juro1971 11 Posted August 27, 2024 Posted August 27, 2024 I also had to adapt user and pw in item extra data. In general, the replacement works. Unfortunately, I had user access problems afterwards. Don't ask me why ?! some series and movies where missing, so I removed the path. An error message popped up. Also re assignment of the path now does not work anymore because I have not the right user rights?!
juro1971 11 Posted August 27, 2024 Posted August 27, 2024 Fu.. Now I chrashed soemthing and also the backup does not work anymore ..... Not good. I will now reinstall a full backup
juro1971 11 Posted August 27, 2024 Posted August 27, 2024 So now 4 GB to delete and restore, then unfortunatly the rescan of all libraries. Greetings Juro
Happy2Play 9811 Posted August 27, 2024 Posted August 27, 2024 Have no idea of everything you are changing but this is one reason I save everything with media as everything is alway available. Have only don't db changes on test systems that don't store with media. But have not run into any issues with path changes in my tests.
tedfroop21 89 Posted August 28, 2024 Posted August 28, 2024 Silly suggestion? Why not edit fstab and name your old /mnt/movies to /mnt/old_movies and your new drive to /mnt/movies, since you can name the mount point name to whatever you want? If your folder structures are the same, shutdown Emby, make the changes to fstab, run "sudo mount -a" to mount everything and when you turn Emby back on it won't know anything has changed....
juro1971 11 Posted August 28, 2024 Posted August 28, 2024 Because the IP /domain where the external USB was connected to has also changed. Moved the drive from a shield to the raspberry directly. However this was a total nightmare for me. I don't know what went wrong. I had many error messages and at the end a corrupt installation. Also the restoring of a local backup did not went well. After the restore emby server did not start. So I had to reinstall emby. Now I have my old status and now re scan and waiting for days. Changing Path of Library for me a valid use case which should be supported by standard @Luke This is not the last time I change my media paths. I have many project with different machines where I test. Next project is to move everting or split Home assistant and emby ?! It would be better if I bought a PI 5 to have more power and have the possibility of transcoding. Maybe now a mini PC with more power then a PI4. Have already one but this one is an oversized with I5 with 16 GB RAM. too much ... 5-10 W in idle. I am looking for a Dell wyse 5070 with a Celeron CPU and passive cooling. 3-5 W in idle. 1
_NAME_ 1 Posted January 4 Posted January 4 (edited) My solution for a similar problem - maybe this helps someone! I wanted to move my Emby Server from my Synology NAS (because of better transcoding performance) to an Ubuntu server (virtual machine) that already runs multiple Docker containers. All my media should remain on the NAS and will be accessed via NFS. 1. I made a backup of everything inside Emby's /config folder on my NAS and copied it over to the Emby /config folder on my Ubuntu server. 2. I mounted the NFT share on my NAS to /mnt/nas/video on the Ubuntu server. 3. In docker-compose.yml I just defined a volume (/volume1/video) which is the same as it used to be on my NAS. This way I did not need to change anything inside the Emby DB. Even if I should move my media to a new location, I just need to update the docker volume entry. Here's the docker-compose.yml emby: image: emby/embyserver:latest container_name: embyserver network_mode: host environment: - UID=1000 - GID=1000 - GIDLIST=123 # Matches 'render' group ID volumes: - /opt/emby/config:/config - /mnt/nas/video:/volume1/video devices: - /dev/dri/renderD129:/dev/dri/renderD129 # Direct path to the Iris Xe restart: unless-stopped Edited January 4 by _NAME_ 1
