limore 0 Posted November 13, 2020 Posted November 13, 2020 I have specified in advanced settings under library that it saves all metadata in a specified folder for all of my (two) libraries. When I got to refresh metadata, it re-downloads the metadata to the folders within my library files. any ideas why the preferences are being overidden? I will also add that the preferences are displaying the path to the metadata folder, so it is clear that emby preferences can correctly locate the file path that I am specifying. thanks, Limore
limore 0 Posted November 13, 2020 Author Posted November 13, 2020 ok. I see my error. It moved the metadata, but the .nfo files stay in the libraries. Anyway to move those? They kinda muddy up the folder structure. Limore
Luke 42240 Posted November 13, 2020 Posted November 13, 2020 Hi, no. Best you can do is turn off the option to save nfo files and then delete your existing ones.
limore 0 Posted November 13, 2020 Author Posted November 13, 2020 is there a way to hide it in the directory but have emby still able to access it? Feature request would be to be able to move that to and alternate location. Thanks, Limore
Luke 42240 Posted November 13, 2020 Posted November 13, 2020 Quote is there a way to hide it in the directory but have emby still able to access it? Not that I'm aware of. You might be able to find a utility to mark them as hidden in bulk.
