Carlo 4561 Posted April 19, 2021 Posted April 19, 2021 That's ok the feed was from your house. Thanks for everything you do here on the forums and elsewhere. It's greatly appreciated! This is the best managed forum I've used in years! 1 1
ebr 16332 Posted April 20, 2021 Posted April 20, 2021 My inbox automatically goes to that view now so I guess it is a persistent setting once you click it. LOL Abo. 1
Abobader 3485 Posted May 4, 2021 Author Posted May 4, 2021 Good day, Dark theme update, let me know if thing change somewhere. My best
Spaceboy 2573 Posted May 21, 2021 Posted May 21, 2021 is it possible to show which user has marked the thread as solved? currently the user that provided the solution is indicated. An example of why it would be useful 2 1
softworkz 5133 Posted May 21, 2021 Posted May 21, 2021 I've sometimes been wondering about this as well...
Abobader 3485 Posted May 22, 2021 Author Posted May 22, 2021 Interesting. Well, by default normally the OP, but we enable the option as the mod's team can make this as well, the reason, many solve answer made, and OP did not select the best answer, so to help the other whom looking to the same issue will find the answer. But good point, just notice that mod's public action do not apply to "best answer". I will see if we can solve this request. 3
Abobader 3485 Posted June 10, 2021 Author Posted June 10, 2021 ah, I removed/deleted my 2 last posts about the group highlight, since it conflict with best answer.
softworkz 5133 Posted June 10, 2021 Posted June 10, 2021 1 minute ago, Abobader said: ah, I removed/deleted my 2 last posts about the group highlight, since it conflict with best answer. It's a great idea, though! Didn't you have different colors for best answer and group highlight? 1
Abobader 3485 Posted June 10, 2021 Author Posted June 10, 2021 6 minutes ago, softworkz said: It's a great idea, though! Didn't you have different colors for best answer and group highlight? I agree buddy, I temp remove it, I need to find if it a bug, if not, then tomorrow after like 2 to 3 cups of coffee I will fix that 1
ebr 16332 Posted June 11, 2021 Posted June 11, 2021 Honestly, I'm not crazy about this. When you start "highlighting" multiple different types of posts they cease to become a highlight and you're never exactly sure why they are different. 1
Abobader 3485 Posted June 11, 2021 Author Posted June 11, 2021 2 hours ago, ebr said: Honestly, I'm not crazy about this. When you start "highlighting" multiple different types of posts they cease to become a highlight and you're never exactly sure why they are different. Good point indeed.
softworkz 5133 Posted June 11, 2021 Posted June 11, 2021 How about indicating staff posts by some kind of visual emphasis in the left column (poster name and avatar)?
Happy2Play 9811 Posted June 11, 2021 Posted June 11, 2021 4 minutes ago, softworkz said: How about indicating staff posts by some kind of visual emphasis in the left column (poster name and avatar)? Not sure I follow. Something different then what is already there?
softworkz 5133 Posted June 11, 2021 Posted June 11, 2021 2 minutes ago, Happy2Play said: Not sure I follow. Something different then what is already there? I meant something more prominent. That little icon isn't really a clear indication and reading the group text below and making sense of it - not everybody's doing that.
Abobader 3485 Posted June 12, 2021 Author Posted June 12, 2021 15 hours ago, softworkz said: I meant something more prominent. That little icon isn't really a clear indication and reading the group text below and making sense of it - not everybody's doing that. I think I know what you mean, like "Emby Staff" icon for all the teams (admin/mod/dev/support), right?
softworkz 5133 Posted June 12, 2021 Posted June 12, 2021 1 hour ago, Abobader said: I think I know what you mean, like "Emby Staff" icon for all the teams (admin/mod/dev/support), right? Yea, something like that, or maybe a slight border or shading.. Done in 30s, so not really perfect and just one idea from many possibilities. It might be worth to take a look how it is done in other IPS forums. 1
Abobader 3485 Posted June 12, 2021 Author Posted June 12, 2021 48 minutes ago, softworkz said: It might be worth to take a look how it is done in other IPS forums. No my friend, we do not do that. Well, a forum admin normally provide what his community need from design to operational, nothing from a wow factor or be special design will fit our need here. The main owner of the forum/software (Luke & Ebr) always wanted clean and simple design. Back to the subject, we will try now to stay away from the "border" thing, unserinfo (what under the avatar - left panel) used to have these info as we modify it in the past, so going back simply design, even groups icons been removed. I am thinking of something this week, to let the post of dev/support noticeable to new user, just give me time.
softworkz 5133 Posted June 12, 2021 Posted June 12, 2021 8 minutes ago, Abobader said: No my friend, we do not do that. Well, a forum admin normally provide what his community need from design to operational, nothing from a wow factor or be special design will fit our need here. Probably you are referring to the various IPS plugins that are available for "enhancing" the user presentation. I have looked through them some time ago and these are all really over-exaggerating the user presentation. That's not what I meant, but anyway...: 13 minutes ago, Abobader said: I am thinking of something this week, to let the post of dev/support noticeable to new user, just give me time. I'm sure you'll find a nice and clean way! 1
Abobader 3485 Posted June 13, 2021 Author Posted June 13, 2021 What I am thinking right now, you see where the word "Author", same when we used the highlight group option, that one way coming to my mind at the moment, but still thinking of better way. No, I am not referring to IPS plugin for the past, we normally modify the userinfo template for that. 1
Abobader 3485 Posted August 23, 2021 Author Posted August 23, 2021 Image display posting size been increased. @GrimReaper76 1
Carlo 4561 Posted August 23, 2021 Posted August 23, 2021 1 hour ago, Abobader said: Image display posting size been increased. @GrimReaper76 What's it been expanded to? Do you know off the top of your head?
Abobader 3485 Posted August 24, 2021 Author Posted August 24, 2021 15 hours ago, cayars said: What's it been expanded to? Do you know off the top of your head? The settings was: Saved image max: 1200x1200 Display: 1200x7** Now: Original image size saving. Display: 1200x1200 1 1
Abobader 3485 Posted October 14, 2021 Author Posted October 14, 2021 Good day, I am closing this since soon we will update the forum and as always will open new thread. Thanks. My best 2
