MediaMogal 19 Posted November 25, 2020 Posted November 25, 2020 (edited) My question is I noticed a couple of extra settings on their page about port forwarding that make look like it's going to be harder to setup than the Xfinity modem is. The Xfinity modem all I had to do was have to enter the port number, click save, and was good to go. On Arris's page they mention a tcp / udp and finding the information in the server in this case Emby. I had a look through the Emby settings but didn't see anything. Can someone point me in the right direction? Thanks https://arris.secure.force.com/consumers/articles/General_FAQs/SVG2482AC-Port-Forwarding-Setup https://www.bestbuy.com/site/arris-surfboard-ac-1750-dual-band-wi-fi-router-with-24-x-8-docsis-3-0-cable-modem-white/5791602.p?skuId=5791602 Edited November 26, 2020 by MediaMogal
mastrmind11 722 Posted November 26, 2020 Posted November 26, 2020 21 hours ago, MediaMogal said: My question is I noticed a couple of extra settings on their page about port forwarding that make look like it's going to be harder to setup than the Xfinity modem is. The Xfinity modem all I had to do was have to enter the port number, click save, and was good to go. On Arris's page they mention a tcp / udp and finding the information in the server in this case Emby. I had a look through the Emby settings but didn't see anything. Can someone point me in the right direction? Thanks https://arris.secure.force.com/consumers/articles/General_FAQs/SVG2482AC-Port-Forwarding-Setup https://www.bestbuy.com/site/arris-surfboard-ac-1750-dual-band-wi-fi-router-with-24-x-8-docsis-3-0-cable-modem-white/5791602.p?skuId=5791602 emby uses TCP over the internet. 1
MediaMogal 19 Posted November 26, 2020 Author Posted November 26, 2020 Ok so just add the port, select my device, and set to TCP?
mastrmind11 722 Posted November 27, 2020 Posted November 27, 2020 18 hours ago, MediaMogal said: Ok so just add the port, select my device, and set to TCP? correct, just forward the port to your server's internal IP as TCP. FWIW if you added both it would still work, just unnecessary. 1
MediaMogal 19 Posted November 28, 2020 Author Posted November 28, 2020 Thanks info very much appreciated.
