bokonon 0 Posted December 3, 2020 Posted December 3, 2020 Audio was out of sync on the below file through fireTV, no transcoding: Quote Media Info Video Title4K HEVC CodecHEVC ProfileMain Level150 Resolution3840x2160 Aspect Ratio16:9 AnamorphicNo InterlacedNo Framerate23.976 Bitrate18,444 kbps Bit Depth8 bit Pixel Formatyuv420p Reference Frames1 Audio TitleEnglish DTS-HD MA 5.1 (Default) LanguageEnglish CodecDTS ProfileDTS-HD MA Layout5.1 Channels6 ch Sample Rate48,000 Hz Bit Depth24 bit DefaultYes Subtitle TitleEnglish (SUBRIP) LanguageEnglish CodecSUBRIP DefaultNo ForcedNo ExternalNo Subtitle TitleSpanish (PGSSUB) LanguageSpanish CodecPGSSUB DefaultNo ForcedNo ExternalNo Containermkv Path/volume1/video/TV/The Spanish Princess/The.Spanish.Princess.S01.2160p.Stan.WEB-DL.DTS-HD.MA.5.1.HEVC-TrollUHD[rartv]/The.Spanish.Princess.S01E01.2160p.Stan.WEB-DL.DTS-HD.MA.5.1.HEVC-TrollUHD.mkv Size7306MB Coudln't replicate the issue on my PC on MPC-HC The web-player won't play it at all - no compatible streams error Any ideas?
ebr 16338 Posted December 3, 2020 Posted December 3, 2020 The Fire does not support DTS-HD. Exactly how was the item playing?
bokonon 0 Posted December 4, 2020 Author Posted December 4, 2020 It was playing fine if that's what you mean. the only issue was the audio being OOS Interesting when I check 'playback correction' on the fire tv app the audio is in sync. What exactyl does this option do?
ebr 16338 Posted December 4, 2020 Posted December 4, 2020 2 hours ago, bokonon said: What exactyl does this option do? It depends on how the item was playing in the first place but it falls back to a different playback method. e.g. if direct playing, it will try a remux - if remuxing it will try a transcode.
