Dlna with philips 49pus7809
eddedrukker
I can't figure it out, i see the server but everytime when i want to play a file the tv says not support, how do i get it working on the new philips uhd tv?
I've had nothing but trouble with my Philips. I don't think their DLNA implementation is very good. Maybe the devs have some help.
  • 2 weeks later...
eddedrukker
So this not goin to work on this brand tv?
are you using a custom profile or the default? Also, what file formats are you trying?
Edited by nirvmedia
eddedrukker
Im using the default and the files are mkv
7illusions
First thing first, can the tv play mkv files?
Can you post a server log when you try to play?
