collections 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Kids-Movies 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Kids-TV 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Movies 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Music 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Others 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: Playlists 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: TV shows 10:38:27 T:5268 NOTICE: XBMB3C SkinHelperThread -> set backgroundlink for: UFC 10:38:27 T:3568 NOTICE: Thread JobWorker start, auto delete: true 10:38:28 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID : 10:38:28 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Resetting MB3.Background.Item.FanArt 10:38:28 T:1708 NOTICE: Thread FileCache start, auto delete: false 10:38:28 T:4520 NOTICE: Thread JobWorker start, auto delete: true 10:38:28 T:4876 NOTICE: Thread FileCache start, auto delete: false 10:38:34 T:4296 NOTICE: Previous line repeats 1 times. 10:38:34 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID : 10:38:34 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Resetting MB3.Background.Item.FanArt 10:38:40 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink ItemGUID : 10:38:40 T:4296 NOTICE: XBMB3C BackgroundRotationThread -> setItemBackgroundLink Resetting MB3.Background.Item.FanArt Full log: https://www.dropbox.com/s/ckl5hu1u0q9rq02/kodi.log?dl=0 (sorry log is to many lines for paste website)
marcelveldt 736 Posted December 10, 2014 Author Posted December 10, 2014 I just noticed that every few tile art rotation the following happens: All the MBS tiles will change to music art. Then they all change back to there respective art. I captured the log and it happens when this part appears: Full log: https://www.dropbox.com/s/ckl5hu1u0q9rq02/kodi.log?dl=0 (sorry log is to many lines for paste website) Hmm, this looks likes something's wrong with the latest mb3 addon version... I'll check it out for you, in the meanwhile can you revert to previous version of the mediabrowser addon ?
saitoh183 137 Posted December 10, 2014 Posted December 10, 2014 Hmm, this looks likes something's wrong with the latest mb3 addon version... I'll check it out for you, in the meanwhile can you revert to previous version of the mediabrowser addon ? This has been happening since 728...i can live with it for now cuz reverting back to older builds is kind of a hassle
e123enitan 276 Posted December 10, 2014 Posted December 10, 2014 (edited) Hmm, I think I understood your question not good enough. I think by genres you mean your MB3 collections that you've set up. Well this is in fact possible as you want it. Go to the skin settings --> configure menu items Press the add button Go to MediaBrowser collections Here you will see your mediabrowser collections, you can add a tile for every collection you have. --> the tile image will only show images from that particular collection --> if you also want a widget for that collection tile, also press "select widget" --> custom collection widget Thanks I do as you have suggested, another question In MB3 server, I created a library folder under Home Video -the folder contains (vidoe mkv, poster and backdrop) in Titan- I configured home video menu but there was no rotations, but the backdrop is populating from movies library, how is that possible I thought the logic is backdrop is specific to each menu category since Home video library is seperate movies library folder in serve how could this have happen, am doing something wrong? Thanks for your support Edited December 10, 2014 by e123enitan
marcelveldt 736 Posted December 10, 2014 Author Posted December 10, 2014 Thanks I do as you have suggested, another question In MB3 server, I created a library folder under Home Video -the folder contains (vidoe mkv, poster and backdrop) in Titan- I configured home video menu but there was no rotations, but the backdrop is populating from movies library, how is that possible I thought the logic is backdrop is specific to each menu category since Home video library is seperate movies library folder in serve how could this have happen, am doing something wrong? Thanks for your support If I recall correctly only music, musicvideos, movies and tvshows backdrops are used to generate the images... So no home videos. I can take a look at the addon's code to check if this can be fixed... For the time beiing you can maybe specify movies as the content-type in the MB3 server ? 1
marcelveldt 736 Posted December 10, 2014 Author Posted December 10, 2014 (edited) I just pushed another beta version of the skin to the beta repo Version 2.2.5 Gotham Version 3.2.5 Helix Various fixes: - fixes for onscreen keyboard in helix - fixes for codecinfo tags - some more alignment fixes - compressed images for smaller skin size And two new features: 1. Touchscreen support --> enable it in the skinsettings --> first version so bugs to be expected (feedback welcome!) 2. Support for Smart Widgets (beta addon) --> widgets that present content based on history/behaviour etc, really cool! --> look at: http://forum.kodi.tv/showthread.php?tid=210707 --> please note that the smart movies/tvshows widgets are not available for MB3 mode of the skin Edited December 10, 2014 by marcelveldt 1
