striker008 2 Posted November 26, 2020 Posted November 26, 2020 I have several movies in the same folder and three will not show up at all in emby. I have tried everything naming wise and they refuse to show in emby. I even moved them to another folder and set up a new library as home videos and they still wouldn't show up. Any ideas on what to do?
Happy2Play 9802 Posted November 26, 2020 Posted November 26, 2020 Can you go over a specific example, along with a server log for that example.
striker008 2 Posted November 26, 2020 Author Posted November 26, 2020 All movie files located in this folder: /home/xx/mnt/gdrive/kidsmovies Every file in their scrapes fine. Except three movies. One is: How.The.Grinch.Stole.Christmas.1966.mkv Does not even come up in the library. I moved it to another folder: /home/xx/mnt/gdrive/kidsmovies2 Setup new library as home videos....it still doesn't show up. embyserver.txt
Happy2Play 9802 Posted November 26, 2020 Posted November 26, 2020 They should appear in the even though the naming scheme is unidentifiable as the provider query will not return results as your file is not named exactly as shown above. 2020-11-26 02:35:51.683 Info App: MovieDbProvider: Finding id for item: How.The.Grinch.Stole.userxtmas
Luke 42203 Posted November 26, 2020 Posted November 26, 2020 Yes it might be showing as the wrong title if it wasn't identified correctly but it should be showing up.
striker008 2 Posted April 1, 2021 Author Posted April 1, 2021 So I have rebuilt the server now but there are still two files that will not be scraped no matter what I do. I have even tried adding the [imdbid=ttxxxxxx] in the name. There are 68 items in the folder and 66 items show up in emby. I am at a loss for what to do. I know my naming convention is correct. The scraper will just not pick them up.... They are: How.The.Grinch.Stole.Christmas.1966.1080p.BluRay.x264.[imdbid=tt0060345].mkv A.Charlie.Brown.Thanksgiving.1973.1080p.BluRay.x264.[imdbid=tt0068359].mkv embyserver.txt
ebr 16309 Posted April 2, 2021 Posted April 2, 2021 18 hours ago, striker008 said: I know my naming convention is correct. Hi. Try: How the Grinch Stole Christmas (1966) 1
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 I agree this will likely work but technically shouldn't be needed. Once you manually identify with the ID number the folder name and file name should be ignored and only use the ID.
striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 35 minutes ago, ebr said: Hi. Try: How the Grinch Stole Christmas (1966) I tried this....still doesn't show in library. So then I decided I would just name it some random movie.....so I named it: Talladega.Nights.The.Ballad.Of.Ricky.Bobby.2006.720p.BluRay.x264.mkv (this is still How the Grinch Stole Christmas (1966)). Now I see Talledega Nights in my Library..... So for some reason it is just rejecting How the Grinch Stole Christmas! (very Grinch of it, lol)
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 (edited) Can you rename it back again. Go to scheduled tasks and run the rotate log job. Do a full library scan. Upload the latest server log. Thanks PS do you use parental restrictions? Edited April 3, 2021 by cayars
striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 5 minutes ago, cayars said: Can you rename it back again. Go to scheduled tasks and run the rotate log job. Do a full library scan. Upload the latest server log. Thanks Done and attached embyserver.txt
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 Thanks Hmm, neither "ricky" or "grinch" show up in the log at all. This was a full library scan? Which library do these files reside in?
striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 3 minutes ago, cayars said: Thanks Hmm, neither "ricky" or "grinch" show up in the log at all. This was a full library scan? Which library do these files reside in? Yes it was. You mean like library location? /home/co/mnt/gdrivea/'Kids Show'/Movies
speechles 2062 Posted April 2, 2021 Posted April 2, 2021 (edited) How.The.Grinch.Stole.Christmas.1966.1080p.BluRay.x264.[imdbid=tt0060345].mkv That won't work as those (tmdbid/imdbid) identifiers are meant for the folder name not the file name. Are these movies just spread out in a single folder? Reading your top post appears they are. It is the resolution not being encapsulated within [ ] being your issue. It confused the date pattern reading. The [ ] instruct the file name to ignore what is inside when looking up that item. Otherwise it is going to use the entire file name to look it up. Including that "1080p.Bluray.x264" part. How.The.Grinch.Stole.Christmas.1966.[1080p.BluRay.x264].mkv does that work? Edited April 2, 2021 by speechles
striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 12 minutes ago, speechles said: How.The.Grinch.Stole.Christmas.1966.1080p.BluRay.x264.[imdbid=tt0060345].mkv That won't work as those (tmdbid/imdbid) identifiers are meant for the folder name not the file name. Are these movies just spread out in a single folder? Reading your top post appears they are. It is the resolution not being encapsulated within [ ] being your issue. It confused the date pattern reading. The [ ] instruct the file name to ignore what is inside when looking up that item. Otherwise it is going to use the entire file name to look it up. Including that "1080p.Bluray.x264" part. How.The.Grinch.Stole.Christmas.1966.[1080p.BluRay.x264].mkv does that work? No dice.....attached an updated log embyserver.txt
