Mossway 4 Posted November 7, 2020 Posted November 7, 2020 Hi, I am looking to purchase a Smart TV and want to make sure the one I buy, I can install the Emby client app on the TV. The one I've seen says that it is an Android TV but I hknest5 don't know what requirements the TV needs to have in order to install the Emby Client. Please can someone advise if this TV is likely to support it please? : Sharp 4T-C55BL3KF2AB 55-inch I won't hold you to it I can easily return if not but made sense to check here first from the community I have already purchased a Premier Emby Subscription Thanks
ebr 16338 Posted November 7, 2020 Posted November 7, 2020 Based on their screen shot of the home screen I'd say yes this should run our Android TV app just fine. Thanks. 1
Mossway 4 Posted November 7, 2020 Author Posted November 7, 2020 That's great. I did have a look on the Emby TV page, but may I ask what the minimum version number of Android TV Emby Client will run on I know this TV is Android 9.0 Thanks
ebr 16338 Posted November 8, 2020 Posted November 8, 2020 20 hours ago, Mossway said: but may I ask what the minimum version number of Android TV Emby Client will run on 5.1. This is what the original Fire TV devices are still on. 1
