procyon 2 Posted November 4, 2020 Posted November 4, 2020 I am having problems playing lossless audio files in Emby. I am using Chrome to play audio locally. No transcoding. When attempting to play certain flac files, I get the following error: No compatible streams are currently available... The files play just fine in apps like vlc. I get a similar error when trying to play these files to my rooku. mp3 and m4a files play just fine, and it's not all flac, only a select few files.
Happy2Play 9814 Posted November 4, 2020 Posted November 4, 2020 If you drag the file directly into Chrome does it play? But this sounds like the id3 tagging issue, will have to search but previous topics discovered tags cause this because the tagging version and flac are incompatible. https://emby.media/community/index.php?/topic/55997-flac-audio-not-playing-via-web-client/&do=findComment&comment=615191
Luke 42246 Posted November 4, 2020 Posted November 4, 2020 Hi there, please attach the information requested in how to report a media playback issue. thanks !
