ebr 16334 Posted November 9, 2020 Posted November 9, 2020 8 minutes ago, YoYo0014 said: ok i 'm waiting thanks ! You were already added. Check your spam...
YoYo0014 0 Posted November 9, 2020 Posted November 9, 2020 3 minutes ago, ebr said: You were already added. Check your spam... yes i found it and i install it . works perfect play some video that we can't play with the 1.4.9 like mp4 format on TVos 14.2.
bthjf1 0 Posted November 11, 2020 Posted November 11, 2020 Have you got an ETA for 1.5.0 to fix the issue with TVos 14.2 ? Thanks
Luke 42241 Posted November 11, 2020 Posted November 11, 2020 28 minutes ago, bthjf1 said: Have you got an ETA for 1.5.0 to fix the issue with TVos 14.2 ? Thanks Hi, we're working hard on it. We'll release it as soon as it's ready. Thanks. 1
YoYo0014 0 Posted November 11, 2020 Posted November 11, 2020 Problem with 1.5.0.(2) : when i use mpv : when you finally arrive to show just the seek bar you see on the left side the Time elapsed and on the right side the full Time . but when you double tap you see on the left side always 22:43 (Wrong elapsed time)and on the right side the remaining Time . Also after use the double tap : When you just tap the seek appear and Also the menu on the top when the movies is playing
vdatanet 1619 Posted November 11, 2020 Author Posted November 11, 2020 (edited) 10 minutes ago, YoYo0014 said: Problem with 1.5.0.(2) : when i use mpv : when you finally arrive to show just the seek bar you see on the left side the Time elapsed and on the right side the full Time . but when you double tap you see on the left side always 22:43 (Wrong elapsed time)and on the right side the remaining Time . Also after use the double tap : When you just tap the seek appear and Also the menu on the top when the movies is playing I think it's correct, when you tap once, elapsed time and duration is shown. When you tap twice current time and end time is shown. https://streamable.com/fpb3l2 Edited November 11, 2020 by vdatanet
vdatanet 1619 Posted November 11, 2020 Author Posted November 11, 2020 13 minutes ago, YoYo0014 said: Problem with 1.5.0.(2) : when i use mpv : when you finally arrive to show just the seek bar you see on the left side the Time elapsed and on the right side the full Time . but when you double tap you see on the left side always 22:43 (Wrong elapsed time)and on the right side the remaining Time . Also after use the double tap : When you just tap the seek appear and Also the menu on the top when the movies is playing I think I understand what you mean. Using MPV player double tap for zooming it's difficult to accomplish, it only works while timeline is visible. https://streamable.com/dq2ccs
YoYo0014 0 Posted November 11, 2020 Posted November 11, 2020 1 hour ago, vdatanet said: I think it's correct, when you tap once, elapsed time and duration is shown. When you tap twice current time and end time is shown. https://streamable.com/fpb3l2 Sorry i had not understand that was Current Time and enfin Time
YoYo0014 0 Posted November 11, 2020 Posted November 11, 2020 Look what is the issue when i tap once. https://streamable.com/14jvgs
YoYo0014 0 Posted November 11, 2020 Posted November 11, 2020 1 hour ago, vdatanet said: I think I understand what you mean. Using MPV player double tap for zooming it's difficult to accomplish, it only works while timeline is visible. https://streamable.com/dq2ccs https://streamable.com/14jvgs
vdatanet 1619 Posted April 16, 2022 Author Posted April 16, 2022 On 11/8/2020 at 6:40 PM, vdatanet said: It seems that the beta 1.5.0 (0) has fixed the problems of the native player, even those of the audio player (not showing artwork when playing), but the instability of the MPV player continues. Also, the PIP icon of the native player has disappeared. On 11/8/2020 at 6:50 PM, ebr said: Unfortunately, that was the fix for the music issue. Apple doesn't allow music apps to use PIP (don't ask...). Now Apple music app has pip, I guess PIP is allowed in music apps. Can you try enabling it again?
Luke 42241 Posted April 22, 2022 Posted April 22, 2022 We'll get there but we have some plumbing to do first.
unisoft 355 Posted May 20, 2022 Posted May 20, 2022 On 22/04/2022 at 16:14, Luke said: We'll get there but we have some plumbing to do first. I agree, let's fix de-interlacing FIRST (properly like double frame rate/sendfield) and frame rate match Other apps have done it for a while now......years on and still not done.....Its my number one of hate about the Emby App on Apple TV, despite it looking polished. 2
vdatanet 1619 Posted May 20, 2022 Author Posted May 20, 2022 5 hours ago, unisoft said: FIRST (properly like double frame rate/sendfield) and frame rate match And dynamic range match with HDR passthrough. 2
