Happy2Play 9802 Posted November 21, 2020 Posted November 21, 2020 1 minute ago, justinrh said: @Happy2Play I'm getting lost here. Can you just tell me what I need to do to make this work? It looks like I have they same situation as you, yet it is not working. Does this need to be an audio book instead of music? According to that the Album is NIV: The Listener's Bible. I would assume everything has that album name vs the actual folder name ie 1 Genesis. But your Metadata Manager image suggest all tracks in one folder/Album "NIV: The Listener's Bible".
justinrh 264 Posted November 21, 2020 Author Posted November 21, 2020 Gotcha. So, I'll have to use the metadata mgr to rename the albums to be like the folder names. Why did Emby not pick this up? Is it because the tags were already set to the generic name and Emby used it?
Happy2Play 9802 Posted November 21, 2020 Posted November 21, 2020 (edited) What is the actual folder structure? To me it looks like you need to change the embedded metadata though. Edited November 21, 2020 by Happy2Play
justinrh 264 Posted November 21, 2020 Author Posted November 21, 2020 See the earlier post. So, with audio, tags rules the day.
Solution Happy2Play 9802 Posted November 21, 2020 Solution Posted November 21, 2020 1 minute ago, justinrh said: So, with audio, tags rules the day. Yes all audio is primarily run by embedded tags.
