baiguke 1 Posted November 25, 2020 Posted November 25, 2020 7 hours ago, Happy2Play said: Copied from Report Center. @lemmo What version are you using? Can you upload the .ass subtitles for reference?
hellomrli 0 Posted November 25, 2020 Author Posted November 25, 2020 拯救大兵瑞恩 (1998) 1080p DTSHD-MA.ass
hellomrli 0 Posted November 25, 2020 Author Posted November 25, 2020 The .ass subtitles for Saving Private Ryan(1998).
Luke 42246 Posted November 30, 2020 Posted November 30, 2020 Ok I think this should be resolved for the next release. Thanks for reporting.
deccat 1 Posted May 7, 2021 Posted May 7, 2021 9 hours ago, myhomeserve said: The problem is still unsolved 客户端基本不存在这个问题了。如果是网页端播放,可以手动替换服务端的字体文件,重启 emby server即可。老版本字体很多地方有下载,思路有了剩下的你百度一下。
Luke 42246 Posted May 8, 2021 Posted May 8, 2021 Hi, it should be resolved in the upcoming emby server 4.6 release that will be out soon. Thanks. 1
myhomeserve 0 Posted May 9, 2021 Posted May 9, 2021 14 hours ago, Luke said: Hi, it should be resolved in the upcoming emby server 4.6 release that will be out soon. Thanks. Thank you for your reply.
