lowe1739 3 Posted November 13, 2020 Posted November 13, 2020 For some reason my Metadata is no longer pulling from any sources. example below. Wonder Woman, the screen cap 1 shows the correct info for themoviedb but even after refreshing and choosing replace image it just shows what is in the other two screen caps any help would be appreciated, just happened this week.
Luke 42206 Posted November 13, 2020 Posted November 13, 2020 Hi, try using the Identify feature and see if that helps.
lowe1739 3 Posted November 13, 2020 Author Posted November 13, 2020 Hey Luke, I thought I was, how do i confirm that is turned on?
Luke 42206 Posted November 13, 2020 Posted November 13, 2020 Hi, that's just the metadata editor. Try clicking the 3-dot menu on the item, then select Identify. Before doing that I would also check your settings for that library in emby library setup. What metadata providers are enabled, and in what order?
lowe1739 3 Posted November 13, 2020 Author Posted November 13, 2020 Identify doesn't bring up anything I have TheMovieDB and the open Movie Database in that order for my movie folder for Movie image fetchers have Themovidedb, FanArt and Screen Grabber in that order.
Carlo 4561 Posted November 13, 2020 Posted November 13, 2020 Hello @Iowe1739 Want to do a remote session via TeamViewer and let me take a look at your setup and give you a hand getting this working? If so install TeamViewer from www.teamviewer.com and send me via PM the userid & one-time use password it shows you on launch. Carlo
lowe1739 3 Posted November 13, 2020 Author Posted November 13, 2020 7 minutes ago, cayars said: Hello @Iowe1739 Want to do a remote session via TeamViewer and let me take a look at your setup and give you a hand getting this working? If so install TeamViewer from www.teamviewer.com and send me via PM the userid & one-time use password it shows you on launch. Carlo wow...that's seems shady but sure worse thing you can do is delete all my data i suppose. give me a min to set that up. 1
Carlo 4561 Posted November 13, 2020 Posted November 13, 2020 Just now, lowe1739 said: wow...that's seems shady but sure worse thing you can do is delete all my data i suppose. give me a min to set that up. It's a service we sometimes offer at Emby for certain types of things that may be easier to solve by us seeing it than asking tons of config questions and asking for logs, etc... Look at the bottom of this page: https://emby.media/community/index.php?/staff/ and you'll see me listed as part of the staff for Emby. We're going to be doing this together and I'll open a chat with you. You'll see everything I'm looking at and we'll be communicating (you'll do most of the driving actually).
lowe1739 3 Posted November 13, 2020 Author Posted November 13, 2020 sent a message to you with the info
lowe1739 3 Posted November 13, 2020 Author Posted November 13, 2020 actually i did a reboot of my server it might be working now....testing a few things
