Hello, When you have a chance can you take a look at my log?
It freaked when I was messing with the skins preffrences.
When it starts to build it warns Unable to Build Menu.
I would have installed log uploader but not fast enough for the popup..
Thanks!
Can you please enable script.skinshortcuts own debug logging, in addition to Kodi's - System > Add-Ons > Enabled Add-Ons > Helper Add-Ons > Skin Shortcuts > Configure, then check "Enable debug logging". Thanks.
(Edit: or manually install XBMC Log Uploader from System > Add-Ons - when that is installed, skin shortcuts will take care of enabling all necessary debug logging, recreating the error, disabling debug logging, and then offer to upload a debug log when an error building the menu occurs)
Edited by unfleshed
marcelveldt
still happening. After i updated i noticed the error happened a few seconds after starting kodi.
http://tny.cz/59e51f54
I noticed in that log that there was a error about favorites.xml could not be found, so i go the one from my previous install and remove the content and left it with blank data...jsut the favorite tags. Then i started kodi and the error too k much long er to start
https://www.dropbox.com/s/8vypkqhe8unj5a2/kodi.log?dl=0
I will look into it further tomorrow as tonight I don't have much time.
Is the error occurring after starting Kodi/XBMC (from a running computer) OR does it auto start on windows startup ?
In my case I had the same issue with my HTTPC's starting up too fast with SSD while the networkconnection was not available yet, causing errors in my various addons, like PVR and mediabrowser... After putting a small delay in the startup this was fixed.
saitoh183
already started machine
saitoh183
Handler for Request not found:
Request.HttpMethod: GET
Request.PathInfo: /Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/10000/10000/0
Request.QueryString:
Request.RawUrl: /mediabrowser/Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/10000/10000/0
Request.PathInfo: /Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/1920/1080/0
Request.RawUrl: /mediabrowser/Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/1920/1080/0
marcelveldt
OK, please try again with new updated skin (v.2.1.16)  and helperservice (v.1.2.3)
Let me know if everything is working fine.
If you still have the error on startup, I guess it's caused by the xbmb3c addon but I'll help you to fix that.
Most important to know is if your images (tiles) are all working good now.
Edited by marcelveldt
saitoh183
OK, please try again with new updated skin (v.2.1.6)  and helperservice (v.1.2.3)
Updating gotham right now...will tell you in a few minutes
marcelveldt
OK, great. Just a little heads up about an issue I just discovered.
You have to restart xbmc after installing the skin's update else you'll get no tiles on the home screen...
Fixed it allready but if you've allready downloaded the 2.1.6 version you'll notice the error  :-)
dark_slayer
Nice skin. I'm wondering what artwork it is trying to use for the native "i" info screen as the AR doesn't match Poster dimensions
54614972e78d6_ScreenShot20141110at52146P
saitoh183
16:16:35 T:5744   ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://192.168.13.190:8095/mediabrowser/Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/1920/1080/0?
16:16:35 T:5744   ERROR: Previous line repeats 1 times.
16:16:35 T:5744   ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
16:16:35 T:5744  NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
16:16:35 T:5744   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
16:16:35 T:5744   ERROR: XFILE::CHTTPDirectory::GetDirectory - Unable to get http directory
16:16:35 T:5744   ERROR: XFILE::CDirectory::GetDirectory - Error getting http://192.168.13.190:8095/mediabrowser/Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/1920/1080/0/?
16:16:35 T:6512  NOTICE: Thread FileCache start, auto delete: false
16:16:35 T:5744   ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://192.168.13.190:8095/mediabrowser/Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
16:16:35 T:6480  NOTICE: Thread FileCache start, auto delete: false
Here is a full log
https://db.tt/wfLO1PR0
marcelveldt
Here is a full log
Those errors are stating that the images cannot be downloaded from the MB3 server.
Is everything working okay ?
saitoh183
working on the MBS server...yes...but could it be a cache corruptions?
Like the error comes and goes so the tile might be blank for a bit then show a images, then when the timer ends and its switches, it goes blank and so on
marcelveldt
Yes, that might be it... some cache corruption or something.
What happens if you open the url in your browser ?
or
http://192.168.13.190:8095/mediabrowser/Items/da777e188bdc760985d7b138f62d0b82/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/10000/10000/0?
marcelveldt
Yeah, that was an error in conjuction with xbmb3c addon, is fixed in 2.1.18 release that's now on the xbmb3c repo..
marcelveldt
OK, you are indeed having server problems.I think that if you go to your movie collection in xbmc that you'll be missing a lot of artwork there too...
Maybe one of the server devs is reading this but I suggest you to report the problem in the server area of the forum.
marcelveldt
@Luke, do you have any idea what is going on here if you see the log results posted by user saitoh183 ?