saitoh183 137 Posted December 10, 2014 Posted December 10, 2014 And two new features: 1. Touchscreen support --> enable it in the skinsettings --> first version so bugs to be expected (feedback welcome!) Will test this out on my tablet tonight for you
e123enitan 276 Posted December 10, 2014 Posted December 10, 2014 If I recall correctly only music, musicvideos, movies and tvshows backdrops are used to generate the images... So no home videos. I can take a look at the addon's code to check if this can be fixed... For the time beiing you can maybe specify movies as the content-type in the MB3 server ? You're so responsive, dam men I love you- I will move file to movies folder, hope it won't conflict with the backdrops from Genre's.Speaking of Genres, I think this would be great a option for users if included in all facets as mentioned below, whyFor instance I have movies library of over 2000+Initially I created a folder in server named movies, Titan-movies menu, this works finebut:loading or fetching movies info time takes too long, once a movie played, it takes equal time to reload, which Genre's resolve, instead of unwinding 2000+ movies, it just default to 22 categoriesalso searching for a specific movies can be challenging-which Genre's resolved coz I could narrow/drill down by Category-with respect to my guest request, or users of my server who only wish to watch specific group of movies, this difficult as I have to create a new folder for each purpose, maintenance efforts is in efficient and effective.Suggestions: On the server side Under user profile-additional 3 tap next to library for Genre's movies, music and TV shows One can easily provide access to specific movie category thus elevating the need for creating additional folder User can manipulate Genre's as they which in metadata which should auto add to Genre's list Speed of response to several guest needs would be fast, as it would just take check/unchecked grouping The data/info are currently available in all facets (server, addon, skin) it just a matter of manipulating the system to accommodate these needs Suggestions: On the Titan side Titan already have the ability to create menu for Genre's, (I have tried and is working fine-love it) just need fixing rotations on the menu, and backdropsNot a simple as you thought, agreed but you guys are skilful and can be done with timeMy 2 cent contribution, hope it make sense! Cheers Cheers
shaefurr 1340 Posted December 11, 2014 Posted December 11, 2014 Not to ruin the theme or anything, but if you replace the sounds with those from Steam BPM, its just like they were made for each other. (dont mind steam taking forever to open apparently it had an update). Not saying you should do this, just wanted to show how well they pair together.
marcelveldt 736 Posted December 11, 2014 Author Posted December 11, 2014 Not to ruin the theme or anything, but if you replace the sounds with those from Steam BPM, its just like they were made for each other. (dont mind steam taking forever to open apparently it had an update). Not saying you should do this, just wanted to show how well they pair together. Are these sounds copyright free ? I can provide muliple soundthemes with the skin, just like I did with the fonts and the theme. Must be sure that stuff is free of any copyrights because the skin is in official repo.
shaefurr 1340 Posted December 11, 2014 Posted December 11, 2014 Are these sounds copyright free ? I can provide muliple soundthemes with the skin, just like I did with the fonts and the theme. Must be sure that stuff is free of any copyrights because the skin is in official repo. I have no idea, ill read through their legal info to see if we can use them
marcelveldt 736 Posted December 11, 2014 Author Posted December 11, 2014 I have no idea, ill read through their legal info to see if we can use them Ok, thanks
e123enitan 276 Posted December 11, 2014 Posted December 11, 2014 (edited) Hmm, I think I understood your question not good enough. I think by genres you mean your MB3 collections that you've set up. Well this is in fact possible as you want it. Go to the skin settings --> configure menu items Press the add button Go to MediaBrowser collections Here you will see your mediabrowser collections, you can add a tile for every collection you have. --> the tile image will only show images from that particular collection --> if you also want a widget for that collection tile, also press "select widget" --> custom collection widget Good day Marcel -Genres menu backdrops rotation works for Win7 not for andriod box, both system are set up identical i.e. on addon and titan skin, any reasons why this could have happen? I will post a log latter for a review both systems and something would stand out that may have caused Andriod not to backdrop. Also since backdrop works for Genres-proves my earlier point, hence could you please look into why the menu rotations is not and make it work Thanks for your help Edited December 11, 2014 by e123enitan
