Solution PontusN 12 Posted December 3, 2020 Solution Posted December 3, 2020 (edited) Hi! Im trying to add a custom indicator overlay to my movies. I have added a hdtype_UHD.png file that I want to use, and CoverArt is trying to apply them but encounters an error as stated in the logs below. Permisions should not be an issue. EDIT: Solved! The image was too big. Max res is 236*354 (w*h) Spoiler 2020-12-03 13:43:03.877 Info HttpServer: HTTP Response 200 to 192.168.1.181. Time: 30ms. http://192.168.1.30:8096/emby/Items/36086/Images/Primary?maxHeight=354&maxWidth=236&tag=2e1916818cedbb53481b83648eb466fe&quality=90. ConnectionId: 0HM4NH3BFPI81 2020-12-03 13:43:03.882 Info CoverArt: image enhance of Men in Black 3 took 0.011 seconds. 2020-12-03 13:43:03.882 Error ImageProcessor: Error enhancing image *** Error Report *** Version: 4.5.2.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.8.0-7625-generic (buildd@lgw01-amd64-031) (gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #26~160338 Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'image') at SkiaSharp.SKCanvas.DrawImage(SKImage image, SKRect dest, SKPaint paint) at CoverArt.Skia.CAHelper.DrawImage(SKBitmap destination, SKBitmap source, Rectangle destinationRect, Rectangle sourceRect) at CoverArt.Skia.CoverArtBaseEnhancer.DrawOverlay(SKBitmap work, OverlayDefinition oDef, IEnumerable`1 imagePaths, Size imgSize, SKBitmap explicitImage) at CoverArt.Skia.CoverArtBaseEnhancer.ApplyOverlays(ProfileDefinition profile, BaseItem item, SKBitmap newImage, Size imgSize) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImage(SKBitmap originalImage, ProfileDefinition profile, String itemType, String frameType, BaseItem item, List`1 childImages) at CoverArt.Skia.CoverArtMovieEnhancer.EnhanceImageAsyncInternal(BaseItem item, SKBitmap originalImage, ImageType imageType, Int32 imageIndex) at CoverArt.Skia.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputPath, String outputPath, ImageType imageType, Int32 imageIndex) at CoverArt.Enhancers.CoverArtBaseEnhancer.EnhanceImageAsync(BaseItem item, String inputFile, String outputFile, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.ExecuteImageEnhancers(IEnumerable`1 imageEnhancers, String inputPath, String outputPath, BaseItem item, ImageType imageType, Int32 imageIndex) at Emby.Drawing.ImageProcessor.GetEnhancedImageInternal(String originalImagePath, BaseItem item, ImageType imageType, Int32 imageIndex, IImageEnhancer[] supportedEnhancers, String cacheGuid, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.GetEnhancedImage(ItemImageInfo image, Boolean inputImageSupportsTransparency, BaseItem item, Int32 imageIndex, IImageEnhancer[] enhancers, CancellationToken cancellationToken) Source: SkiaSharp TargetSite: Void DrawImage(SkiaSharp.SKImage, SkiaSharp.SKRect, SkiaSharp.SKPaint) embyserver.txt Edited December 3, 2020 by PontusN
Luke 42246 Posted December 5, 2020 Posted December 5, 2020 Hi there, glad to hear you figured it out.
