GiGo 108 Posted November 27, 2020 Posted November 27, 2020 I re-installed emby a couple of weeks ago after an issue with my TV Shows folder, I now have an issue with Movies, all current movies are there, ie the ones that were added before I re-installed, I've since added a few more movies and none of them have been added, Auto Organize has done it's thing and added them to the folder, although an observation was made that once I selected Media Type as Movie it wasn't recoginising the movie title, the title field was blank, so I manually typed in the title and search came up with it and then it moved the file to the Movie Folder. I've tried deleting the Library and re-adding it, no luck I've moved the folder, no luck I've done multiple re-scans, no luck Any ideas what I can do next? Server log attached, TIA EDIT: Just to add when I before I re-installed Emby I deleted the entire Emby folder on my NAS. embyserver.txt
GiGo 108 Posted November 27, 2020 Author Posted November 27, 2020 Just now, PenkethBoy said: your library type is movies? Yes, type is set to Movies
PenkethBoy 2068 Posted November 27, 2020 Posted November 27, 2020 sounds like possibly a permissions issue - have you compared old and new movie folders - check the files as well have you looked for errors in the logs - turn debug on if not already
GiGo 108 Posted November 27, 2020 Author Posted November 27, 2020 5 minutes ago, PenkethBoy said: sounds like possibly a permissions issue - have you compared old and new movie folders - check the files as well have you looked for errors in the logs - turn debug on if not already Thanks for the feedback, I've turned on Debug, looking at my log I do see this; 2020-11-27 08:50:26.623 Error LibraryMonitor: Error in Directory watcher for: /volume1/Movies *** Error Report *** Version: 4.5.2.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 3.10.105 (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP Wed Jul 8 03:19:33 CST 2020 Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (8192) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. Source: TargetSite: No Stack Trace Available I'm not sure what to make of it as I get similar (or the same for my TV library, which works fine) 2020-11-27 08:50:26.623 Error LibraryMonitor: Error in Directory watcher for: /volume1/TV *** Error Report *** Version: 4.5.2.0 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 3.10.105 (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP Wed Jul 8 03:19:33 CST 2020 Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 4 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system System.IO.IOException: System.IO.IOException: The configured user limit (8192) on the number of inotify watches has been reached, or the operating system failed to allocate a required resource. Source: TargetSite: No Stack Trace Available
PenkethBoy 2068 Posted November 27, 2020 Posted November 27, 2020 search for inotify in this sub forum and you will find a long thread on it needs a small addition to the startup of the syno IIRC - basically you have too many files for the current default inotify setting
GiGo 108 Posted November 27, 2020 Author Posted November 27, 2020 21 minutes ago, PenkethBoy said: search for inotify in this sub forum and you will find a long thread on it needs a small addition to the startup of the syno IIRC - basically you have too many files for the current default inotify setting Thanks for the info, I've been reading thru the threads and it's going over my head at bit! Will keep reading to try and understand, thanks for input. 1
FrostByte 5454 Posted November 27, 2020 Posted November 27, 2020 Add a script to run at boot up to eliminate the watches error. There's another script you may need to run also. If it still doesn't work please post another log of you adding a movie, etc. and we can see what you get next. @cayars any luck getting something into the kb about the 2 inotify errors and Synology? Wait a couple minutes after you reboot and you can check to see if the allowed watches have increased by typing this into terminal cat /proc/sys/fs/inotify/max_user_watches
