bakes82 167 Posted January 16, 2021 Author Posted January 16, 2021 11 hours ago, teop2009 said: Hi, Not sure am I doing everything ok, but I can't make your plugin to work. I am using emby in docker, the newest stable version. So I downloaded the newest plugin release from your github, I put it inside of my plugins folder, I restarted the server. Then I checked and I saw plugin appeared under plugins, I left configuration as default. I tried to play a 4k movie on Microsoft Edge on my pc, and movie got transcoded, but it never kill the stream, I done the same test with my android phone and nothing happens. I left it to play for a few min and the stream never got killed. When I went under logs, it seems like server recognize that I have this plugin, but plugin never gets activated during playback. So only parts of the log which has a word killstream are: 2021-01-16 08:39:27.137 Info App: Loading KillStreams, Version=2021.1.12.1, Culture=neutral, PublicKeyToken=null from /config/plugins/KillStreams.dll 2021-01-16 08:39:28.314 Debug XmlSerializer: Deserializing file /config/plugins/configurations/KillStreams.xml 2021-01-16 08:39:29.083 Info App: Starting entry point KillStreams.ServerEntryPoint 2021-01-16 08:39:29.083 Info App: Entry point completed: KillStreams.ServerEntryPoint. Duration: 8.15E-05 seconds Is there something I mess up, or maybe just on this type of devices, your plugin doesn't work? No idea, it works in FireFox and on Shields. Those what I use to test with. You would need to attach full logs and what the your config looks like. There are two plugin dirs, you sure you put it in the right one? The plugin has a sched task that runs every 1 min. Thats when the things are killed, there isno way to prevent it from happening so at most it would transcode 1min before the job kicks off again. If plugin already installed, in the sched tasks press the roate logs button, start a transcode wait a min or two and then wait a min for the logs to update and let me know.
spaceman07 8 Posted February 12, 2021 Posted February 12, 2021 Just saw this now.. many thanks for this I will be installing this for sure!
spaceman07 8 Posted February 12, 2021 Posted February 12, 2021 (edited) Hi.. I am having some issues with this plugin where it appears its not working - * Version 4.5.4.0 * installed plugin latest version from git repo Release 2021.01.12.1 * enabled pause kill after 1 min and enabled to allow audio transcode * Info SessionManager: Playback start reported by app Emby Web 4.5.4.0 I will enable debug for logs and capture further.. what can i grep for to extract the specifics possibly? Thanks Edited February 12, 2021 by spaceman07
bakes82 167 Posted February 12, 2021 Author Posted February 12, 2021 2 hours ago, spaceman07 said: Hi.. I am having some issues with this plugin where it appears its not working - * Version 4.5.4.0 * installed plugin latest version from git repo Release 2021.01.12.1 * enabled pause kill after 1 min and enabled to allow audio transcode * Info SessionManager: Playback start reported by app Emby Web 4.5.4.0 I will enable debug for logs and capture further.. what can i grep for to extract the specifics possibly? Thanks Not all "clients" are equal, I only tested with shield and web browser, as thats all I use. I was making some plugins for me to transition to Emby, but I still very much only use Plex. Emby is just meh, and the api and differences between features on each "client" makes things even more meh.
lundblad 10 Posted February 19, 2021 Posted February 19, 2021 (edited) add own "stop" messages would be nice Edited February 19, 2021 by lundblad
lundblad 10 Posted February 20, 2021 Posted February 20, 2021 (edited) Nothing with this plugin did work for me, emby on synology (Package) Version 4.6.0.22 beta Edited February 20, 2021 by lundblad
bakes82 167 Posted February 20, 2021 Author Posted February 20, 2021 2 hours ago, lundblad said: Nothing with this plugin did work for me, emby on synology (Package) Version 4.6.0.22 beta That’s a beta and you didn’t say what client you used and there is a sched job that runs every 1 min to kill the streams so you can start it but after 1 min it will kill it and there are logs. So post your emby sever logs
lundblad 10 Posted February 20, 2021 Posted February 20, 2021 (edited) 10 hours ago, bakes82 said: That’s a beta and you didn’t say what client you used and there is a sched job that runs every 1 min to kill the streams so you can start it but after 1 min it will kill it and there are logs. So post your emby sever logs Vivaldi Browser (built on chrome i guess?) Shield tv emby app. Now i got the popup about transcoding 4k but after pressing OK, stream still playing xD. Edited February 20, 2021 by lundblad
BoxMovie2 0 Posted February 26, 2021 Posted February 26, 2021 Hi, how do you install this add-on Kill Streams ؟ https://github.com/bakes82/Emby_KillStreams Is the method in the picture correct?
