neo1994 0 Posted November 9, 2020 Posted November 9, 2020 (edited) Hi there, i own a DS218+ had emby running for best part of a year now, over the last 24 hours during the night my emby on my synology is making it run at 99% Disk and utilisation. As soon as i stop Emby it goes back down to 1/2%. I have tried reinstalling old emby and 4.5 and 4.6 beta also, I have also reset the DSM OS and reinstalled it. I ran HTOP and its showing mono something thats taking up all the processing... although my cpu and ram is 8-10%. My DS218+ is making a huge whirring noise 24/7 and its not stopped unless i stop emby anyone got any assistance? As you can see from the screenshot the drops is when i restart emby embyserver.txt embyserver-63740553281.txt hardware_detection-63740553300.txt Edited November 9, 2020 by neo1994
Happy2Play 9812 Posted November 9, 2020 Posted November 9, 2020 Looks like it is stuck in a loop processing a backdrop for client/app, there are over 4300+ errors on this specific database item (36544). 2020-11-09 21:14:57.170 Info Server: http/1.1 GET http://xx.x.xxx.105:8096/emby/Items/36544/Images/Backdrop/0?Accept=webp&MaxWidth=1920&EnableImageEnhancers=true&Tag=788953375ca87ebd3e24800a5a2bf604. UserAgent: Dalvik/2.1.0 (Linux; U; Android 5.1.1; AFTT Build/LVY48F) 2020-11-09 21:14:57.177 Error Server: Error processing request *** Error Report *** Version: 4.6.0.5 Command line: /volume1/@appstore/EmbyServer/system/EmbyServer.dll -programdata /volume1/Emby -ffdetect /var/packages/EmbyServer/target/bin/ffdetect -ffmpeg /var/packages/EmbyServer/target/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/bin/ffprobe -nolocalportconfig -ignore_vaapi_enabled_flag -updatepackage emby-server-synology_{version}_x86_64.spk Operating system: Linux version 4.4.59+ (root@build3) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP PREEMPT Wed Jul 8 03:21:29 CST 2020 Framework: .NET Core 3.1.7 OS/Process: x64/x64 Runtime: volume1/@appstore/EmbyServer/system/System.Private.CoreLib.dll Processor count: 2 Data path: /volume1/Emby Application path: /volume1/@appstore/EmbyServer/system MediaBrowser.Common.Extensions.ResourceNotFoundException: MediaBrowser.Common.Extensions.ResourceNotFoundException: 36544 does not have an image of type Backdrop at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Api TargetSite: Void MoveNext() 2020-11-09 21:14:57.178 Info Server: http/1.1 Response 404 to xx.x.xxx.104. Time: 7ms. Pretty sure you would have to go through the api to find out the exact image. But will wait to see what a dev says.
neo1994 0 Posted November 9, 2020 Author Posted November 9, 2020 Okay thanks for looking into this.. This is a fresh install with no users as well, something strange going on i even removed the emby folder inside before fresh install and still doing this
Luke 42243 Posted November 10, 2020 Posted November 10, 2020 Hi, did you try navigating through the folders on the file system to see which one is consuming the most space?
