GWTPqZp6b 50 Posted November 7, 2020 Posted November 7, 2020 I recently migrated Emby into a containerized setup using the official beta container and am facing a challenge with LiveTV streaming. I have identical settings configured in my VM based Emby and the containerized Emby re M3U/XMLTV, firewall is appropriately configured but my containerized setup fails where as my VM based one works correctly. I suspect the issue is the MACVLAN interface and multicast traffic, has anyone run into issues like this before, and any tips to resolve.
GWTPqZp6b 50 Posted November 7, 2020 Author Posted November 7, 2020 scratch this, its starting to look more like a file access/transcode problem. embyserver.log https://hastebin.base8.org/sixikegewe.apache hardware detect: https://hastebin.base8.org/lexosivipu.pl
GWTPqZp6b 50 Posted November 13, 2020 Author Posted November 13, 2020 Hi Luke, thanks for checking in. I think this issue could be related to the other transcode issue that I raised in another thread. I followed up there with Softworkz who was looking at that issue. But yes, the issue still exists that a CIFS mounted transcode folder doesnt work with liveTV, but does work movies/TV content). Theres logs in the linked thread.
Luke 42246 Posted November 15, 2020 Posted November 15, 2020 Actually no, I think this error is simply your file system denying write access: System.AggregateException: System.AggregateException: One or more errors occurred. (Access to the path '/mnt/Transcode/transcoding-temp/52d4eb3b26a84aa28220eebff3d5bfe5.ts' is denied.) ---> System.UnauthorizedAccessException: Access to the path '/mnt/Transcode/transcoding-temp/52d4eb3b26a84aa28220eebff3d5bfe5.ts' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- So that's something you'll need to look into.
GWTPqZp6b 50 Posted November 15, 2020 Author Posted November 15, 2020 Thanks Luke. Can you help guide where I should look as I verified the user that Emby is running at can read/write to the specified folder. Transcoded TV/Movies are also handled without issue and they record to the same mount. Is LiveTV processed with a different UID/GID? I'm kinda scratching my head at the moment.
GWTPqZp6b 50 Posted November 15, 2020 Author Posted November 15, 2020 (edited) For example, if I log into my container I can verify I can read/write as user 1001 in the /mnt/transcode folder. This is why I believed the issue was something to do with LiveTV being different from TV?Movies etc [root@dockerhost ~]# docker exec -it emby sh / # ps | grep Emby 196 1001 0:21 /system/EmbyServer -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 / # ls -lR /mnt/Transcode/ /mnt/Transcode/: total 0 drwxrwxr-x 2 1001 1001 0 Nov 15 18:53 transcoding-temp /mnt/Transcode/transcoding-temp: total 0 / # echo hello! > /mnt/Transcode/transcoding-temp/ForLuke / # cd /mnt/Transcode/transcoding-temp/ /mnt/Transcode/transcoding-temp # ls -l total 1 -rw-rw-r-- 1 1001 1001 7 Nov 15 18:54 ForLuke /mnt/Transcode/transcoding-temp # cat ForLuke hello! Edited November 15, 2020 by GWTPqZp6b tidied code for readability
GWTPqZp6b 50 Posted November 15, 2020 Author Posted November 15, 2020 (edited) Working movie playback https://hastebin.base8.org/ovepakayek.coffeescript specifically the ffmpeg string /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-a0d30ed0-47e5-4230-a904-0ad081025951_1graph.txt" -copyts -start_at_zero -init_hw_device "cuda=cud0:0" -filter_hw_device cud0 -f matroska,webm -c:v:0 hevc -i "/opt/gd-media/Movies/2 Fast 2 Furious (2003)/2.Fast.2.Furious.2003.2160p.UHD.BluRay.REMUX.HDR.HEVC.DTS-X-EPSiLON.mkv" -filter_complex "[0:0]hwupload_cuda@f1,scale_cuda@f2=w=1280:h=720:format=nv12,setsar@f3=sar=sar[f3_out0]" -map [f3_out0] -map 0:1 -sn -c:v:0 h264_nvenc -b:v:0 3616002 -g:v:0 72 -maxrate:v:0 3616002 -bufsize:v:0 7232004 -sc_threshold:v:0 0 -keyint_min:v:0 72 -profile:v:0 high -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/mnt/Transcode/transcoding-temp/7A7935.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/mnt/Transcode/transcoding-temp/7A7935_%d.ts" and successfully writing 19:10:37.991 Output #0, segment, to '/mnt/Transcode/transcoding-temp/7A7935_%d.ts': 19:10:37.991 Metadata: 19:10:37.991 encoder : Lavf58.35.100 19:10:37.991 Stream #0:0: Video: h264 (h264_nvenc) (High), cuda, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 3616 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default) 19:10:37.991 Metadata: 19:10:37.991 encoder : Lavc58.62.100 h264_nvenc 19:10:37.991 Side data: 19:10:37.991 cpb: bitrate max/min/avg: 3616002/0/3616002 buffer size: 7232004 vbv_delay: N/A 19:10:37.991 Stream #0:1(eng): Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp (24 bit), 192 kb/s (default) 19:10:37.991 Metadata: 19:10:37.991 encoder : Lavc58.62.100 libmp3lame I'll grab the LiveTV logs now Edited November 15, 2020 by GWTPqZp6b
GWTPqZp6b 50 Posted November 15, 2020 Author Posted November 15, 2020 (edited) LiveTV stream here I think the file access error is a symptom of something else failing, possibly in relation to xteve? Is this possibly related? 2020-11-15 19:19:03.986 Error GraphRunner: GraphRunnerTimestampFixup Edited November 15, 2020 by GWTPqZp6b
Luke 42246 Posted November 27, 2020 Posted November 27, 2020 Are you still having an issue with this?
GWTPqZp6b 50 Posted November 27, 2020 Author Posted November 27, 2020 (edited) I am although I haven't looked at this again after having debugged it to the point that I couldn't figure out what was wrong with it. Emby has the ability to read/write the SMB mounted share (the same as it does correctly with TV/Movies) but it doesn't work with Live TV for some reason. I had hoped it might just start working with the latest beta but its still broken in 4.6.0.6 in my system. EDIT: I have a non containerized version of 4.6.0.6 running with identical LiveTV setup and a identical SMB mounted folder that works fine so whatever it is is limited to my containerized setup, LiveTV and only with a SMB share. Edited November 27, 2020 by GWTPqZp6b
GWTPqZp6b 50 Posted November 28, 2020 Author Posted November 28, 2020 @Luke Thank you. I noticed this morning that programs recorded from my VM based Emby can be replayed on my containerized version (direct play or transcoded) so its just LiveTV watching or recording thats causing the problems.
GWTPqZp6b 50 Posted January 18, 2021 Author Posted January 18, 2021 @Luke I have been unable to identify the root cause of this problem to date however as a NFS share works correctly I have a low impact work around.
Luke 42246 Posted January 18, 2021 Posted January 18, 2021 36 minutes ago, GWTPqZp6b said: @Luke I have been unable to identify the root cause of this problem to date however as a NFS share works correctly I have a low impact work around. Thanks for the feedback.
