striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 (edited) 12 minutes ago, Happy2Play said: Only thing I can suggest in making a test folder on gdrive and moving those two items to that folder, then making a new library in Emby for that test folder. If they show up then there is something happening within that specific library and your database. I did so....no luck. It shows nothing in there: New Log attached. embyserver.txt Edited April 2, 2021 by striker008
Happy2Play 9802 Posted April 2, 2021 Posted April 2, 2021 It really should not matter but if you enabled OMDB on the library does it make a difference? I know I can not replicate this even if I used all the different scenarios you have in your logs. But will never be a gdrive user. No matter what they should still appear even if unidentified.
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 Humor me and leave them in one place and don't touch them for 24 hours and see if they show up. What you're describing IS common.
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 Oh, for a quick test COPY the two files down to a local HDD (real drive) and add that path to a library. If they show up on a scan it's clear where the issue is. 2 1
striker008 2 Posted April 3, 2021 Author Posted April 3, 2021 5 hours ago, Happy2Play said: It really should not matter but if you enabled OMDB on the library does it make a difference? I know I can not replicate this even if I used all the different scenarios you have in your logs. But will never be a gdrive user. No matter what they should still appear even if unidentified. That didn't do anything
striker008 2 Posted April 3, 2021 Author Posted April 3, 2021 5 hours ago, cayars said: Oh, for a quick test COPY the two files down to a local HDD (real drive) and add that path to a library. If they show up on a scan it's clear where the issue is. I did this. Nothing. They do not show up on scan at all just like the gdrive mount.
Solution Happy2Play 9802 Posted April 3, 2021 Solution Posted April 3, 2021 1 minute ago, striker008 said: I did this. Nothing. They do not show up on scan at all just like the gdrive mount. There is something really going on, on your system then. All I did was drop dummy files in a flat folder structure with your naming and they were discovered by RTM and/or Library scan. Only thing I can think of is a database issue, but using new library/library paths should have resolved that. Minus setting up a remote session with @cayars, I am out of ideas. Are there any user access/parental controls being assigned to the user? 1
striker008 2 Posted April 3, 2021 Author Posted April 3, 2021 5 minutes ago, Happy2Play said: There is something really going on, on your system then. All I did was drop dummy files in a flat folder structure with your naming and they were discovered by RTM and/or Library scan. Only thing I can think of is a database issue, but using new library/library paths should have resolved that. Minus setting up a remote session with @cayars, I am out of ideas. Are there any user access/parental controls being assigned to the user? OMG, you are a genius....it was parental settings. I had it set on NC-17....apparently these shows are so old they are not rated....thank you!
Happy2Play 9802 Posted April 3, 2021 Posted April 3, 2021 Yes this is the most overlooks setting when troubleshooting.