Forgive me if I'm wrong but I'm starting to think it's an issue serverside...
saitoh183
I havent noticed any missing artwork.but would i need to redo my cache only or imagebyname also. Also to redo them, do i just need to stop the server and rename folders?
marcelveldt
In fact I really don't have a clue :-)
Just to be sure:  The images are NOT displayed in the tiles ?
Or are they displayed but you only get the error ?
saitoh183
Not displayed in tiles or background, when the start to work i see both. Yesterday i restored my server giving the Timeout problems  to a clean installation. i will test it out today with a fresh MB and fresh DB/Cache..etc and post back
marcelveldt
Ok, great. Let's hope your issues are resolved than!
marcelveldt
@@marcelveldt
I'm a fellow early adopter of WMC/MediaBrowser and have run the gamut in trying to find the holy grail of LiveTV/downloads/DVR. I've yet to find a solution that will finally allow me to completely ditch Windows but this skin has me closer than ever. Great work!
I am having an issue with the live tiles. Currently, they are only showing the default images (Avatar, Breaking Bad) Is there a setting that I am missing?
Two request:
1- the Latest Movies widget on the home screen shows the movies thumb and if that is not available displays the movies background with a title overlay. Is it possible to carry this format over to the Recently Added Episodes widget? Currently this displays the episode image with a title overlay and I think the series thumb image would be more visually pleasing.
2- the Recently Added Albums widget displays the album cover art with the album name overlayed. Unfortunately, the images are landscape thumbnail sized and not the proper aspect ratio for album art. Any chance of correcting this and removing the album title overlay?
Again, thank you for this wonderful addition to the community!
Hi Danofun,
Thanks for the feedback, yes I'm also a longtime big fan of MediaBrowser and designed my skin to give the best features out of it. Since I replaced my WMC setups (which I had for many years) I never looked back. The MB Classic is great but WMC is just a dead product (my personal opinion)...
As for your questions/requests:
0: I assume you're using the skin with MediaBrowser. Did you install and configure the XBMB3c addon ?
Also, after installation a reboot is required for the images to load (or just wait one hour or so).
If you have configured the XBMB3c addon and you selected "Mediabrowser Mode" in the skin it should all work out of the box without any further hassle.
1: I know that most users preference is to show the episode thumb for the recently added episodes. Off course I can also show the series thumb, it's just a personal preference which one you like best. What I will do is make it a selectable option. Will do this within a few days...
2: Actually I configured things that the Artist fanart is always preferred, it will just fallback to album covers if no fanart is available. Actually my experience with the MB3 music support is that is a bit behind, I strongly suggest you to use normal XBMC libraries for music as it just works much better. Offcourse we have to respect the fact that Music support isn't very long ago added to MB3 so it still needs some improvements which will come (I'm sure) along the way.
To get good working artwork, genres and other music info you'd better use XBMC for that. The skin will let you do that, just don't select Mediabrowser as the source for Music and add your music shares/folders to XBC and let it scan to library.
I'll let you know as soon as I have optimized the skin setings to make the thumbs selection user configurable.
@@marcelveldt
Two request:
saitoh183
So here is want i got so far
Setup: MBS 3.0.5424.1, XBMB3C 9.0.703 , Titan gotham and helix ( x.1.20)
All main Live tiles seems to work without error (TV shows , movies and Anime)
When i added a live tile for Favorite Shows on gotham, it seems to work...but... When i add the live tile in Helix for favorite shows and both XBMC's are running, the tile starts to get errors on both machines. Now i get favorite tiles error all the time in gotham. I redid the library from scratch in MBS. I dont know if its a coincidence that the tiles for favorite shows started failing after i added it to helix.
Here is what i found in the xbmb3c log
21:34:14 T:4992   ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for http://192.168.13.198:8096/mediabrowser/Items/c9b5eb33313f76b065746f128de40e31/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
In mbs log at the same time:
2014-11-13 21:35:43.9789 Error - DtoUtils: ServiceBase<TRequest>::Service Exception
	Parenthood (2010) does not have an image of type Backdrop
	MediaBrowser.Common.Extensions.ResourceNotFoundException
	   at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, IHasImages item, Boolean isHeadRequest)
	   at MediaBrowser.Api.Images.ImageService.Head(GetItemImage request)
	   at lambda_method(Closure , Object , Object )
	   at ServiceStack.Host.ServiceRunner`1.Execute(IRequest request, Object instance, TRequest requestDto)
2014-11-13 21:35:43.9789 Error - HttpServer: Error processing request for /mediabrowser/Items/1bc5a219e4a9d05a3160d1ab680e568e/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
	ServiceStack.HttpError
	No Stack Trace Available
2014-11-13 21:35:43.9789 Error - NotFoundHttpHandler: 192.168.13.198:8096 Request not found: /mediabrowser/Items/1bc5a219e4a9d05a3160d1ab680e568e/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
2014-11-13 21:35:43.9849 Error - ListenerResponse: Could not WriteTextToResponse: Bytes to be written to the stream exceed the Content-Length bytes size specified.