GiGo 108 Posted November 27, 2020 Author Posted November 27, 2020 13 minutes ago, FrostByte said: Add a script to run at boot up to eliminate the watches error. There's another script you may need to run also. If it still doesn't work please post another log of you adding a movie, etc. and we can see what you get next. @cayars any luck getting something into the kb about the 2 inotify errors and Synology? Wait a couple minutes after you reboot and you can check to see if the allowed watches have increased by typing this into terminal cat /proc/sys/fs/inotify/max_user_watches Thanks for the info, I figured that out earlier with the inotify thingy script, I have put it on boot up, and restarted the NAS, it now solves the inotify error, but I am still having the issue; Looking at my log; I can find the latest movies I've added, for example; The Italian Job (1969), it shows it in the log but I have Debug App listings next to a few entries, I have no knowledge on what I'm looking at, I've attached the latest log, but I assume this is not normal; 2020-11-27 10:12:36.709 Info Server: http/1.1 Response 200 to 192.168.68.136. Time: 3ms. http://192.168.68.3:8096/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=cd086d72-77bb-43f9-9d8a-f538cb09fe65&X-Emby-Client-Version=4.5.2.0 2020-11-27 10:12:38.534 Debug App: FolderImageProvider reports change to 426707 - /volume1/Movies/Mulan (2020) 2020-11-27 10:12:38.588 Debug App: Running FolderImageProvider for /volume1/Movies/Mulan (2020) 2020-11-27 10:12:38.604 Debug App: FolderImageProvider reports change to 426708 - /volume1/Movies/The Godfather- Part II (1974) 2020-11-27 10:12:38.604 Debug App: Running FolderImageProvider for /volume1/Movies/The Godfather- Part II (1974) 2020-11-27 10:12:38.717 Debug App: FolderImageProvider reports change to 426709 - /volume1/Movies/The Hungover Games (2014) 2020-11-27 10:12:38.717 Debug App: Running FolderImageProvider for /volume1/Movies/The Hungover Games (2014) 2020-11-27 10:12:38.719 Debug App: FolderImageProvider reports change to 426710 - /volume1/Movies/Saw 6 (2009) 2020-11-27 10:12:38.719 Debug App: Running FolderImageProvider for /volume1/Movies/Saw 6 (2009) 2020-11-27 10:12:38.727 Debug App: FolderImageProvider reports change to 426711 - /volume1/Movies/Guru (2007) 2020-11-27 10:12:38.727 Debug App: Running FolderImageProvider for /volume1/Movies/Guru (2007) 2020-11-27 10:12:38.729 Debug App: FolderImageProvider reports change to 426712 - /volume1/Movies/The Italian Job (1969) 2020-11-27 10:12:38.729 Debug App: Running FolderImageProvider for /volume1/Movies/The Italian Job (1969) 2020-11-27 10:12:38.731 Debug App: FolderImageProvider reports change to 426713 - /volume1/Movies/Casa De Mi Padre (2012) 2020-11-27 10:12:38.731 Debug App: Running FolderImageProvider for /volume1/Movies/Casa De Mi Padre (2012) 2020-11-27 10:12:38.733 Debug App: FolderImageProvider reports change to 426714 - /volume1/Movies/Kong Skull Island (2017) 2020-11-27 10:12:38.733 Debug App: Running FolderImageProvider for /volume1/Movies/Kong Skull Island (2017) 2020-11-27 10:12:38.736 Debug App: FolderImageProvider reports change to 426715 - /volume1/Movies/Ghost in the Shell- Stand Alone Complex (2002) 2020-11-27 10:12:38.736 Debug App: Running FolderImageProvider for /volume1/Movies/Ghost in the Shell- Stand Alone Complex (2002) 2020-11-27 10:12:38.738 Debug App: FolderImageProvider reports change to 426716 - /volume1/Movies/The Hitchhiker's Guide to the Galaxy (2005) 2020-11-27 10:12:38.738 Debug App: Running FolderImageProvider for /volume1/Movies/The Hitchhiker's Guide to the Galaxy (2005) 2020-11-27 10:12:38.740 Debug App: FolderImageProvider reports change to 426717 - /volume1/Movies/Contagion! The BBC Four Pandemic (2018) 2020-11-27 10:12:38.740 Debug App: Running FolderImageProvider for /volume1/Movies/Contagion! The BBC Four Pandemic (2018) 2020-11-27 10:12:38.742 Debug App: FolderImageProvider reports change to 426718 - /volume1/Movies/Star Wars Episode VII The Force Awakens (2015) 2020-11-27 10:12:38.742 Debug App: Running FolderImageProvider for /volume1/Movies/Star Wars Episode VII The Force Awakens (2015) 2020-11-27 10:12:38.744 Debug App: FolderImageProvider reports change to 426730 - /volume1/Movies/Star Wars Episode VII The Force Awakens (2015)/Subs 2020-11-27 10:12:38.744 Debug App: Running FolderImageProvider for /volume1/Movies/Star Wars Episode VII The Force Awakens (2015)/Subs 2020-11-27 10:12:38.747 Debug App: FolderImageProvider reports change to 426719 - /volume1/Movies/Regan (1974) 2020-11-27 10:12:38.747 Debug App: Running FolderImageProvider for /volume1/Movies/Regan (1974) 2020-11-27 10:12:38.749 Debug App: FolderImageProvider reports change to 426720 - /volume1/Movies/James Bond Collection 2020-11-27 10:12:38.750 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection 2020-11-27 10:12:38.756 Debug App: FolderImageProvider reports change to 426732 - /volume1/Movies/James Bond Collection/02 From Russia With Love (1963) 2020-11-27 10:12:38.757 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/02 From Russia With Love (1963) 2020-11-27 10:12:38.759 Debug App: FolderImageProvider reports change to 426733 - /volume1/Movies/James Bond Collection/01 Dr No (1962) 2020-11-27 10:12:38.759 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/01 Dr No (1962) 2020-11-27 10:12:38.762 Debug App: FolderImageProvider reports change to 426734 - /volume1/Movies/James Bond Collection/23 Skyfall (2012) 2020-11-27 10:12:38.762 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/23 Skyfall (2012) 2020-11-27 10:12:38.764 Debug App: FolderImageProvider reports change to 426735 - /volume1/Movies/James Bond Collection/09 The Man With The Golden Gun (1974) 2020-11-27 10:12:38.765 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/09 The Man With The Golden Gun (1974) 2020-11-27 10:12:38.767 Debug App: FolderImageProvider reports change to 426736 - /volume1/Movies/James Bond Collection/20 Die Another Day (2002) 2020-11-27 10:12:38.767 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/20 Die Another Day (2002) 2020-11-27 10:12:38.769 Debug App: FolderImageProvider reports change to 426737 - /volume1/Movies/James Bond Collection/16 Licence To Kill (1989) 2020-11-27 10:12:38.769 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/16 Licence To Kill (1989) 2020-11-27 10:12:38.773 Debug App: FolderImageProvider reports change to 426738 - /volume1/Movies/James Bond Collection/17 GoldenEye (1995) 2020-11-27 10:12:38.773 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/17 GoldenEye (1995) 2020-11-27 10:12:38.775 Debug App: FolderImageProvider reports change to 426739 - /volume1/Movies/James Bond Collection/15 The Living Daylights (1987) 2020-11-27 10:12:38.775 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/15 The Living Daylights (1987) 2020-11-27 10:12:38.777 Debug App: FolderImageProvider reports change to 426740 - /volume1/Movies/James Bond Collection/18 Tomorrow Never Dies (1997) 2020-11-27 10:12:38.778 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/18 Tomorrow Never Dies (1997) 2020-11-27 10:12:38.780 Debug App: FolderImageProvider reports change to 426741 - /volume1/Movies/James Bond Collection/10 The Spy Who Loved Me (1977) 2020-11-27 10:12:38.780 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/10 The Spy Who Loved Me (1977) 2020-11-27 10:12:38.782 Debug App: FolderImageProvider reports change to 426742 - /volume1/Movies/James Bond Collection/19 The World Is Not Enough (1999) 2020-11-27 10:12:38.782 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/19 The World Is Not Enough (1999) 2020-11-27 10:12:38.786 Debug App: FolderImageProvider reports change to 426743 - /volume1/Movies/James Bond Collection/04 Thunderball (1965) 2020-11-27 10:12:38.786 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/04 Thunderball (1965) 2020-11-27 10:12:38.788 Debug App: FolderImageProvider reports change to 426744 - /volume1/Movies/James Bond Collection/06 On Her Majestys Secret Service (1969) 2020-11-27 10:12:38.788 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/06 On Her Majestys Secret Service (1969) 2020-11-27 10:12:38.791 Debug App: FolderImageProvider reports change to 426745 - /volume1/Movies/James Bond Collection/14 A View To A Kill (1985) 2020-11-27 10:12:38.791 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/14 A View To A Kill (1985) 2020-11-27 10:12:38.794 Debug App: FolderImageProvider reports change to 426746 - /volume1/Movies/James Bond Collection/13 Octopussy (1983) 2020-11-27 10:12:38.794 