bugmenot 1 Posted November 1, 2020 Posted November 1, 2020 (edited) Hello, i want to see the "Media Info" on my FireTV Stick too. Is it possible to enable it? On WebInterface i can see them on the bottom of the site. THX Edited November 2, 2020 by bugmenot
Solution neik 874 Posted November 2, 2020 Solution Posted November 2, 2020 Enable debug options, it should then be visible.