	System.Net.ProtocolViolationException
	   at System.Net.HttpResponseStream.Write(Byte[] buffer, Int32 offset, Int32 size)
	   at ServiceStack.Host.HttpListener.ListenerResponse.Write(String text)
2014-11-13 21:35:43.9849 Error - HttpAsyncTaskHandler: Error occured while Processing Request: Bytes to be written to the stream exceed the Content-Length bytes size specified.
	   at ServiceStack.Formats.HtmlFormat.SerializeToStream(IRequest request, Object response, IResponse httpRes)
	   at ServiceStack.HttpResponseExtensionsInternal.WriteErrorToResponse(IResponse httpRes, IRequest httpReq, String contentType, String operationName, String errorMessage, Exception ex, Int32 statusCode)
	   at ServiceStack.ServiceStackHost.OnUncaughtException(IRequest httpReq, IResponse httpRes, String operationName, Exception ex)
	   at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse response, Object result, ResponseSerializerDelegate defaultAction, IRequest request, Byte[] bodyPrefix, Byte[] bodySuffix)
	   at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse httpRes, IRequest httpReq, Object result, Byte[] bodyPrefix, Byte[] bodySuffix)
	   at ServiceStack.HttpResponseExtensionsInternal.WriteToResponse(IResponse httpRes, IRequest httpReq, Object result)
	   at ServiceStack.Host.RestHandler.<>c__DisplayClass5.<ProcessRequestAsync>b__0(Object response)
	   at ServiceStack.Host.Handlers.ServiceStackHandlerBase.HandleResponse(Object response, Func`2 callback, Func`2 errorCallback)
2014-11-13 21:35:43.9849 Debug - HttpServer: HTTP Response 500 to 192.168.13.102. Response time: 1.9976 ms.
	Url: http://192.168.13.198:8096/mediabrowser/Items/1bc5a219e4a9d05a3160d1ab680e568e/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
2014-11-13 21:35:43.9849 Debug - HttpServer: HTTP GET http://192.168.13.198:8096/mediabrowser/Items/1bc5a219e4a9d05a3160d1ab680e568e/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
	Ip: 192.168.13.102:61404. Headers: Accept=*/*,Accept-Charset=UTF-8,*;q=0.8,Host=192.168.13.198:8096,Range=bytes=0-0,User-Agent=XBMC/13.2 Git:20140817-0f3db05 (Windows NT 6.1;WOW64;Win64;x64; http://xbmc.org)
2014-11-13 21:35:44.0009 Error - DtoUtils: ServiceBase<TRequest>::Service Exception
	   at MediaBrowser.Api.Images.ImageService.Get(GetItemImage request)
2014-11-13 21:35:44.0009 Error - HttpServer: Error processing request for /mediabrowser/Items/1bc5a219e4a9d05a3160d1ab680e568e/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
2014-11-13 21:35:44.0009 Error - NotFoundHttpHandler: 192.168.13.198:8096 Request not found: /mediabrowser/Items/1bc5a219e4a9d05a3160d1ab680e568e/Images/Backdrop/2/e3ab56fe27d389446754d0fb04910a34/original/620/350/0?
2014-11-13 21:35:44.0009 Debug - HttpServer: HTTP Response 404 to 192.168.13.102. Response time: 1.0004 ms.
This portion says there is no backdrop but there is one when i look in metadata manager
marcelveldt
What do you have as client names in both xbmc clients ?
Make sure they're different... Maybe xbmb3c/mb3 can't handle if two clients with same name want to connect...
saitoh183
Both clients are running under the same mbs account. But the problem is there even if just one client is running now. Both clients need to be under the same account so watched status/resumes can follow. The problem is also there if i run both clients but one client is point to my mbs server on ip 192.163.13.190 and other pointing to 192.168.13.198 (client giving error). In this case both username are different. Could being connected in the webbrowser with the same username as xbmc cause this? This error is only in titan since it is tile releated...but why just the Favorite Shows or movies are affected and not the other tiles
Edited by saitoh183
marcelveldt
I don't mean the MBS username... Your XBMC has an instance name that should be different on all clients...
I believe the setting for this is somewhere in Settings --> System
EDIT: It's in settings --> Network --> device name
Guest