Happy2Play 9814 Posted February 26, 2021 Posted February 26, 2021 Yes you would place it in "C:\Users\username\AppData\Roaming\Emby-Server\programdata\plugins".
Happy2Play 9814 Posted February 26, 2021 Posted February 26, 2021 1 minute ago, BoxMovie2 said: How is the installation method.? per you other topic, you place the dll file in "C:\Users\username\AppData\Roaming\Emby-Server\programdata\plugins", then start/restart Emby.
BoxMovie2 0 Posted February 26, 2021 Posted February 26, 2021 2 minutes ago, Happy2Play said: Yes you would place it in "C:\Users\username\AppData\Roaming\Emby-Server\programdata\plugins". Not set
BoxMovie2 0 Posted February 26, 2021 Posted February 26, 2021 2 minutes ago, Happy2Play said: per you other topic, you place the dll file in "C:\Users\username\AppData\Roaming\Emby-Server\programdata\plugins", then start/restart Emby.
BoxMovie2 0 Posted February 26, 2021 Posted February 26, 2021 Is there anyone who has solved the problem?
bakes82 167 Posted March 2, 2021 Author Posted March 2, 2021 (edited) On 2/20/2021 at 5:40 AM, lundblad said: Vivaldi Browser (built on chrome i guess?) Shield tv emby app. Now i got the popup about transcoding 4k but after pressing OK, stream still playing xD. It keeps playing in what client? Shield? Vivaldi? There is no way to to prevent the person from playing the file, if they want to keep watching in 1min intervals I guess they can lol. This is where I said not all clients are created equal, some I can only pass "pause" to, others I pass "stop". I issue both to the client, and "stop" is the last in the sequence but if the client doesnt support it and only supports pause well they can just press play again. If you check in the logs I think I list what the client supports. Edited March 2, 2021 by bakes82
CyberPoison 33 Posted April 28, 2021 Posted April 28, 2021 (edited) Unfotunatelly not able to put it working with Google Chrome. 2021-04-28 13:43:43.589 Info App: Application version: 4.6.0.40 2021-04-28 13:43:43.589 Info App: Emby Command line: /app/emby/EmbyServer.dll -programdata /config -ffdetect /app/emby/ffdetect -ffmpeg /app/emby/ffmpeg -ffprobe /app/emby/ffprobe -restartexitcode 3 Operating system: Linux version 4.15.0-142-generic (buildd@lgw01-amd64-036) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #146-Ubuntu SMP Tue Apr 13 01:11:19 UTC 20 Framework: .NET Core 3.1.13 OS/Process: x64/x64 Runtime: app/emby/System.Private.CoreLib.dll Processor count: 12 Data path: /config Application path: /app/emby 2021-04-28 13:43:43.590 Info App: Plugins: Anime 1.4.8.0 Auto Box Sets 1.2.6.0 Bluray Folder Support 1.0.0.0 Cinema Intros 1.0.37.0 CoverArt 4.1.14.0 Dlna 1.0.63.0 Dvd Folder Support 1.0.0.0 Fanart.tv 1.0.12.0 Genre Cleaner 1.0.21.0 KillStreams 1.0.0.0 LDAP 1.0.39.0 Message Users 1.0.0.1 Movie Theme Songs 1.7.5.0 Movie Theme Videos 1.7.5.0 MovieDb 1.4.5.0 MusicBrainz 1.0.16.0 Nfo Metadata 1.0.51.0 OMDb 1.0.14.0 Podcasts 1.2.4.0 Port Mapper 1.0.5.0 Rating Poster Database 1.0.0.0 SmartPlaylist 1.3.0.1 Statistics 2.0.19.0 Studio Cleaner 3.2.6.0 Studio Images 1.0.3.0 TheAudioDb 1.0.14.0 Theme Songs 1.6.6.7 TheTVDB 1.0.41.0 Trailers 1.3.0.0 Trakt 3.5.0.0 TV Theme Videos 1.7.5.0 Webhooks 1.0.14.0 2021-04-28 13:43:43.590 Debug TaskManager: Rotate log file Completed after 0 minute(s) and 0 seconds 2021-04-28 13:43:43.611 Info Server: http/1.1 GET http://192.168.1.5/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36 2021-04-28 13:43:43.612 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 1ms. http://192.168.1.5/emby/ScheduledTasks?isHidden=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40 2021-04-28 13:43:44.670 Info Server: http/1.1 GET http://192.168.1.5/emby/videos/190956/hls1/subs/28.