uberrice 0 Posted November 2, 2020 Posted November 2, 2020 (edited) So I tried this both for my anime folder and a random series - a movie folder containing a movie works just fine. Had the same problem with the rival with P. So I have files like: [HorribleSubs] Gintama - 303 [1080p].mkv or in the series: Happy S01E01 Saint Nick.mkv If I go into folders it's detected fine, I can see it there, play it, no problem. It's also generating some .bif files so it's definitely found, but in my library in the Shows view, it's not showing anything. I installed the anime plugin as well. What's the issue there? Edited November 2, 2020 by uberrice
Happy2Play 9802 Posted November 2, 2020 Posted November 2, 2020 What is your library folder structure? Emby currently requires a Series folder for every show. https://support.emby.media/support/solutions/articles/44001159110-tv-naming
uberrice 0 Posted November 2, 2020 Author Posted November 2, 2020 Alright, thanks, that worked. Now to get to the issue that I somehow can't connect to the server from other devices...
