sebasmiles 8 Posted November 9, 2020 Posted November 9, 2020 Server: Unraid 6.8.2 Running docker version of Emby. M/B: ASRock B75 Pro3-M CPU: Intel® Xeon® CPU E3-1225 V2 @ 3.20GHz Memory: 16 GiB DDR3 Kernel: Linux 4.19.98-Unraid x86_64 Problem: When using chrome and playing this specific file, it loads for a long time, then plays something for a fraction of a second and goes back to main menu. I tried re-starting chrome, yet the issue persists. I tried watching the same on firefox on the same system, and it worked just fine. Normally I would just go and try to get a different version of the file, but figured best to post here in case it may be a more widespread issue. Other files seem to be ok. embyserver.txt ffmpeg-remux-4676798a-da55-4289-b8c5-736aacafdfc1_1.txt
Luke 42241 Posted November 9, 2020 Posted November 9, 2020 Hi, if you lower the in-app quality setting to force a full transcode, how does that compare?
sebasmiles 8 Posted November 9, 2020 Author Posted November 9, 2020 (edited) Well, I went to see something else for a while and came back after I saw your message. I was going to figure out how to force the transcode (probably thru profile settings since the video didn't run long enough) but I went ahead and gave it another try...and it worked. I am utterly confused as to what changed. I will leave the files here, but I guess this is closed unless you want me to test something else for you. ffmpeg-remux-b1fe9da8-6fdd-4bb1-8101-8257a2c9b1ec_1.txt embyserver.txt Edited November 9, 2020 by sebasmiles
Luke 42241 Posted November 9, 2020 Posted November 9, 2020 These two examples are streaming the original to the browser video player. For some reason the browser video player doesn't like one of them, so that's why forcing the transcode most likely would have resolved it. It's just that it's difficult to do that automatically because the steam looks like something the video player should be able to handle. 1
sebasmiles 8 Posted November 9, 2020 Author Posted November 9, 2020 Yeah, I just don't get why it got jammed with it originally and seemingly wihtout changes it worked the second time. Weird...
Solution sebasmiles 8 Posted November 9, 2020 Author Solution Posted November 9, 2020 @Luke So I figured it out, in the meantime my system automatically downloaded a different version of the episode and replaced it so it worked the second time because it wasn't the same file.... oh well.
