MangoMC 51 Posted November 3, 2020 Posted November 3, 2020 Hi Since today when i start a video file that ive got 2 times. One with 1080p and one in 4k emby is starting the wrong file. I want to watch the 4k File. But im getting 1080p. With only one quality, only 4k, im getting the correct one In emby and in Kodi/vlc Server: 4.5.2.0 FireTV: 1.8.4.2 Log send. User Marco, Time 04.43 embyserver.txt
ebr 16310 Posted November 3, 2020 Posted November 3, 2020 Hi. I didn't see any playback in your app log. Are you selecting the version you want in the drop-down on the detail screen?
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 Yes i select the correct quality and send a new log right now
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 Yes, but the error also happens sometimes, not everytime with the emby player too
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 What it for me fixed now is seperate the 4k movie library and the 1080p movie library. Before ive got one library and grouped same movies together
ebr 16310 Posted November 3, 2020 Posted November 3, 2020 Does it behave differently with the web app?
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 Same in webapp. New log attached embyserver (1).txt
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 Ok. i can use two different versions in one library, but when i group them it always plays the lower resolution. When i split them it plays the correct.
ebr 16310 Posted November 3, 2020 Posted November 3, 2020 So you are manually grouping these items? What if you use our naming conventions to have them grouped automatically?
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 (edited) I cant use that because ive got them in different path and folders. Because i dont want that everyone can access 4k movies. Or did i Missed something There? Movie (2020) [WEBDL-2160P AC3-5.1][HEVC]-EDE.mkv Movie (2020) [BLURAY-1080P AC3-5.1][X264]-PSO.mkv Edited November 3, 2020 by MangoMC
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 Also Movie (2020) - [BLURAY-1080P AC3-5.1][X264]-PSO.mkv Movie (2020) - [WEBDL-2160P AC3-5.1][HEVC]-EDE.mkv doesnt work, because they are in different paths. But with series it works, they are also in different paths and emby group them automically
Luke 42208 Posted November 3, 2020 Posted November 3, 2020 You've restricted user access to transcoding. This is probably affecting the decision making. Try undoing that and see if it helps.
Luke 42208 Posted November 3, 2020 Posted November 3, 2020 Let's focus on the web app first, so please test there. Thanks.
MangoMC 51 Posted November 3, 2020 Author Posted November 3, 2020 (edited) Now it suddenly work and suddenly not, i dont understand it External player in ATV app always playing the lower resolution, emby player sometimes 4k, sometimes 1080p Edited November 3, 2020 by MangoMC
Luke 42208 Posted November 3, 2020 Posted November 3, 2020 Let's ignore the external player for a moment as that is introducing more variables. What is happening in the web app?
