mavs 1 Posted November 20, 2020 Posted November 20, 2020 On 11/14/2020 at 4:29 PM, jordy said: Ok, I understand what you want me to do , what I don't understand is HOW to do it! Here is the path to the TV Series images C:\ProgramData\Geekzone\EPG Collector\Images\TV Series\8 Out Of 10 Cats Does Countdown.jpg NOW, how do I give that an HTTP address? Sorry to jump in from nowhere but could you not do something like this: file://C:\ProgramData\Geekzone\EPG Collector\Images\TV Series\8 Out Of 10 Cats Does Countdown.jpg
jordy 284 Posted November 20, 2020 Author Posted November 20, 2020 (edited) I have tried that but no joy with Emby as it currently only accepts http/s addresses. Although, hopefully Luke is going to change that. And for some reason, the double slash after file: doesn't work with either Windows Explorer or FireFox, but add a 3rd slash and they both work just fine. thanks anyway. Edited November 20, 2020 by jordy additional txt
Luke 42243 Posted November 20, 2020 Posted November 20, 2020 I haven't tested what I mentioned earlier but I took a quick look at it and it seems like it might already work.
jordy 284 Posted November 21, 2020 Author Posted November 21, 2020 I have already tried it and it didn't work. But I'll try again
cristiallx 0 Posted December 1, 2020 Posted December 1, 2020 On 10/11/2020 at 17:38, cayars said: Hi, Emby can fully support TV Station logos and program images. Let's get some basic info. I take it you are using the Adelaide listing from https://www.xmltv.net/ as your guide source? What do you need EPGCollector for? Hi cayars, i try to find a solution or a good answer for this issue: Every 2 days i must to upload logo channel again because disappear. i dont have time to upload every 2 days the logo channel what happens??? thank you
Carlo 4561 Posted December 1, 2020 Posted December 1, 2020 Just to make sure we understand completely, where are you uploading the graphic to?
cristiallx 0 Posted December 1, 2020 Posted December 1, 2020 27 minutes ago, cayars said: Just to make sure we understand completely, where are you uploading the graphic to? i go live tv/channel/click on ... and edit image where i can upload a logo for channel wich it is working but for a short time if it is upload why disappear?
Carlo 4561 Posted December 1, 2020 Posted December 1, 2020 I wonder if Emby is replacing your images during guide refresh? Can you change a logo, then do a full guide refresh. After it's complete go the guide and do a browser refresh and see if it's still your logo or if it got replaced. Let us know.
cristiallx 0 Posted December 1, 2020 Posted December 1, 2020 1 hour ago, cayars said: I wonder if Emby is replacing your images during guide refresh? Can you change a logo, then do a full guide refresh. After it's complete go the guide and do a browser refresh and see if it's still your logo or if it got replaced. Let us know. nothing happens if I do so, I don't know what happens but in about 2 or 3 days they disappear my playlist is on the ace media server but only if I delete a channel and add it again then logo disappear and i know tahat but generally I don't do that and the logos on all channels disappear ?????
Luke 42243 Posted December 2, 2020 Posted December 2, 2020 Probably because they're gone from your m3u source?
cristiallx 0 Posted December 3, 2020 Posted December 3, 2020 21 hours ago, Luke said: Probably because they're gone from your m3u source? nop m3u it is the same i only chnage 2 or 3 channel and i understand i will lose logo for that but the other one itis there from the start and never change but the logo dissaper regulary after 2 or 3 ddays i think something it is wrong on the server
Luke 42243 Posted December 3, 2020 Posted December 3, 2020 4 minutes ago, cristiallx said: nop m3u it is the same i only chnage 2 or 3 channel and i understand i will lose logo for that but the other one itis there from the start and never change but the logo dissaper regulary after 2 or 3 ddays i think something it is wrong on the server We'd have to look at an example. How to report a problem. Thanks.
cristiallx 0 Posted December 13, 2020 Posted December 13, 2020 On 03/12/2020 at 14:24, Luke said: We'd have to look at an example. How to report a problem. Thanks. Hi again I want to ask you if it is possible to wacht a link like this one :" https://newdmn.icu/stream/38725.html " like a normal channel in live tv and hoe to do it\ or to transform this one into a m3u ? thank you
Luke 42243 Posted December 13, 2020 Posted December 13, 2020 2 hours ago, cristiallx said: Hi again I want to ask you if it is possible to wacht a link like this one :" like a normal channel in live tv and hoe to do it\ or to transform this one into a m3u ? thank you Hi, no, you can't have urls that only point to a webpage.
