puntipik 0 Posted November 16, 2020 Posted November 16, 2020 Hi, I have the newest emby server in my network and some clients (fire tv sticks) where everthing is working perfect. but I have one old windows 7 media center running with MB classic on it. But the MediaCenter pc is too old to run HEVC H.265 videos as direct stream. But I didn't got it to work, that emby server will transcode this codecs for my MB classic. Is there a possibilty to force this, or is MB classic only able to direct stream, but not ask the server for a transcode? br puntipk
Luke 42237 Posted November 16, 2020 Posted November 16, 2020 Hi, we would need to add an option into the app. Have you tried our new emby theater app? https://emby.media/emby-theater.html It is designed to fully replace windows media center.
puntipik 0 Posted November 18, 2020 Author Posted November 18, 2020 hi, yes I know the emby theater app, but therefore a premium account is needed for playback. and I also need my mediacenter pc with media center because of other 'old' stuff so for the moment, there is no option I can try to force streaming of h265 at the media center instead of direct play, right? br
ebr 16331 Posted November 18, 2020 Posted November 18, 2020 6 hours ago, puntipik said: so for the moment, there is no option I can try to force streaming of h265 at the media center instead of direct play, right? You could put them in a location that is inaccessible to the WMC machine and then the app would be forced to stream them.
puntipik 0 Posted November 18, 2020 Author Posted November 18, 2020 ok thx for the tip, will try it next weekend
