rb9999 6 Posted November 28, 2020 Posted November 28, 2020 I saw that this feature was added but I cannot find it anywhere in the settings. I am using a 2019 Nvidia Shield Pro. I am running app version 1.8.54g and server 4.5.2.0. How do I actually change the subtitle offsets in the interface?
GrimReaper 4902 Posted November 28, 2020 Posted November 28, 2020 (edited) 1 hour ago, rb9999 said: I saw that this feature was added but I cannot find it anywhere in the settings. I am using a 2019 Nvidia Shield Pro. I am running app version 1.8.54g and server 4.5.2.0. How do I actually change the subtitle offsets in the interface? Unfortunately, in the official ATV app - you can't. You can sideload vanilla Android app if you need to profit from that function, but that road has its own set of issues, so it basically bolis down to what does take preference for your use. Anyway, support for subs offset should be coming soon, hopefully. Edit: And it's been coming... and coming... and coming... for some time now. Edited November 28, 2020 by GrimReaper76
edd-- 2 Posted December 7, 2020 Posted December 7, 2020 +1 on this request, this would make the experience perfect ! Thanks !
jkramer 12 Posted December 8, 2020 Posted December 8, 2020 (edited) I just did this on my Shield. After I selected a subtitle during the movie a checkbox then appears below the selection called "Position". This must be a new feature, didn't see it a couple days ago. [edit] oops, I was thinking position, not time. Edited December 8, 2020 by jkramer
KrisFriFly 0 Posted January 4, 2021 Posted January 4, 2021 I thought I was going crazy that this feature has been there, but apparently it hasnt. Any update on offset feature in Android TV/Google tv app?
CBers 7554 Posted January 4, 2021 Posted January 4, 2021 Subtitle offset (external subs only) is available in the current beta. You can download and sideload it from here. 1
KrisFriFly 0 Posted April 11, 2021 Posted April 11, 2021 On 1/4/2021 at 2:18 PM, CBers said: Subtitle offset (external subs only) is available in the current beta. You can download and sideload it from here. Thanks. Any idea when it will be updated in the Google app store app? Such a cool feature I'm missing it big time