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=pt-PT,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr-FR;q=0.6,fr;q=0.5,pl;q=0.4,de;q=0.3, Host=192.168.1.5, Referer=https://192.168.1.5/web/index.html, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36, X-Request-ID=91c962020c36f8b476625179b2c1b467, X-Real-IP=176.139.21.193, X-Forwarded-For=176.139.21.193, X-Forwarded-Host=192.168.1.5, X-Forwarded-Port=443, X-Forwarded-Proto=https, X-Original-URI=/emby/videos/190956/hls1/subs/28.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&api_key=49916508bcb84e99ba788e8368c49dc7&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3, X-Scheme=https, sec-ch-ua=" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90", sec-ch-ua-mobile=?0, sec-fetch-site=same-origin, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-28 13:43:44.671 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 1ms. http://192.168.1.5/emby/videos/190956/hls1/subs/28.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3 2021-04-28 13:43:45.179 Info Server: http/1.1 GET http://192.168.1.5/emby/videos/190956/hls1/main/41.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=pt-PT,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr-FR;q=0.6,fr;q=0.5,pl;q=0.4,de;q=0.3, Host=192.168.1.5, Referer=https://192.168.1.5/web/index.html, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36, X-Request-ID=228f926141eceb20f838fb293cc6050c, X-Real-IP=176.139.21.193, X-Forwarded-For=176.139.21.193, X-Forwarded-Host=192.168.1.5, X-Forwarded-Port=443, X-Forwarded-Proto=https, X-Original-URI=/emby/videos/190956/hls1/main/41.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&api_key=49916508bcb84e99ba788e8368c49dc7&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit, X-Scheme=https, sec-ch-ua=" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90", sec-ch-ua-mobile=?0, sec-fetch-site=same-origin, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-28 13:43:45.201 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 23ms. http://192.168.1.5/emby/videos/190956/hls1/main/41.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit 2021-04-28 13:43:47.627 Info Server: http/1.1 GET http://192.168.1.5/emby/videos/190956/hls1/subs/29.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=pt-PT,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr-FR;q=0.6,fr;q=0.5,pl;q=0.4,de;q=0.3, Host=192.168.1.5, Referer=https://192.168.1.5/web/index.html, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36, X-Request-ID=2c4c3b8d151d7b06d9e0096c679222e8, X-Real-IP=176.139.21.193, X-Forwarded-For=176.139.21.193, X-Forwarded-Host=192.168.1.5, X-Forwarded-Port=443, X-Forwarded-Proto=https, X-Original-URI=/emby/videos/190956/hls1/subs/29.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&api_key=49916508bcb84e99ba788e8368c49dc7&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3, X-Scheme=https, sec-ch-ua=" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90", sec-ch-ua-mobile=?0, sec-fetch-site=same-origin, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-28 13:43:47.627 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 1ms. http://192.168.1.5/emby/videos/190956/hls1/subs/29.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3 2021-04-28 13:43:47.770 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to 176.139.21.193 2021-04-28 13:43:47.774 Info Server: http/1.1 GET http://192.168.1.5/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36 2021-04-28 13:43:47.774 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 1ms. http://192.168.1.5/emby/System/Configuration?X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40 2021-04-28 13:43:47.783 Info Server: http/1.1 GET http://192.168.1.5/emby/System/Logs/Query?