KrisFriFly 0 Posted December 11, 2020 Posted December 11, 2020 (edited) 2 hours ago, SamES said: After you uninstall it, make sure your do a full restart of the tv (pull the power for 30 seconds) before installing again from USB This seemed to do the trick. However, when clicking Connect to the remote server it gives me "Connection Failure". This is despite the server being up and working on my other devices. Edited December 11, 2020 by KrisFriFly
Luke 42242 Posted December 12, 2020 Posted December 12, 2020 3 hours ago, KrisFriFly said: This seemed to do the trick. However, when clicking Connect to the remote server it gives me "Connection Failure". This is despite the server being up and working on my other devices. Is it an https url? It could be certificate related as samsung is picky about that.
KrisFriFly 0 Posted December 15, 2020 Posted December 15, 2020 On 12/12/2020 at 2:39 AM, Luke said: Is it an https url? It could be certificate related as samsung is picky about that. Yes, it is. Is there a way around this?
Luke 42242 Posted December 15, 2020 Posted December 15, 2020 4 minutes ago, KrisFriFly said: Yes, it is. Is there a way around this? If it's https, then the server has to use a certificate that Samsung devices trust. If you don't, then you'll see this kind of connection error. Samsung doesn't publish a list of trusted certificates but we think Digicert provides the best chance for success. The only other option is to just use plain http.