speechles 2062 Posted April 2, 2021 Posted April 2, 2021 (edited) Spoiler 2021-04-02 16:05:58.843 Info App: Removing item from database, Type: Movie, Name: How the Grinch Stole Christmas!, Path: /home/co/mnt/gdrivea/Kids Show/Movie/How.The.Grinch.Stole.Christmas.1966.1080p.BluRay.x264.[imdbid=tt0060345].mkv, Id: 1290679 2021-04-02 16:05:58.843 Info App: Deleting path /var/lib/emby/metadata/library/5a/5a2f95b6a75ca15fa99047062fb48717 2021-04-02 16:06:02.958 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/home/co/mnt/gdrivea/Kids Show/Movie/How.The.Grinch.Stole.Christmas.1966.[1080p.BluRay.x264].mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2021-04-02 16:06:04.488 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2021-04-02 16:06:04.492 Info App: MovieDbProvider: Finding id for item: How.The.Grinch.Stole.Christmas 2021-04-02 16:06:04.492 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=How.The.Grinch.Stole.Christmas&language=en 2021-04-02 16:06:04.790 Info HttpClient: GET https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=How+The+Grinch+Stole+Christmas&language=en https://api.themoviedb.org/3/search/movie?api_key=&query=How+The+Grinch+Stole+Christmas&language=en You might need to put the year within ( ) parenthesis as well as the extraneous information within [ ] brackets. How.The.Grinch.Stole.Christmas.(1966)[1080p.BluRay.x264].mkv Perhaps this? Edited April 2, 2021 by speechles 1
Happy2Play 9802 Posted April 2, 2021 Posted April 2, 2021 I am confused as previous logs show items are found just fine with imdbid. 2021-04-01 18:56:07.123 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/home/co/mnt/gdrivea/Kids Show/Movie/How.The.Grinch.Stole.Christmas.1966.1080p.BluRay.x264.[imdbid=tt0060345].mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2021-04-01 18:56:09.492 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2021-04-01 18:56:09.495 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt0060345?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null 2021-04-01 19:05:47.841 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /opt/emby-server/bin/ffprobe -i file:"/home/co/mnt/gdrivea/Kids Show/Movie/A.Charlie.Brown.Thanksgiving.1973.1080p.BluRay.x264.[imdbid=tt0068359].mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2021-04-01 19:05:49.147 Info MediaProbeManager: ProcessRun 'ffprobe' Process exited with code 0 2021-04-01 19:05:49.152 Info HttpClient: GET https://api.themoviedb.org/3/movie/tt0068359?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null I had zero issue using this flat item naming scheme. How.The.Grinch.Stole.Christmas.1966.1080p.BluRay.x264.[imdbid=tt0060345].mkv A.Charlie.Brown.Thanksgiving.1973.1080p.BluRay.x264.[imdbid=tt0068359].mkv 1
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 I think this likely works as well but since the drive is Google Mounted via Rclone the delay in getting file updates is likely the problem. I'd suggest naming them and waiting 24 hours before even bothering to look at your library for them. At the 24 hour mark if they still don't show up try a full library scan.
speechles 2062 Posted April 2, 2021 Posted April 2, 2021 (edited) ...and at that point knowing it is based upon that we should back up a few steps and walk away... Where black and white become a grey area. https://www.linkedin.com/pulse/decision-making-grey-space-shashwat-k-mitra Edited April 2, 2021 by speechles
striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 58 minutes ago, cayars said: I think this likely works as well but since the drive is Google Mounted via Rclone the delay in getting file updates is likely the problem. I'd suggest naming them and waiting 24 hours before even bothering to look at your library for them. At the 24 hour mark if they still don't show up try a full library scan. That's not really how rclone works. I am making the renames within the mount. So the timing is the time to go back and rename on the google server side. In other words, the changes are instantaneous.....proof of that was the Talladega Nights change was picked up immediately on library refresh. I paste pics so you know I am not nuts. You can also see the difference between the 68 and 66 that emby is picking up. Here is current names: Total files: Server side:
Carlo 4561 Posted April 2, 2021 Posted April 2, 2021 It's more about how Google sends the information. The web client for example can show updates right away while info pulled via API takes longer. RClone itself can also cache this info. We see this happen A LOT!
striker008 2 Posted April 2, 2021 Author Posted April 2, 2021 (edited) 7 minutes ago, cayars said: It's more about how Google sends the information. The web client for example can show updates right away while info pulled via API takes longer. RClone itself can also cache this info. We see this happen A LOT! I understand, but I am not making the change within google's web client. I am making the change within the mount itself via CLI. Therefore, the cache time is just writing to google. What emby sees is within the mount where I made the change, so there is no cache time difference there. The rename posted in google fine too: Edited April 2, 2021 by striker008
Happy2Play 9802 Posted April 2, 2021 Posted April 2, 2021 Only thing I can suggest in making a test folder on gdrive and moving those two items to that folder, then making a new library in Emby for that test folder. If they show up then there is something happening within that specific library and your database.
