nitrup93 17 Posted November 24, 2020 Posted November 24, 2020 (edited) Hello to all, Let me explain my problem, I'm using Emby Beta 4.6.0.6 on a Synology DS918+ I use Emby on LG OLED55BX TV with Webos and the sound is optically linked on a "devialet Freebox". I know the DTS-HD is not present on the TV and the SoundBar how do I get Emby to transcode the sound and let the video in directplay ? I can't find the option for uncheck de DTS-HD on the webos app Thanks in advance exemple : Vidéo Title 4K HEVC Code cHEVC Profil Main 10 Niveau150 Résolution3840x1600 Ratio d’aspect2.40:1 EntrelacéNon Images par seconde23,976 Débit37 879 kbps Gamme vidéoHDR Couleurs primairesbt2020 Espace colorimétriquebt2020nc Transfert de couleursmpte2084 Profondeur des échantillons10 bit Format des pixelsyuv420p10le Images de référence1 Audio TitleFrench DTS-HD MA 5.1 (Default) LangueFrench CodecDTS ProfilDTS-HD MA Disposition5.1 Chaînes6 ch Taux d’échantillonnage48 000 Hz Profondeur des échantillons16 bit Par défaut Oui Edited November 24, 2020 by nitrup93
Solution Luke 42243 Posted November 24, 2020 Solution Posted November 24, 2020 Hi, I've resolved for the next update to the lg app. Thanks.
nitrup93 17 Posted November 24, 2020 Author Posted November 24, 2020 Great !! Do you have a date of this update ?
nitrup93 17 Posted November 24, 2020 Author Posted November 24, 2020 What is the next version ? 1.0.25 ?
Luke 42243 Posted November 24, 2020 Posted November 24, 2020 Depends on how many tries it takes. Something greater than the current version.
nitrup93 17 Posted November 24, 2020 Author Posted November 24, 2020 Thanks for your speed anwser ! Wait and see now
nitrup93 17 Posted December 4, 2020 Author Posted December 4, 2020 Can we expect a new version before Christmas?
