deanDemo 1 Posted November 30, 2020 Posted November 30, 2020 Hi, I've done some reading through the threads and from what I can see (and the settings on my server) IMDB ins not used for metadata scraping. In my case, I have it set to TheMovieDb only and in most cases, this score varies significantly from IMDB. But, as one of the main sort options, we have "sort by IMDB rating" which doesn't make sense if the score on the poster is actually from a different source. Have I got this all correct? I assume that there is no way to change the setting to fetch the info from IMDB instead?
Abobader 3485 Posted November 30, 2020 Posted November 30, 2020 Hello deanDemo, Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: How to Report a Problem Thank you. Emby Team
deanDemo 1 Posted November 30, 2020 Author Posted November 30, 2020 2 hours ago, PenkethBoy said: imdb scores can come from omdb And how do I apply them to the movies? The options are only TheMovieDb and The Open Movie Database
deanDemo 1 Posted November 30, 2020 Author Posted November 30, 2020 5 minutes ago, PenkethBoy said: they get add if they exist on omdb Ah, ok. So if I understand you correctly - if I select the Open Movie Database instead of TheMovieDb, the scores will be the same as imdb?
PenkethBoy 2068 Posted November 30, 2020 Posted November 30, 2020 whatever is on omdb - which you can update if wrong 1
