lucasbuck 2 Posted November 10, 2020 Posted November 10, 2020 I have some movies that are split into CD 1 and CD 2. I've tried setting the category up as movie, mixed, and home. Regardless, when I go to the subfolder of the movie it just has play, which plays CD 1. CD 2 doesn't show up. Am I doing something wrong, or should I just go through and join them with MKVToolbox? Really I don't need them merged, CD 2 is usually bonus stuff, so I would prefer to keep them separate. I just want both to show up. Thanks!
ebr 16310 Posted November 10, 2020 Posted November 10, 2020 8 minutes ago, lucasbuck said: I don't need them merged, CD 2 is usually bonus stuff Hi. Why not use our special features functionality for that then?
lucasbuck 2 Posted November 10, 2020 Author Posted November 10, 2020 I haven't seen that option. I used to use Media Browser so I'm just learning Emby.
ebr 16310 Posted November 10, 2020 Posted November 10, 2020 Okay, that will work much better for you. Please see: Movie Naming
Carlo 4561 Posted November 10, 2020 Posted November 10, 2020 Hi, Just make sure the only video files in that directory are the split files. Also make sure the folder name is the movie name itself ie "Top Gun (1986)".