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/13 Octopussy (1983) 2020-11-27 10:12:38.796 Debug App: FolderImageProvider reports change to 426747 - /volume1/Movies/James Bond Collection/07 Diamonds Are Forever (1971) 2020-11-27 10:12:38.796 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/07 Diamonds Are Forever (1971) 2020-11-27 10:12:38.800 Debug App: FolderImageProvider reports change to 426748 - /volume1/Movies/James Bond Collection/22 Quantum of Solace (2008) 2020-11-27 10:12:38.800 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/22 Quantum of Solace (2008) 2020-11-27 10:12:38.802 Debug App: FolderImageProvider reports change to 426749 - /volume1/Movies/James Bond Collection/08 Live And Let Die (1973) 2020-11-27 10:12:38.802 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/08 Live And Let Die (1973) 2020-11-27 10:12:38.804 Debug App: FolderImageProvider reports change to 426750 - /volume1/Movies/James Bond Collection/03 Goldfinger (1964) 2020-11-27 10:12:38.804 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/03 Goldfinger (1964) 2020-11-27 10:12:38.807 Debug App: FolderImageProvider reports change to 426751 - /volume1/Movies/James Bond Collection/05 You Only Live Twice (1967) 2020-11-27 10:12:38.807 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/05 You Only Live Twice (1967) 2020-11-27 10:12:38.810 Debug App: FolderImageProvider reports change to 426752 - /volume1/Movies/James Bond Collection/11 Moonraker (1979) 2020-11-27 10:12:38.810 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/11 Moonraker (1979) 2020-11-27 10:12:38.814 Debug App: FolderImageProvider reports change to 426753 - /volume1/Movies/James Bond Collection/21 Casino Royale (2006) 2020-11-27 10:12:38.814 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/21 Casino Royale (2006) 2020-11-27 10:12:38.816 Debug App: FolderImageProvider reports change to 426754 - /volume1/Movies/James Bond Collection/12 For Your Eyes Only (1981) 2020-11-27 10:12:38.817 Debug App: Running FolderImageProvider for /volume1/Movies/James Bond Collection/12 For Your Eyes Only (1981) 2020-11-27 10:12:38.819 Debug App: FolderImageProvider reports change to 426721 - /volume1/Movies/Free Birds (2013) 2020-11-27 10:12:38.819 Debug App: Running FolderImageProvider for /volume1/Movies/Free Birds (2013) 2020-11-27 10:12:38.821 Debug App: FolderImageProvider reports change to 426722 - /volume1/Movies/Hector and the Search for Happiness (2014) 2020-11-27 10:12:38.821 Debug App: Running FolderImageProvider for /volume1/Movies/Hector and the Search for Happiness (2014) 2020-11-27 10:12:38.823 Debug App: FolderImageProvider reports change to 426723 - /volume1/Movies/Kiss of Death (1995) 2020-11-27 10:12:38.823 Debug App: Running FolderImageProvider for /volume1/Movies/Kiss of Death (1995) 2020-11-27 10:12:38.826 Debug App: FolderImageProvider reports change to 426724 - /volume1/Movies/Europa Report 2020-11-27 10:12:38.826 Debug App: Running FolderImageProvider for /volume1/Movies/Europa Report 2020-11-27 10:12:38.828 Debug App: FolderImageProvider reports change to 426725 - /volume1/Movies/SAMPLE (2018) 2020-11-27 10:12:38.828 Debug App: Running FolderImageProvider for /volume1/Movies/SAMPLE (2018) 2020-11-27 10:12:38.830 Debug App: FolderImageProvider reports change to 426726 - /volume1/Movies/Tracy Beaker The Movie of Me (2004) 2020-11-27 10:12:38.830 Debug App: Running FolderImageProvider for /volume1/Movies/Tracy Beaker The Movie of Me (2004) 2020-11-27 10:12:39.114 Info Server: http/1.1 GET http://192.168.68.3:8096/emby/ScheduledTasks?IsEnabled=true&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=cd086d72-77bb-43f9-9d8a-f538cb09fe65&X-Emby-Client-Version=4.5.2.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/87.0.4280.66 Safari/537.36 embyserver.txt
Solution GiGo 108 Posted November 28, 2020 Author Solution Posted November 28, 2020 I've just solved my problem! Turns out I hadn't included ".%ext" on Auto Organize file name pattern so all new movies were being moved and renamed without the file extension only found it out when I moved the movies back to the watch folder and it didn't see the, checked in the folders and sure enough each movie was missing their file extention!
