gillmacca01 220 Posted November 1, 2020 Posted November 1, 2020 (edited) I have just reset Emby (running latest beta version), including removing nfo files, and now I am finding some episodes are not being identified, although the episodes are on TVDB Here is just one example: Star Trek The Next Generation - 1x15 - 11001001 (this is the way I have it named) TVDB: https://thetvdb.com/series/star-trek-the-next-generation/episodes/46522 Metadata is not being retrieved, inspecting the nfo file, no data is in there Tried, 'Search for Missing Metadata', 'Replace All Metadata' and have also tried a library scan (TV Series level and full) and also identify tv series The TVDBID, I manually added to see if it would help All other episodes in this series are being identified correctly I have attached latest server log and nfo file embyserver.txt Star Trek The Next Generation - 1x15 - 11001001.nfo Edited November 1, 2020 by gillmacca01
GrimReaper 4861 Posted November 1, 2020 Posted November 1, 2020 And the other episodes that metadata was not fetched, can you see any pattern in filenames? Did you try renaming this single episode to some other naming convention (SxxExx, for example), just to check whether it'll be identified properly? In your (mostly empty) nfo, episode TVDBID (46523) is different than the actual one (46522)? Also, date added is actually that Episode title, in YYYY-MM-DD, you might try deleting just that part of filename and rescan, see what happens? Cheers
Happy2Play 9802 Posted November 1, 2020 Posted November 1, 2020 @Luke The episode is not parsed correctly with that file name. Dropping the episode name to Star Trek The Next Generation - 1x15 work but not Star Trek The Next Generation - 1x15 - 11001001 (in my tests).
Luke 42208 Posted November 1, 2020 Posted November 1, 2020 yea episodes with numbers like that in the filename will always be tricky. I would just correct the season and episode numbers for it manually and then refresh the metadata on it.
Deathsquirrel 745 Posted November 2, 2020 Posted November 2, 2020 For reference, \TV\Star Trek the Next Generation\Season 01\Star Trek The Next Generation S01E15 11001001.mkv identified without issue.
Happy2Play 9802 Posted November 2, 2020 Posted November 2, 2020 Yes the episode number does not get parsed properly with that specific naming scheme above. As I get no episode number in metadata as shown in episode nfo in first post.
