mbnwa 49 Posted July 29, 2014 Posted July 29, 2014 After upgrading to 3.0.5323.459 my supporter key no longer works I get the following message: Supporter key is missing or invalid. In order for any premium content to be registered, you must also be a Media Browser Supporter. Please donate and support the continued development of the core product. Thank you.
Ron 2 Posted July 29, 2014 Posted July 29, 2014 sure it doesn't help you but just for comparison, I am now on the same version and my supporter is still active
Mibok 158 Posted July 29, 2014 Posted July 29, 2014 I had the same problem not so much time ago. Try leave the supporter key in blank then save, that'll delete the stored key. Then re enter your key. That worked for me
mbnwa 49 Posted July 30, 2014 Author Posted July 30, 2014 I tried that (Deleting key and saving and re-entering) but after re-entering my key it tells me it's invalid if I revert to the version I was running before it works as expected :/
ebr 16306 Posted July 31, 2014 Posted July 31, 2014 A server log from when you enter and save the key please.
