heula 192 Posted November 5, 2020 Posted November 5, 2020 I have activated my HDhomerun tuners again for recording with Emby and it has been much improved since the last time I tried that. What I notice is when a new recording start I see that in Emby as a new recording appearing but in Kodi it won't appear unless I do a library update for the recordings or close Kodi and restart it again. Than the new recording(s) do appear. embyserver.txt kodi.old.log kodi.log
quickmic 1709 Posted November 5, 2020 Posted November 5, 2020 I'm currently verifying the issue. I'm using m3u tuner not HDhomerun but shouldn't make a difference. btw, can you watch LiveTV via emby4kodi? Here it's not working.
quickmic 1709 Posted November 5, 2020 Posted November 5, 2020 (edited) It's working here, Kodi syncs new Recordings on the fly. How are the other syncs? regular tv-shows, movies etc? I assume you are using kodi companion. Please disable last_played addon for testing. According to your log, it causes multiple issues. Edited November 5, 2020 by quickmic
heula 192 Posted November 5, 2020 Author Posted November 5, 2020 (edited) 6 minutes ago, quickmic said: It's working here, Kodi syncs new Recordings on the fly. How are the other syncs? regular tv-shows, movies etc? I assume you are using kodi companion. Regular tv show syncs fine and yes I use Kodi companion. I will test tonight if recordings do sync now. I thought live tv worked with Kodi companion but I'm not really using that. Edited November 5, 2020 by heula
quickmic 1709 Posted November 5, 2020 Posted November 5, 2020 1 hour ago, heula said: I thought live tv worked with Kodi companion but I'm not really using that Me too, but actually the stream is loading forever.
heula 192 Posted November 6, 2020 Author Posted November 6, 2020 18 hours ago, quickmic said: Me too, but actually the stream is loading forever. Yesterday my recordings did appear almost right away so I will keep track of that if this continues that way. Live TV with Emby for Kodi is working just fine for me on my two Shield TV devices. 1
