Pommes 12 Posted November 20, 2020 Posted November 20, 2020 Hi, some thumbnails display in the wrong ratio when i click on the video any ideas? in the overview they are displayed correctly
Carlo 4561 Posted November 20, 2020 Posted November 20, 2020 Hi, Can you post a screen shot where they are wrong? Are they on a screen with other videos of different aspect ratio?
Pommes 12 Posted November 20, 2020 Author Posted November 20, 2020 (edited) nope They are correctly displayed on the overview page with other movies. Only when I click on the and get to the "detailed page they are bugged. Edited November 20, 2020 by Pommes
Carlo 4561 Posted November 20, 2020 Posted November 20, 2020 21 minutes ago, Pommes said: Hi, some thumbnails display in the wrong ratio when i click on the video any ideas? in the overview they are displayed correctly If this is what you're referring to replace the image with a proper movie poster.
Pommes 12 Posted November 20, 2020 Author Posted November 20, 2020 1 minute ago, cayars said: If this is what you're referring to replace the image with a proper movie poster. oh ok thx so it isnt possible to use a thumb in this possition?
Luke 42206 Posted November 20, 2020 Posted November 20, 2020 It's something we can look at improving in future updates. For best results though movie posters should use an aspect ratio of 2:3