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,PrimaryImageAspectRatio&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=30&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36 2021-04-28 13:43:47.786 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 3ms. http://192.168.1.5/emby/System/Logs/Query?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,PrimaryImageAspectRatio&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=30&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40 2021-04-28 13:43:48.177 Info Server: http/1.1 GET http://192.168.1.5/emby/videos/190956/hls1/main/42.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=pt-PT,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr-FR;q=0.6,fr;q=0.5,pl;q=0.4,de;q=0.3, Host=192.168.1.5, Referer=https://192.168.1.5/web/index.html, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36, X-Request-ID=4db53368c003b1b61e353571995b26aa, X-Real-IP=176.139.21.193, X-Forwarded-For=176.139.21.193, X-Forwarded-Host=192.168.1.5, X-Forwarded-Port=443, X-Forwarded-Proto=https, X-Original-URI=/emby/videos/190956/hls1/main/42.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&api_key=49916508bcb84e99ba788e8368c49dc7&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit, X-Scheme=https, sec-ch-ua=" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90", sec-ch-ua-mobile=?0, sec-fetch-site=same-origin, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-28 13:43:48.180 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 3ms. http://192.168.1.5/emby/videos/190956/hls1/main/42.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit 2021-04-28 13:43:49.029 Info Server: http/1.1 GET http://192.168.1.5/emby/System/Logs/embyserver.txt/Lines?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,PrimaryImageAspectRatio&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=100&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36 2021-04-28 13:43:49.042 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 14ms. http://192.168.1.5/emby/System/Logs/embyserver.txt/Lines?SortBy=SortName&SortOrder=Ascending&Fields=BasicSyncInfo,CanDelete,PrimaryImageAspectRatio&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Thumb&StartIndex=0&Limit=100&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome&X-Emby-Device-Id=3f733e16-7377-4f6a-b56d-5fc529a6dda2&X-Emby-Client-Version=4.6.0.40 2021-04-28 13:43:50.625 Info Server: http/1.1 GET http://192.168.1.5/emby/videos/190956/hls1/subs/30.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=pt-PT,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr-FR;q=0.6,fr;q=0.5,pl;q=0.4,de;q=0.3, Host=192.168.1.5, Referer=https://192.168.1.5/web/index.html, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36, X-Request-ID=1fb11f0af178156ad0aa09f84cae3f75, X-Real-IP=176.139.21.193, X-Forwarded-For=176.139.21.193, X-Forwarded-Host=192.168.1.5, X-Forwarded-Port=443, X-Forwarded-Proto=https, X-Original-URI=/emby/videos/190956/hls1/subs/30.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&api_key=49916508bcb84e99ba788e8368c49dc7&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3, X-Scheme=https, sec-ch-ua=" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90", sec-ch-ua-mobile=?0, sec-fetch-site=same-origin, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-28 13:43:50.626 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 1ms. http://192.168.1.5/emby/videos/190956/hls1/subs/30.vtt?