Jonathan1683 29 Posted November 25, 2020 Posted November 25, 2020 Hello, I am starting to have an issue where when I try to rewind a show a bit once I click play after moving the scrubber to where i want it, the app just closes down to the main apple tv menu. is anyone else having this issue? I restarted the apple tv closed the app and restarted the server and it's still doing the same thing. thank you,
vdatanet 1619 Posted November 26, 2020 Posted November 26, 2020 11 hours ago, Jonathan1683 said: Hello, I am starting to have an issue where when I try to rewind a show a bit once I click play after moving the scrubber to where i want it, the app just closes down to the main apple tv menu. is anyone else having this issue? I restarted the apple tv closed the app and restarted the server and it's still doing the same thing. thank you, Check that you are running the latest version 1.5.0. When upgrading to tvOS 14.2, version 1.5.0 is required for proper operation.
Luke 42241 Posted November 26, 2020 Posted November 26, 2020 Please let us know if this helps. Thanks!
Jonathan1683 29 Posted November 26, 2020 Author Posted November 26, 2020 Hello not sure which I had installed I thought it updated apps automatically, but I did uninstall and reinstall and it's working good again. Thank you,
Desert-Rat 5 Posted November 27, 2020 Posted November 27, 2020 (edited) I'm using a Mac Mini with Catalina. Since I have the same problem, I'm going to uninstall and then reinstall. Is there any specific way to do the uninstall? Edited November 27, 2020 by Desert-Rat
vdatanet 1619 Posted November 27, 2020 Posted November 27, 2020 2 hours ago, Desert-Rat said: I'm using a Mac Mini with Catalina We are talking about client app version not server version. Update client app on Apple TV app store.
Desert-Rat 5 Posted November 27, 2020 Posted November 27, 2020 That question occurred to me last night...got it, yes, thank you very much for clarifying, and for replying. I'll try the uninstall and reinstall on the AppleTV and let you know how that goes.
Desert-Rat 5 Posted November 27, 2020 Posted November 27, 2020 I did what you suggested, voila, it worked. Thank you very much, I really appreciate your help.
Jonathan1683 29 Posted November 27, 2020 Author Posted November 27, 2020 glad it worked i’m sure others will end up with this issue as the apple tv doesn’t have much you can do wrong with it must be a glitch.
Desert-Rat 5 Posted November 28, 2020 Posted November 28, 2020 Emby's a great media platform, and it's very reassuring to have this community forum to support it.
