sjlcjl 5 Posted November 19, 2020 Posted November 19, 2020 I see that the bitrate for audio remux is set to 384k. Is there a way to change that somewhere that I cannot find? Thanks so much!
Luke 42206 Posted November 20, 2020 Posted November 20, 2020 Hi, not currently. What are you hoping to change it to?
sjlcjl 5 Posted November 20, 2020 Author Posted November 20, 2020 I was looking to go higher.. 448k or possibly just go 640k to keep as much there as possible.. Thought maybe I could cheat it somewhere since it wasn't in the GUI..
Luke 42206 Posted November 20, 2020 Posted November 20, 2020 There isn't, but it's possible for the future. Thanks.