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit&CurrentSubtitleStreamIndex=3&SubtitleSegmentLength=3 2021-04-28 13:43:51.177 Info Server: http/1.1 GET http://192.168.1.5/emby/videos/190956/hls1/main/43.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit. Accept=*/*, Accept-Encoding=gzip, deflate, br, Accept-Language=pt-PT,pt;q=0.9,en-US;q=0.8,en;q=0.7,fr-FR;q=0.6,fr;q=0.5,pl;q=0.4,de;q=0.3, Host=192.168.1.5, Referer=https://192.168.1.5/web/index.html, User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36, X-Request-ID=93b293c0f7f7b9642ce4930dd7c8f247, X-Real-IP=176.139.21.193, X-Forwarded-For=176.139.21.193, X-Forwarded-Host=192.168.1.5, X-Forwarded-Port=443, X-Forwarded-Proto=https, X-Original-URI=/emby/videos/190956/hls1/main/43.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&api_key=49916508bcb84e99ba788e8368c49dc7&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit, X-Scheme=https, sec-ch-ua=" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90", sec-ch-ua-mobile=?0, sec-fetch-site=same-origin, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-28 13:43:51.182 Info Server: http/1.1 Response 200 to 176.139.21.193. Time: 4ms. http://192.168.1.5/emby/videos/190956/hls1/main/43.ts?DeviceId=3f733e16-7377-4f6a-b56d-5fc529a6dda2&MediaSourceId=6140e605184b0dc753d4777e98343df1&PlaySessionId=eb6a764497104245bf1b15c1bd4b1214&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=6616000&AudioBitrate=384000&AudioStreamIndex=2&SubtitleStreamIndex=3&SubtitleMethod=Hls&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerBitrateExceedsLimit 2021-04-28 13:43:51.313 Info Server: http/1.1 GET http://192.168.1.5/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36 {"Protocol":"File","Id":"c43fa49f9a115e6c4000bbb54d0f8068","Path":"/mnt/Cloud Storage/Cloud Storage Server 1/FR/Films4K[FR]/Assassin's Creed/Assassin's Creed 2016 MULTi 2160p UHD BluRay REMUX HEVC-GLaDOS.mkv","Type":"Default","Container":"mkv","Size":36526499328,"Name":"2016 MULTi 2160p UHD BluRay REMUX HEVC-GLaDOS","IsRemote":false,"RunTimeTicks":69309760000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","ColorTransfer":"smpte2084","ColorPrimaries":"bt2020","ColorSpace":"bt2020nc","TimeBase":"1/1000","CodecTimeBase":"1001/24000","Title":"Assassin's Creed","VideoRange":"HDR10","DisplayTitle":"4K HEVC HDR10","IsInterlaced":false,"BitRate":42160295,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":2160,"Width":3840,"AverageFrameRate":23.976025,"RealFrameRate":23.976025,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":153,"IsAnamorphic":false},{"Codec":"ac3","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"French (Canada) : Dolby Digital 5.1","DisplayTitle":"AC3 5.1 (Default)","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":448000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"dts","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"French (France) : Digital Theater System 5.1","DisplayTitle":"DTS 5.1","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":768000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"DTS","Type":"Audio","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"truehd","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"English : Dolby Atmos 7.1","DisplayTitle":"TRUEHD 7.1","IsInterlaced":false,"ChannelLayout":"7.1","BitDepth":24,"Channels":8,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"PGSSUB","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"French : Subtitles","DisplayTitle":"Und (PGSSUB)","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"PGSSUB","TimeBase":"1/1000","CodecTimeBase":"0/1","Title":"English : Subtitles","DisplayTitle":"Und (PGSSUB)","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":42160295,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for CyberPoison EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Affected codecs Encoder VAAPI Device 32902:16018 - H.264 (AVC) Adapter #0: 'Device 32902:16018' Id:16018 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 20.4.5 (b7066a4), Vendor: 32902) Frame Sizes: 32x32...4096x4096 Color Formats: NV12 Profiles: Main Profile (Level 6), High Profile (Level 6), Constrained Baseline Profile (Level 6) Decoder VAAPI Device 32902:16018 - H.265 (HEVC) Adapter #0: 'Device 32902:16018' Id:16018 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 20.4.5 (b7066a4), Vendor: 32902) Frame Sizes: max 8192x8192 Color Formats: NV12, P010 Profiles: Main Profile (Level 6.1), Main 10 Profile (Level 6.1) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Custom Info Checking: 'VAAPI Device 32902:16018 - H.264 (AVC)' Info Check successful - selecting 'VAAPI Device 32902:16018 - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: hevc, Mode: Custom Info Checking: 'VAAPI Device 32902:16018 - H.265 (HEVC)' Info Check successful - selecting 'VAAPI Device 32902:16018 - H.265 (HEVC)' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info VAAPI Device 32902:16018 - H.265 (HEVC) >> True True Hardware Codec Info VideoInput >> True True Same adapter (/dev/dri/renderD128), s... Info Scaling >> True True Info ToneMapping (when possible) >> True True Info VideoOutput >> True True Hardware encoder Info VAAPI Device 32902:16018 - H.264 (AVC) >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info hevc >> VAAPI vaapi_vld yuv420p10 3840x2160 >> scale_vaapi Info scale_vaapi >> VAAPI vaapi_vld yuv420p10 1280x720 >> tonemap_vaapi Info tonemap_vaapi >> VAAPI vaapi_vld nv12 1280x720 >> /app/emby/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-b528e859-a243-4c99-86ff-0fe6a4781d6c_1graph.txt" -copyts -start_at_zero -f matroska,webm -c:v:0 hevc -hwaccel:v:0 vaapi -hwaccel_device:v:0 /dev/dri/renderD128 -hwaccel_output_format:v:0 vaapi -i "/mnt/Cloud Storage/Cloud Storage Server 1/FR/Films4K[FR]/Assassin's Creed/Assassin's Creed 2016 MULTi 2160p UHD BluRay REMUX HEVC-GLaDOS.mkv" -filter_complex "[0:0]scale_vaapi@f1=w=1280:h=720,tonemap_vaapi@f2=format=nv12:matrix=bt709:primaries=bt709:transfer=bt709[f2_out0]" -map [f2_out0] -map 0:1 -sn -c:v:0 h264_vaapi -b:v:0 6616000 -g:v:0 72 -maxrate:v:0 6616000 -bufsize:v:0 13232000 -sc_threshold:v:0 0 -keyint_min:v:0 72 -profile:v:0 high -level:v:0 3.1 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -filter:a:0 "volume=2" -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/config/transcoding-temp/1325A4.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/config/transcoding-temp/1325A4_%d.ts" 13:04:30.347 ffmpeg version 4.3.0-emby_2021_02_27 Copyright (c) 2000-2021 the FFmpeg developers and softworkz for Emby LLC 13:04:30.347 built with gcc 8.3.0 (crosstool-NG 1.24.0) 13:04:30.347 Execution Date: 2021-04-28 13:04:30 13:04:30.409 [matroska,webm @ 0xaacb00] Could not find codec parameters for stream 4 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options 13:04:30.409 [matroska,webm @ 0xaacb00] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options 13:04:30.410 Input #0, matroska,webm, from '/mnt/Cloud Storage/Cloud Storage Server 1/FR/Films4K[FR]/Assassin's Creed/Assassin's Creed 2016 MULTi 2160p UHD BluRay REMUX HEVC-GLaDOS.mkv': 13:04:30.410 Metadata: 13:04:30.410 encoder : libebml v1.3.5 + libmatroska v1.4.8 13:04:30.410 creation_time : 2017-10-27T22:54:39.000000Z 13:04:30.410 Duration: 01:55:30.98, start: 0.000000, bitrate: 42160 kb/s 13:04:30.410 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], Level 153, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default) 13:04:30.410 Metadata: 13:04:30.410 title : Assassin's Creed 13:04:30.410 BPS : 34949542 13:04:30.410 BPS-eng : 34949542 13:04:30.410 DURATION : 01:55:30.924000000 13:04:30.410 DURATION-eng : 01:55:30.924000000 13:04:30.410 NUMBER_OF_FRAMES: 166177 13:04:30.410 NUMBER_OF_FRAMES-eng: 166177 13:04:30.410 NUMBER_OF_BYTES : 30279077664 13:04:30.410 NUMBER_OF_BYTES-eng: 30279077664 13:04:30.410 Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default) 13:04:30.410 Metadata: 13:04:30.410 title : French (Canada) : Dolby Digital 5.1 13:04:30.410 BPS : 448000 13:04:30.410 BPS-eng : 448000 13:04:30.410 DURATION : 01:55:30.976000000 13:04:30.410 DURATION-eng : 01:55:30.976000000 13:04:30.410 NUMBER_OF_FRAMES: 216593 13:04:30.410 NUMBER_OF_FRAMES-eng: 216593 13:04:30.410 NUMBER_OF_BYTES : 388134656 13:04:30.410 NUMBER_OF_BYTES-eng: 388134656 13:04:30.410 Stream #0:2: Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 768 kb/s 13:04:30.410 Metadata: 13:04:30.410 title : French (France) : Digital Theater System 5.1 13:04:30.410 BPS : 767999 13:04:30.410 BPS-eng : 767999 13:04:30.410 DURATION : 01:55:30.923000000 13:04:30.410 DURATION-eng : 01:55:30.923000000 13:04:30.410 NUMBER_OF_FRAMES: 649774 13:04:30.410 NUMBER_OF_FRAMES-eng: 649774 13:04:30.410 NUMBER_OF_BYTES : 665368576 13:04:30.410 NUMBER_OF_BYTES-eng: 665368576 13:04:30.410 Stream #0:3: Audio: truehd, 48000 Hz, 7.1, s32 (24 bit), Start-Time 0.032s 13:04:30.410 Metadata: 13:04:30.410 title : English : Dolby Atmos 7.1 13:04:30.410 BPS : 5895763 13:04:30.410 BPS-eng : 5895763 13:04:30.410 DURATION : 01:55:30.893000000 13:04:30.410 DURATION-eng : 01:55:30.893000000 13:04:30.410 NUMBER_OF_FRAMES: 8317071 13:04:30.410 NUMBER_OF_FRAMES-eng: 8317071 13:04:30.410 NUMBER_OF_BYTES : 5107863588 13:04:30.410 NUMBER_OF_BYTES-eng: 5107863588 13:04:30.410 Stream #0:4: Subtitle: hdmv_pgs_subtitle 13:04:30.410 Metadata: 13:04:30.410 title : French : Subtitles 13:04:30.410 BPS : 12731 13:04:30.410 BPS-eng : 12731 13:04:30.410 DURATION : 01:54:06.966000000 13:04:30.410 DURATION-eng : 01:54:06.966000000 13:04:30.410 NUMBER_OF_FRAMES: 1378 13:04:30.410 NUMBER_OF_FRAMES-eng: 1378 13:04:30.410 NUMBER_OF_BYTES : 10896619 13:04:30.410 NUMBER_OF_BYTES-eng: 10896619 13:04:30.410 Stream #0:5: Subtitle: hdmv_pgs_subtitle 13:04:30.410 Metadata: 13:04:30.410 title : English : Subtitles 13:04:30.410 BPS : 18223 13:04:30.410 BPS-eng : 18223 13:04:30.410 DURATION : 01:42:13.252000000 13:04:30.410 DURATION-eng : 01:42:13.252000000 13:04:30.410 NUMBER_OF_FRAMES: 1762 13:04:30.410 NUMBER_OF_FRAMES-eng: 1762 13:04:30.410 NUMBER_OF_BYTES : 13971141 13:04:30.410 NUMBER_OF_BYTES-eng: 13971141 13:04:30.413 Stream mapping: 13:04:30.413 Stream #0:0 (hevc) -> scale_vaapi (graph 0) 13:04:30.413 tonemap_vaapi (graph 0) -> Stream #0:0 (h264_vaapi) 13:04:30.413 Stream #0:1 -> #0:1 (ac3 (native) -> mp3 (libmp3lame)) 13:04:30.413 Press [q] to stop, [?] for help 13:04:30.563 Output #0, segment, to '/config/transcoding-temp/1325A4_%d.ts': 13:04:30.563 Metadata: 13:04:30.563 encoder : Lavf58.35.100 13:04:30.563 Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 6616 kb/s, Level 31, 23.98 fps, 90k tbn, 23.98 tbc (default) 13:04:30.563 Metadata: 13:04:30.563 encoder : Lavc58.62.100 h264_vaapi 13:04:30.563 Stream #0:1: Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (default) 