Carlo 4561 Posted November 3, 2020 Posted November 3, 2020 You could certainly try installing right over top of what you currently have. No need to uninstall.
jochob 3 Posted November 3, 2020 Author Posted November 3, 2020 2 hours ago, cayars said: You could certainly try installing right over top of what you currently have. No need to uninstall. I did, and still the same
Carlo 4561 Posted November 3, 2020 Posted November 3, 2020 This is something the devs will need to look into.
jochob 3 Posted November 3, 2020 Author Posted November 3, 2020 OK, since I noticed that on kodi addon works properly it's enough for me But it still puzzling me.
Luke 42241 Posted November 5, 2020 Posted November 5, 2020 What device are you running Emby Server on?
jochob 3 Posted November 5, 2020 Author Posted November 5, 2020 10 minutes ago, Luke said: What device are you running Emby Server on? Minix NeoU9. An android TV box.
Luke 42241 Posted November 5, 2020 Posted November 5, 2020 Are you able to update to a newer version of android?
jochob 3 Posted November 5, 2020 Author Posted November 5, 2020 20 minutes ago, Luke said: 5 minutes ago, Luke said: Are you able to update to a newer version of android? I'm afraid not. It depends on the brand, and there is no update for 2 years...
Luke 42241 Posted November 5, 2020 Posted November 5, 2020 Ok in order to solve this, we'll have to test on this device ourselves. I'm not sure when we might be able to test on this older device.
jochob 3 Posted November 5, 2020 Author Posted November 5, 2020 All right, there is no rush at all. When you are able to, only let me know to schedule a date. Thank you all for taking the trouble.
jochob 3 Posted November 6, 2020 Author Posted November 6, 2020 Is there a way to downgrade the server? I've installed v.4.5.2.0 and with the previous version I remember all worked properly... I'd like to try it out if it is possible.
Carlo 4561 Posted November 6, 2020 Posted November 6, 2020 What you have to watch with downgrades is any changes that might have happened with new code. If you have your database files from 4.5.2.0 you can safely restore that version but if not it might not be worth the risk.
Luke 42241 Posted November 6, 2020 Posted November 6, 2020 Are you saying this worked on an older version?
jochob 3 Posted November 6, 2020 Author Posted November 6, 2020 17 minutes ago, Luke said: Are you saying this worked on an older version? Yes, it worked properly since I installed it... I remember install it about July, and since then, if I'm not mistaken only one update was released.
jochob 3 Posted November 9, 2020 Author Posted November 9, 2020 (edited) Sorry for being stubborn, but is there a way to download and install a previous version of the android server? Because I've been running some test, and uninstalled the server, an reinstall the beta versions available. But now the problem happens in all my library. I think, installing that previous version and setting the server up again will work for me, as it was before... But I can't find them anywhere. Thank you! Edited November 9, 2020 by jochob
ebr 16334 Posted November 9, 2020 Posted November 9, 2020 Hi. Have you tried just re-installing the current version? It looks like things are missing from your install.
jochob 3 Posted November 9, 2020 Author Posted November 9, 2020 Yes I did. Someone told me that before an still the same. I'm looking for the server available about July when I first installed the server and all worked fine for me.
Carlo 4561 Posted November 9, 2020 Posted November 9, 2020 Hi, Typically only the current release and beta versions are available as older versions may not work with newer clients and vice versa. If there is a problem in a release version it's better to identify the issue so it can be fixed. 1
jochob 3 Posted November 9, 2020 Author Posted November 9, 2020 41 minutes ago, cayars said: Hi, Typically only the current release and beta versions are available as older versions may not work with newer clients and vice versa. If there is a problem in a release version it's better to identify the issue so it can be fixed. It's a shame. I'll hope then that you can identify the bug.
Carlo 4561 Posted November 9, 2020 Posted November 9, 2020 This could be in part because of the older version of Android being used. If you haven't gotten an update in over 2 years that problematic in itself and probably not the best OS to be running your media server on.
jochob 3 Posted November 9, 2020 Author Posted November 9, 2020 I understand, but right now I'm not able to change my OS to run my server on... And since once was possible on this device I hope the issue is solvable.
jochob 3 Posted November 13, 2020 Author Posted November 13, 2020 (edited) 43 minutes ago, Luke said: Have you tried installing 4.4.3 again? I've been trying look for that specific file to try it on, but I couldn't find it yet. @cayars told me in previous post, that it would be useless, but I'd like to give it a try. It'd be nice if I can find a place when I can download it. Thank you! Edited November 13, 2020 by jochob
Carlo 4561 Posted November 13, 2020 Posted November 13, 2020 I don't think I said it wouldn't help. I was saying that doing an OS upgrade would be the first things I'd do as 2 years without an update is a long time. I don't know for sure but think you might have a compatibility issue right now between Emby/OS/Device.
jochob 3 Posted November 13, 2020 Author Posted November 13, 2020 (edited) On 11/9/2020 at 4:43 PM, cayars said: Hi, Typically only the current release and beta versions are available as older versions may not work with newer clients and vice versa. If there is a problem in a release version it's better to identify the issue so it can be fixed. That's the post I was taking about... , it is more than possible that my English tricked me and I missunderstood it, if it is the case, I apologise for that. Edited November 13, 2020 by jochob 1
