cappapp 7 Posted November 22, 2020 Posted November 22, 2020 I've looked at the naming guide, but I'm not sure what to do in the case of 1 episode, broken into 3 parts. If there is even an option. Or maybe I didn't understand. Can anyone confirm if I can do this or not? Cheers
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 Can you go over a specific example.
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 (edited) There is no easy way for this, it will be some work but you already have them in single episodes you would just need to rename the episode number according to TVDB. Cartoons are problematic as different providers handle them differently. But this specific example TMDB list them individually also. So from a metadata provider standpoint these should not be parts of a specific episode. Personally I would use a tool like Bulk Rename Utility and rename them using the interface to the remove 2 character in the naming and replace them sequentially. I will post an example shortly. Edited November 22, 2020 by Happy2Play
Carlo 4561 Posted November 22, 2020 Posted November 22, 2020 Your best bet would be to combine this manually outside of Emby back into 1 episode so that it matches.
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 1 minute ago, cayars said: Your best bet would be to combine this manually outside of Emby back into 1 episode so that it matches. Not really as they are individual episodes on provider sites.
Carlo 4561 Posted November 22, 2020 Posted November 22, 2020 To me if it's one episode broken up as he gets it into 3 files but the meta-data is only for one episode I WOULD combine the three into 1 file so it matches the provider data. That's just me but how I'd handle this.
Solution Happy2Play 9811 Posted November 22, 2020 Solution Posted November 22, 2020 Here is an example of what I would do to make each one match provider. The set code provides proper new name.
cappapp 7 Posted November 22, 2020 Author Posted November 22, 2020 9 minutes ago, Happy2Play said: a tool like Bulk Rename Utility I've been using Ant renamer for a long time, this one looks cool too. Thanks, i'll add it to my tools. So I just want to seq name everything 1, 2, 3 ... etc ?
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 10 minutes ago, cayars said: Your best bet would be to combine this manually outside of Emby back into 1 episode so that it matches. But provider has them individually sequentially. If you combine them then you have to rename as S01E01-E03. Instead of as is and change episode numbers.
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 Just now, cappapp said: I've been using Ant renamer for a long time, this one looks cool too. Thanks, i'll add it to my tools. So I just want to seq name everything 1, 2, 3 ... etc ? I would spot check to verify your episode corresponds with provider but yes.
Carlo 4561 Posted November 22, 2020 Posted November 22, 2020 I misunderstood I think. So there is the correct number of episodes and the description is correct but episode season/number is wrong? In that case just a rename. What am I missing?
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 1 minute ago, cayars said: I misunderstood I think. So there is the correct number of episodes and the description is correct but episode season/number is wrong? In that case just a rename. What am I missing? Correct just a episode number change in this specific case. 1
cappapp 7 Posted November 22, 2020 Author Posted November 22, 2020 2 minutes ago, Happy2Play said: I would spot check to verify your episode corresponds with provider but yes. Ok, cool. I'll give it a shot.
cappapp 7 Posted November 22, 2020 Author Posted November 22, 2020 Actually, based on that information. It was easier to just remove all the numbering and have filebot fix them up; 2
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 (edited) Yes Filebot is really good at matching this information (Show/episode name). Edited November 22, 2020 by Happy2Play
cappapp 7 Posted November 22, 2020 Author Posted November 22, 2020 Yeah. Thanks for the help. I don't know why I didn't think of that earlier. I've done that in the past, I guess I was thrown off by assuming the 3 files should of been 1 file. Thanks again.
Happy2Play 9811 Posted November 22, 2020 Posted November 22, 2020 Just now, cappapp said: Yeah. Thanks for the help. I don't know why I didn't think of that earlier. I've done that in the past, I guess I was thrown off by assuming the 3 files should of been 1 file. Thanks again. I don't believe the Split video files (file stacking) logic applies to Episodes/TV, like it does a Movie. But glad it was a relatively easy fix.
