cyrus104 0 Posted November 3, 2020 Posted November 3, 2020 (edited) I have been starting to create a mobile version of my content testing it to start. I am using the Windows server with 2x Nvidia graphics cards that I have used with conversion in Plex. Right now when start a "convert" task, the GPU is never accessed. I have confirmed that hardware acceleration is enabled and using the advanced menu, I can tell that Emby sees the Nvidia cards. I exported the logs for the hardware detection and the convert task. To me the hardware detection looks successful but in the convert task, CanDoInHardware and WillDoInHardware are both false. Thanks ffmpeg-remux-5be4ec27-3181-441b-9e2f-213b9ac24832_1.txt hardware_detection-63740019622.txt Edited November 3, 2020 by cyrus104
ebr 16310 Posted November 3, 2020 Posted November 3, 2020 Hi. Have you subscribed to Emby Premiere? Emby Premiere Feature Matrix
ebr 16310 Posted November 3, 2020 Posted November 3, 2020 Okay then can we please look at an example?
cyrus104 0 Posted November 3, 2020 Author Posted November 3, 2020 Thank you for pointing out the guide. I was able to pull the logs and add more detail to the original post.
softworkz 5129 Posted November 3, 2020 Posted November 3, 2020 @cyrus104 - The log file is titled "Remux". When remuxing, there is never any hardware acceleration involved.
ebr 16310 Posted November 3, 2020 Posted November 3, 2020 12 minutes ago, softworkz said: @cyrus104 - The log file is titled "Remux". When remuxing, there is never any hardware acceleration involved. Ha. Good point. There is nothing to "accelerate"
cyrus104 0 Posted November 4, 2020 Author Posted November 4, 2020 Ok, interesting. What is the difference in remux versus a "normal" conversion? I want to convert them to original quality mobile, so they will play on chromecast, browser, and mobile devices without transcoding needed. Thanks
ebr 16310 Posted November 4, 2020 Posted November 4, 2020 11 hours ago, cyrus104 said: I want to convert them to original quality That statement is actually contradictory . When you choose original quality that means it will not convert the video. Therefore, there is no need for GPU involvement because no video is being converted. A remux is when either just the container is being changed or just the audio is being converted. Does that make sense?
cyrus104 0 Posted November 4, 2020 Author Posted November 4, 2020 That makes perfect sense, because I think several of these just need to audio converted to be compatible.
