H3adsho0ot 0 Posted November 24, 2020 Posted November 24, 2020 Hello everybody, I moved my emby instance to a new server - since then I can browse emby normally in the tizen app - but it won't start playing (only loading screen is showing up). Emby is on version 4.5.2.0 and Tizen app is 1.0.86. Emby is behind nginx as reverse proxy. Internal and external adress seems right in Emby server app. I can watch all these files in chrome without a problem. Is it probably because the server is not reachable over http? Nginx is upgrading http to https. I attached a part of the log - if you need more pls tell me. Thanks in advance! log.txt
NAVALA00 6 Posted November 24, 2020 Posted November 24, 2020 Tengo el mismo problema que H3adsho0ot: al actualizar a .86 en Tizen (Modelo UE55MU6675) ya no puedo volver hacia tras o avanzar, seleccionar subtitulois... etc. Todo lo demas funcionar correctamente. Mi servidor (TerraMaster) no se ha modificado en absoluto.
Luke 42241 Posted November 24, 2020 Posted November 24, 2020 https://emby.media/community/index.php?/topic/92198-samsung-ue48j5600-tizen-unable-to-click-through-media-foldersicons-in-main-screen/
H3adsho0ot 0 Posted November 24, 2020 Author Posted November 24, 2020 Hi Luke, it's a Samsung 55Q60R (QE55Q60RATXTG) with software version T-MSMDEUC-1372.2. Thanks in advance!
SamES 1084 Posted November 25, 2020 Posted November 25, 2020 17 hours ago, H3adsho0ot said: Is it probably because the server is not reachable over http? Nginx is upgrading http to https. This will be your problem as I don't believe the TV will be able to validate the https certificate, the installed root certificates are limited. Can you configure nginx to not upgrade to https for the Samsung TV user agent string? User-Agent=Mozilla/5.0 (SMART-TV; LINUX; Tizen 5.0) AppleWebKit/537.36 (KHTML, like Gecko) Version/5.0 TV Safari/537.36
H3adsho0ot 0 Posted November 25, 2020 Author Posted November 25, 2020 That's not realy the solution I was hoping for
SamES 1084 Posted November 25, 2020 Posted November 25, 2020 Unfortunately https support on the TV is limited
pir8radio 1313 Posted November 26, 2020 Posted November 26, 2020 18 hours ago, SamES said: Unfortunately https support on the TV is limited you say https support on the tv is "limited" limited how? can he specify to allow weaker cyphers or something? while still having some kind of encryption or is it that the tv doesnt trust his certs? then using cloudflare or something can help.
SamES 1084 Posted November 26, 2020 Posted November 26, 2020 Every time the issue of https support on Tizen/Samsung TV's comes up (and LG as well) there are problems. I'm not aware of anybody that confirmed that it works. Samsung don't have a list of supported root certificates (I found an old list for LG a long time ago), and there's no possibility to add additional. On the developer FAQ's they have this (badly worded) statement. Quote To transmit encrypted information between Web browsers and Web servers, Samsung Smart TVs support TLS (Transport Layer Security) versions 1.0, 1.1, and 1.2. A TV firmware upgrade can be required to patch the POODLE attack vulnerability. Consequently, SSL (Secure Sockets Layer) is no longer supported. #tls #transport layer security #ssl #secure sockets layer As far as I know, the level of support/ciphers is not documented so it would be a lot of trial and error.
dcol 177 Posted November 27, 2020 Posted November 27, 2020 First answer I heard that makes sense. I cannot get any stream to play on a Tizen Samsung and I use https exclusively. maybe I need to offer an http path. Is that really safe to do? If it doesn't matter, then why use https at all? 1
H3adsho0ot 0 Posted December 4, 2020 Author Posted December 4, 2020 It seems to be not all about https. It is working now on one TV (have no idea why) but on three other tizen TVs it still won't load the streams. In the nginx log I can only see errors like this (there are multiple when starting a stream): epoll_wait() reported that client prematurely closed connection, so upstream connection is closed too while sending request to upstream, client: "external ip", server: domain, request: "GET /Users/630d4f25ca5747bf94b94a425d8bf859/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb HTTP/1.1", upstream: "http://"server private ip":8096/Users/630d4f25ca5747bf94b94a425d8bf859/Items/Resume?Limit=3&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb", host: "domain" Is there any way to see the logs of emby tizen app?
Luke 42241 Posted December 4, 2020 Posted December 4, 2020 No, please attach the emby server log. Thanks.
H3adsho0ot 0 Posted December 4, 2020 Author Posted December 4, 2020 Here is one unsuccessful attemp to stream but I think this might be some other problem: embyserver (1).txt
dcol 177 Posted December 4, 2020 Posted December 4, 2020 Tizen TV's working here using http. Make sure you select 'Preferred, but not required' in the Emby 'Secure connection mode' network setting. Also check your NAT settings in the router/firewall. I allow both http and https connections now. Not crazy about allowing http, but until this is fixed I have to allow http.
Luke 42241 Posted December 4, 2020 Posted December 4, 2020 37 minutes ago, dcol said: Tizen TV's working here using http. Make sure you select 'Preferred, but not required' in the Emby 'Secure connection mode' network setting. Also check your NAT settings in the router/firewall. I allow both http and https connections now. Not crazy about allowing http, but until this is fixed I have to allow http. There's nothing emby can do. You'll have to submit your own feedback to samsung to accept more ssl certs.
dcol 177 Posted December 4, 2020 Posted December 4, 2020 (edited) Or, if you know what certs Tizen does accept get one of those. Prime, Netflix, and Hulu uses DigiCert. Get a cert from them and I am sure it will work. Edited December 4, 2020 by dcol
Luke 42241 Posted December 4, 2020 Posted December 4, 2020 58 minutes ago, dcol said: Or, if you know what certs Tizen does accept get one of those. Prime, Netflix, and Hulu uses DigiCert. Get a cert from them and I am sure it will work. @SamES has researched this before and can comment.
SamES 1084 Posted December 5, 2020 Posted December 5, 2020 7 hours ago, dcol said: Or, if you know what certs Tizen does accept get one of those. Prime, Netflix, and Hulu uses DigiCert. Get a cert from them and I am sure it will work. DigiCert is worth trying, but I expect it will be trial and error. You could contact Samsung and ask what certificates they support, but they may not be willing to share that information.
pir8radio 1313 Posted December 5, 2020 Posted December 5, 2020 you are more than welcome to test your TV on my server which uses cloudflare, I have yet to find a device that doesnt like cloudflare's certs.
dcol 177 Posted December 28, 2020 Posted December 28, 2020 (edited) Samsung won't give out that info. Not going to buy an expensive Digicert certificate just to try out. Did anyone get https to work in Emby on a Tizen Smart TV? If so, what was the cert provider? Edited December 28, 2020 by dcol
H3adsho0ot 0 Posted January 11, 2021 Author Posted January 11, 2021 Now its working again for me - have no idea why. Still just uses https.
dcol 177 Posted January 11, 2021 Posted January 11, 2021 Started working for me too. Anyone know why? I don't think there were any Tizen updates.
Luke 42241 Posted January 11, 2021 Posted January 11, 2021 3 hours ago, dcol said: Started working for me too. Anyone know why? I don't think there were any Tizen updates. Not sure but thanks for the info.
