Gilgamesh_48 1243 Posted November 5, 2020 Posted November 5, 2020 My Roku upgraded to 9.4.0 (Roku firmware) and it reset several of the sound settings. I had everything set to use "stereo" only and after the upgrade several of the settings reverted to the factory settings. Also I use "Volume leveling" at all times and after the upgrade it was reset to "off" and I had to press star "*" while a video was playing and turn it back on. That is the only way I could find to get that choice back. In this case Roku's update reset some of the audio choices. It was not a truly transparent upgrade like most of the earlier updates have been. 1