13:04:30.563 Metadata: 13:04:30.563 encoder : Lavc58.62.100 libmp3lame 13:04:30.920 frame= 41 fps=0.0 q=-0.0 size= 1002kB time=00:00:02.42 bitrate=N/A throttle=off speed= 0x 13:04:31.188 [segment @ 0xb47940] Opening '/config/transcoding-temp/1325A4.m3u8.tmp' for writing 13:04:31.189 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.003000 Duration=3.003000 offset_pts=0 start_pts=0 Frames=72 filename=1325A4_0.ts 13:04:31.189 [segment @ 0xb47940] Opening '/config/transcoding-temp/1325A4_1.ts.tmp' for writing 13:04:31.439 frame= 107 fps=104 q=-0.0 size= 3450kB time=00:00:04.94 bitrate=11215.1kbits/s throttle=off speed=2.46x 13:04:31.743 [segment @ 0xb47940] Opening '/config/transcoding-temp/1325A4.m3u8.tmp' for writing 13:04:31.743 SegmentComplete=video:0 Index=1 Start=3.003000 End=6.006000 Duration=3.003000 offset_pts=0 start_pts=3003000 Frames=72 filename=1325A4_1.ts 13:04:31.743 [segment @ 0xb47940] Opening '/config/transcoding-temp/1325A4_2.ts.tmp' for writing 13:04:31.942 frame= 170 fps=111 q=-0.0 size= 5820kB time=00:00:07.70 bitrate=9030.4kbits/s throttle=off speed=3.45x 13:04:32.390 [segment @ 0xb47940] Opening '/config/transcoding-temp/1325A4.m3u8.tmp' for writing Still transcoding Note it works if you stay on the tab if i understand well Edited April 28, 2021 by CyberPoison
amb13 18 Posted June 9, 2021 Posted June 9, 2021 Hi Would love to use this, but does not seem to work at all for me. Using Emby version 4.6.2.0 and Release 2021.03.02.1 of Killstreams. I tried playing a 4k remux in 1080p quality in chrome and stream is transcoding and playing the movie. also tried to pause and stream is not killed for that either. Put the dll in /var/lib/emby/plugins/KillStreams.dll. Plugin is present in Emby and I can set the settings.
bakes82 167 Posted June 9, 2021 Author Posted June 9, 2021 I moved on, Emby is kind of a crappy product and the API is pretty horrible and they dont seem to want to support devs. It most likely just needs the api nuget updated to align to the versions, but who knows even when I used it the API didnt work on all devices in the same manor, some devices didnt have stop, some only had pause so was a crap shoot.
bakes82 167 Posted June 9, 2021 Author Posted June 9, 2021 10 minutes ago, amb13 said: I see, no problem. What did you move on to? Ive been a long time plex user. I dabbled in Jelly but its an emby clone so many of the issues still exist but I might try the 4k kill script its pretty similar to what this one was doing, though when using Jelly/Emby with Infuse on AppleTV the UI is way better, but infuse has its own issues, Plex so far is the reigning king when it comes to UI and ease of use especially when you pair it with shield/appletv.
Carlo 4561 Posted June 10, 2021 Posted June 10, 2021 Why give access to 4K content to users if you only intend to kill their sessions? Why not hide this media from them so they can't play it in the first place?
bakes82 167 Posted June 10, 2021 Author Posted June 10, 2021 Just now, cayars said: Why give access to 4K content to users if you only intend to kill their sessions? Why not hide this media from them so they can't play it in the first place? Because if you direct play the 4k its fine, if you're going to transcode because the client is setup wrong its bad. Pretty self explanatory.
Carlo 4561 Posted June 10, 2021 Posted June 10, 2021 Then I'd rather help my user fix the playback problem so they can direct play it assuming they have the bandwidth and equipment to do so. That's what I've done. Those that can't play the 4K material don't get access to it on my server.
