pünktchen 1410 Posted February 21, 2021 Posted February 21, 2021 How can i remove a "quote" in the mobile view on my smartphone? 1
Abobader 3485 Posted February 21, 2021 Author Posted February 21, 2021 6 hours ago, pünktchen said: How can i remove a "quote" in the mobile view on my smartphone? By simply do not login to your account.
pünktchen 1410 Posted February 21, 2021 Posted February 21, 2021 I mean if i quote someone, how can i remove the quote in my own post. There's no Ctrl+RMB on my smartphone.
ebr 16332 Posted February 21, 2021 Posted February 21, 2021 1 hour ago, pünktchen said: I mean if i quote someone, how can i remove the quote in my own post. There's no Ctrl+RMB on my smartphone. Other than backspacing over it, I'm not sure and not sure if that even works. On anything with a keyboard, I use ctrl-Z.
pünktchen 1410 Posted February 21, 2021 Posted February 21, 2021 34 minutes ago, ebr said: Other than backspacing over it Doesn't work. What's missing is a button for a "code editor", so one can see the code behind quotes, links and the like as cleartext. 1
ebr 16332 Posted February 21, 2021 Posted February 21, 2021 1 minute ago, pünktchen said: Doesn't work. What's missing is a button for a "code editor", so one can see the code behind quotes, links and the like as cleartext. That exists in the desktop theme - it is the "Source" button on the editor. There is only so much that can be done on a phone though I guess.
CBers 7554 Posted February 21, 2021 Posted February 21, 2021 8 minutes ago, pünktchen said: Doesn't work. What's missing is a button for a "code editor", so one can see the code behind quotes, links and the like as cleartext. 6 minutes ago, ebr said: That exists in the desktop theme - it is the "Source" button on the editor. There is only so much that can be done on a phone though I guess. Had the same issues on my phone as well. Only way I found to remove it, was to go BACK, start again and use the CLEAR EDITOR when you redo your post.
Abobader 3485 Posted February 23, 2021 Author Posted February 23, 2021 On 2/21/2021 at 4:44 PM, pünktchen said: I mean if i quote someone, how can i remove the quote in my own post. There's no Ctrl+RMB on my smartphone. On 2/21/2021 at 6:54 PM, CBers said: Had the same issues on my phone as well. Only way I found to remove it, was to go BACK, start again and use the CLEAR EDITOR when you redo your post. I add source for mobile, can you please test and see if that what you want, thanks. 1
CBers 7554 Posted February 23, 2021 Posted February 23, 2021 4 hours ago, Abobader said: I add source for mobile, can you please test and see if that what you want, thanks. Thanks Abo, although it's not just simple HTML any more, but based on HTML5. Might be useful though. Any chance of adding the "code" option as well please?. I've tried to use it as before, but it doesn't seem to work. Thanks.
Abobader 3485 Posted February 23, 2021 Author Posted February 23, 2021 2 hours ago, CBers said: Thanks Abo, although it's not just simple HTML any more, but based on HTML5. Might be useful though. Any chance of adding the "code" option as well please?. I've tried to use it as before, but it doesn't seem to work. Thanks. Done.
Abobader 3485 Posted February 23, 2021 Author Posted February 23, 2021 2 hours ago, CBers said: Thanks Abo, although it's not just simple HTML any more, but based on HTML5. How about now?
CBers 7554 Posted February 23, 2021 Posted February 23, 2021 7 minutes ago, Abobader said: Done. Looks like the SOURCE option is now gone with the addition of the CODE button.
CBers 7554 Posted February 23, 2021 Posted February 23, 2021 28 minutes ago, Abobader said: Try to refresh the page. Tried that. Logged out of the website and force stopped Chrome browser but still no different. Perhaps @pünktchen can try.
pünktchen 1410 Posted February 23, 2021 Posted February 23, 2021 20 minutes ago, CBers said: Perhaps @pünktchen can try. I also only see the "code" button before the "bold" button. No "source" button here. 1
pünktchen 1410 Posted February 23, 2021 Posted February 23, 2021 Fine, thanks. Although i didn't have thought there's such a complex code behind a quote.
CBers 7554 Posted February 23, 2021 Posted February 23, 2021 (edited) 10 minutes ago, Abobader said: Ok, how about now? That's better, thanks Abo. Might it be worth having these options available to the desktop version as well? 1 minute ago, pünktchen said: Fine, thanks. Although i didn't have thought there's such a complex code behind a quote. Me neither. Edited February 23, 2021 by CBers
ebr 16332 Posted February 23, 2021 Posted February 23, 2021 1 hour ago, CBers said: Might it be worth having these options available to the desktop version as well? They are both already there. 1
mastrmind11 722 Posted February 23, 2021 Posted February 23, 2021 any way to get the "mark site read" link pop to the top of the main home page? 2-3 clicks vs the old 1 is pretty annoying.
Abobader 3485 Posted February 24, 2021 Author Posted February 24, 2021 Desktop or mobile? In desktop, it's on the top page. In mobile, it on the same main menu. I am confuse here about your request.
CBers 7554 Posted February 24, 2021 Posted February 24, 2021 14 hours ago, ebr said: They are both already there. There's no SOURCE button. 5 hours ago, Abobader said: I am confuse here about your request. I think @mastrmind11 just wants it visible, rather than having to go through the menu.
mastrmind11 722 Posted February 24, 2021 Posted February 24, 2021 (edited) 9 hours ago, Abobader said: Desktop or mobile? In desktop, it's on the top page. In mobile, it on the same main menu. I am confuse here about your request. the old forum, when you clicked "mark site read", it would take you back to the main forum page and position you at the top of the page. on the new forum, when you click "mark site read", you just sit on the same page and position and have to scroll up to the top and click "home" to have the same effect, which is 2 more actions than previously. Edited February 24, 2021 by mastrmind11
ebr 16332 Posted February 24, 2021 Posted February 24, 2021 5 hours ago, CBers said: There's no SOURCE button. There is for me... However, I don't think this is really necessary and probably will lead to people screwing up their posts.
pwhodges 2033 Posted February 24, 2021 Posted February 24, 2021 And there isn't for me: I like to have it to un-screw-up posts when the editor gets in a mess (which it can, you know!). Paul 1
