neik 874 Posted November 11, 2020 Posted November 11, 2020 Just rediscovered Auto-Organize and it's working great so far. Unfortunately though, the mobile view doesn't support scrolling so it is not really usable while on your smartphone. Is it possible to "fix" this or does anyone know a working workaround?
GrimReaper 4912 Posted November 11, 2020 Posted November 11, 2020 (edited) Just now, neik said: Just rediscovered Auto-Organize and it's working great so far. Unfortunately though, the mobile view doesn't support scrolling so it is not really usable while on your smartphone. Is it possible to "fix" this or does anyone know a working workaround? Never had to use it from Android App, but I guess you could just access your server from any mobile browser > switch to Desktop mode? Edit: Or, within the mobile app, Settings>Display>Display mode: Desktop, will it be scrollable then? Edited November 11, 2020 by GrimReaper76 1
neik 874 Posted November 12, 2020 Author Posted November 12, 2020 Thanks for the workaround. Nevertheless, implementing it to the app would still be nice. If I have an app I don't want to fall back to the browser..
GrimReaper 4912 Posted November 12, 2020 Posted November 12, 2020 Yeah, I use it regularly for Playback Reporting plugin which isn't even listed in mobile app under plugins, so no choice.
