primeflix 1 Posted November 3, 2020 Posted November 3, 2020 (edited) Hi It doesn't appear that you can watch a programme live and recorded it at the same time using IPTV - is that correct? For example, if I set a recording and then one of my users plays that channel live, the recording stops. Given emby buffers the streams I assumed this wouldn't be a problem. TIA Edit: So after testing, it seems that if there is a recording ongoing and that channel is played by direct streaming, the recording continues. However, if the channel is direct played, the recording is cancelled. Edited November 3, 2020 by primeflix More Information
Luke 42244 Posted November 4, 2020 Posted November 4, 2020 Hi, what do you mean by direct played? What Emby app are you playing from?
ebr 16337 Posted November 4, 2020 Posted November 4, 2020 How many connections does your m3u tuner allow simultaneously?
primeflix 1 Posted November 4, 2020 Author Posted November 4, 2020 A lot. Many more than was being used. Recording seems to be intermittently successful. Sometimes it records perfectly. Othertimes anywhere from 1 to 30 mins.
primeflix 1 Posted November 4, 2020 Author Posted November 4, 2020 Sure. I'll try and grab a log for it. Thanks for the replies
primeflix 1 Posted November 7, 2020 Author Posted November 7, 2020 Did a bit more testing and discovered that it was related to hls (m3u8) streams. What seems to be happening is that emby is happy to play hls iptv as long as only one stream is playing at a time. If another hls connection is made, the first stream gets kicked. Using ts format works fine, but hls has a lot of stability benefits for iptv. Especially when recording.
Luke 42244 Posted November 13, 2020 Posted November 13, 2020 On 11/7/2020 at 8:49 AM, primeflix said: Did a bit more testing and discovered that it was related to hls (m3u8) streams. What seems to be happening is that emby is happy to play hls iptv as long as only one stream is playing at a time. If another hls connection is made, the first stream gets kicked. Using ts format works fine, but hls has a lot of stability benefits for iptv. Especially when recording. Hi, does your provider only allow one stream at a time?
Carlo 4561 Posted November 13, 2020 Posted November 13, 2020 On 11/7/2020 at 8:49 AM, primeflix said: If another hls connection is made, the first stream gets kicked. Using ts format works fine, but hls has a lot of stability benefits for iptv. Especially when recording. If you have the option to switch your streams to TS format please do that and see if this improves things. Emby will prefer the TS format over HLS. How many streams are you allowed to have simultaneous from your provider?
Guest Posted November 13, 2020 Posted November 13, 2020 (edited) Removed Edited August 10, 2021 by samboo
Luke 42244 Posted November 16, 2020 Posted November 16, 2020 We'll take a look at it. Thanks for the feedback.
