GrimReaper 4896 Posted December 3, 2020 Posted December 3, 2020 Where do Device icons/images/thumbnails come from? I'd assume they get pulled of the net, as they loook like this whenever my server's offline (which is 6+ months a year). Which is just... NOT visually appealing. Could they be stored and propagated from the server? Thanks
Luke 42241 Posted December 3, 2020 Posted December 3, 2020 Hi, yes this is something that needs to be improved. thanks for the feedback. 1
GrimReaper 4896 Posted October 17, 2021 Author Posted October 17, 2021 On 12/3/2020 at 7:57 PM, Luke said: Hi, yes this is something that needs to be improved. thanks for the feedback. Still seeing this in beta .14, makes it even more painfully obvious with the new Now Playing session windows. Is there anywhere I could insert those images myself so they get pulled? It's 5-6 image types, after all, is it really out of reach to make them local, they are quite a downer. @Happy2Play, can anything be done in CSS to replace these, maybe?
Happy2Play 9811 Posted October 17, 2021 Posted October 17, 2021 4 minutes ago, GrimReaper said: Still seeing this in beta .14, makes it even more painfully obvious with the new Now Playing session windows. Is there anywhere I could insert those images myself so they get pulled? It's 5-6 image types, after all, is it really out of reach to make them local, they are quite a downer. @Happy2Play, can anything be done in CSS to replace these, maybe? Yes these are a online resource via github. Looks like we can target the device id for the Now Playing section for you to potentially target your own images, but not currently seeing a way for Device page. You would have to place these images in Emby system folder with every update, to work with Now Playing. Should be able to provide you an example shortly. Or @Luke needs to add Edit Image to these to allow them to be stored locally via \library or \metadata. 1
Luke 42241 Posted October 18, 2021 Posted October 18, 2021 It's on my to do list to rework this. Thanks.
Happy2Play 9811 Posted October 18, 2021 Posted October 18, 2021 I have not tested with your versions of 4.5.2.0. Hmm 4.7 it can be done for Now Playing, and 4.6 the opposite not sure it the same device sessionid is used always uses but my browser is currently always using same sessionid.. But here is an example from 4.6. I put image in Emby-Server\system\dashboard-ui\css folder. So images would need put in folder on every update and hope code doesn't change. As we already know code will change from 4.6 to 4.7. /*Devices*/ [data-id="c6e11832-f8a1-47ca-996f-2318ac1aacfa"] .cardImageContainer { background-image: url(/web/css/chrome_logo.png) !important; } /*Active Devices*/ #sessionbff43260959eddc721b42a66f1dda24e img { content: url(/web/css/chrome_logo.png); } 1
GrimReaper 4896 Posted October 18, 2021 Author Posted October 18, 2021 34 minutes ago, Happy2Play said: I have not tested with your versions of 4.5.2.0. That was December 2020, when the request originated. Currently on 4.6.4.0 stable and 4.7.0.14 beta. If I understood you correctly, above CSS will work for 4.6.4 by placing all image types in css folder and then linking each device id to correct png? Is that data-id device id?
Happy2Play 9811 Posted October 18, 2021 Posted October 18, 2021 14 minutes ago, GrimReaper said: If I understood you correctly, above CSS will work for 4.6.4 by placing all image types in css folder and then linking each device id to correct png? Correct or we and target any folder within dashboard-ui as it is the within the webservers access. 12 minutes ago, GrimReaper said: Is that data-id device id? Yes so you can click on the device and get the id from the url.
Happy2Play 9811 Posted October 18, 2021 Posted October 18, 2021 But assuming you want the image Emby uses you can get them all from here. https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices 1
GrimReaper 4896 Posted October 18, 2021 Author Posted October 18, 2021 1 minute ago, Happy2Play said: But assuming you want the image Emby uses you can get them all from here. https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices Thanks, grabbed them all yesterday after your screenshot.
Happy2Play 9811 Posted October 18, 2021 Posted October 18, 2021 Same concept for 4.7, but only see a way for Dashboard Now Playing. [data-id="5b61b3c3-dfe7-4ea5-ad32-0e52072008aa"] .activeSession-deviceimage-bg-square { background-image: url(/web/css/chrome_logo.png) !important; } Don't see a way for Devices as they are just items in a virtual scroller with no way to target them, that I can see right now..
GrimReaper 4896 Posted October 19, 2021 Author Posted October 19, 2021 34 minutes ago, Happy2Play said: Same concept for 4.7, but only see a way for Dashboard Now Playing. [data-id="5b61b3c3-dfe7-4ea5-ad32-0e52072008aa"] .activeSession-deviceimage-bg-square { background-image: url(/web/css/chrome_logo.png) !important; } Don't see a way for Devices as they are just items in a virtual scroller with no way to target them, that I can see right now.. That will do, as Active Devices/Now Playing IS where it bothers me the most, Devices tab I practically almost never look at. Thanks, Happy, appreciate it.
Happy2Play 9811 Posted June 8, 2022 Posted June 8, 2022 I know it is the endless to do list but can we get these into the /metadata folder with a one time get from online? 1
Luke 42241 Posted June 8, 2022 Posted June 8, 2022 50 minutes ago, Happy2Play said: I know it is the endless to do list but can we get these into the /metadata folder with a one time get from online? Yes we can.
